Author Topic: 88 K100LT Random Misfire Suddenly Worse  (Read 26336 times)
Offline Edb100cafe
Re: 88 K100LT Random Misfire Suddenly Worse
« Reply #25 on: May 21, 2016, 08:01:07 PM »
Update- Fuel Pressure is 36psi while cranking
  • MA
  • 88 K100LT
« Reply #26 on: May 21, 2016, 08:16:04 PM »
fuel lines reversed perhaps...
Offline The Dude
« Reply #27 on: May 21, 2016, 08:19:17 PM »
Red herring alert.
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #28 on: May 21, 2016, 08:51:58 PM »
Been there, done that one too. I've done them all.
Offline Edb100cafe
« Reply #29 on: May 21, 2016, 09:02:34 PM »
Fuel lines are in the correct location
  • MA
  • 88 K100LT
« Reply #30 on: May 21, 2016, 10:29:12 PM »
Sounds like the temperature sensor is faulty or a bad connection. A known problem with bricks, there is a test procedure for the switch on this site.
But before you do this clean the connection and make sure it is not loose.
Offline The Dude
« Reply #31 on: May 21, 2016, 11:16:19 PM »
Yep.wont run for 15minutes with them reversed...OP image shows them clearly, connected correctly.
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline Edb100cafe
« Reply #32 on: May 22, 2016, 11:15:04 AM »
I checked the resistance of the sensor at the EFI plug and actual sensor. 70*F and got 2.4k ohms. So the senser and wiring are both good.
  • MA
  • 88 K100LT
Offline Edb100cafe
« Reply #33 on: May 22, 2016, 05:52:26 PM »
Still no improvement. I pulled the cover on the HES and noticed this part of the plastic to be white. Has anyone seen this before?
  • MA
  • 88 K100LT
Offline jjs1234
« Reply #34 on: May 23, 2016, 03:42:15 AM »
Mine looks like this...
  • Northern California
  • 1984 K100
Check out my build! Complete tear-down!
Mr. Creative
Offline Edb100cafe
« Reply #35 on: May 23, 2016, 07:09:00 AM »
Ok thanks, so the white isn't abnormal
  • MA
  • 88 K100LT
Offline jjs1234
« Reply #36 on: May 23, 2016, 10:25:42 AM »
I doubt it's something as small as that is causing your issue.
Sent from my HUAWEI MT7-L09 using Tapatalk
  • 1984 K100
Mr. Creative
« Reply #37 on: May 23, 2016, 10:51:07 AM »
How large does something need to be to cause a problem, jjs?  :hehehe
Offline The Dude
« Reply #38 on: May 23, 2016, 02:51:20 PM »
Is there any evidence that the smoke has been let out?
  • K75s
Current.
TR6R 1973 from new.
All the best!
« Reply #39 on: May 23, 2016, 06:01:03 PM »
Good observation, Dude! It's time for a sage cleansing.
Offline Edb100cafe
« Reply #40 on: June 06, 2016, 11:10:24 AM »
Update-
After checking all that I could, decided to get a Efi ecu from ebay. Bike started right up and is running great.
  • MA
  • 88 K100LT
« Reply #41 on: June 06, 2016, 11:13:08 AM »
Thanks for the update!  :2thumbup:
Offline The Dude
« Reply #42 on: June 06, 2016, 02:50:06 PM »
Another Brick back in the wall.Good news.
  • K75s
Current.
TR6R 1973 from new.
All the best!
