Author Topic: ABS lights  (Read 8823 times)
Offline alexis291
ABS lights
« on: March 22, 2016, 08:20:33 PM »
I can hear you groaning ... not another ABS light question!
So the fault I have is that the central ABS light in the dash glows for a few seconds when I use the front brake. A few days ago it wouldn't go out after I set off to work but did after a few miles and stayed off for a few days.
"Faulty brake light switch" I thought. "I'll get round to that in a few days."
All was ok for a while but now the lamp glows when I use the front brake, just for a couple of seconds, then goes out. It does this each time I brake.
Any ideas? The faulty switch theory?
  • UK
  • K1100RS 1995
Re: ABS lights
« Reply #1 on: March 22, 2016, 08:46:23 PM »
Did you go here then type "abs light" in the search box and read all the related posts, alexis? It's your turn to groan now.
Re: ABS lights
« Reply #2 on: March 22, 2016, 08:52:28 PM »
there are 2 abs lights... im trying to figger out center abs light because there aints one...
does your center abs light flash steady or does it alternate with its self...
 :useless
Re: ABS lights
« Reply #3 on: March 22, 2016, 08:56:37 PM »
While you're groaning, alexis, would you please put your bike's model and year in your profile so it shows up in each of your posts?
Re: ABS lights
« Reply #4 on: March 22, 2016, 09:00:42 PM »
The idiot light you are speaking of is the bulb monitor unit warning light.  If you or a previous owner installed LED's in the instrument cluster it is quite normal for that light to flicker when the brakes are applied.  It may also flicker if the brake light is different than the 1157 bulb that is supposed to go in there.
My BMU idiot light flashes every time I use the brakes to remind me that I am an idiot with LED's in the cluster.
I have learned to live with that knowledge and accept the fact that I am an idiot.  A side benefit is that my wife finds it good that I agree with her.
Offline alexis291
Re: ABS lights
« Reply #5 on: March 23, 2016, 07:32:43 AM »
Laitch - groan, yes, can't find a similar problem here though
Johnny - it's the one with the warning triangle
Mighty Gryphon - no LEDs in my cluster
I have now discovered that the brake light does not work when the front brake is applied, but it does with the rear. I expect it will be the switch so will investigate that but I'm puzzled why the light comes on when I brake and then slowly dims to off. Why doesn't it just stay on ?
  • UK
  • K1100RS 1995
Re: ABS lights
« Reply #6 on: March 23, 2016, 09:54:14 AM »
Because if it just stayed on it wouldn't be a problem, alexis.
Re: ABS lights
« Reply #7 on: March 23, 2016, 11:47:51 AM »
if you can read... click this link...
http://www.motobrick.com/index.php/topic,331.0.html
if you caint read... click this link...
http://www.motobrick.com/index.php/topic,7932.0.html
Offline alexis291
Re: ABS lights
« Reply #8 on: March 23, 2016, 07:07:35 PM »
Johnny, you f-ing a-hole, I can read but I clicked the second link - is that ok you f-ing a-hole?
Problem solved I believe. I discovered a horrendous repair to the front brake switch wiring which is now soldered until I get a new switch. Lights now ok.
  • UK
  • K1100RS 1995
Offline alexis291
Re: ABS lights
« Reply #9 on: March 24, 2016, 04:45:04 PM »
Standard part - £40
DC1C-C3LC - £5 on eBay
Hmmm...
  • UK
  • K1100RS 1995
Offline TrueAce
Re: ABS lights
« Reply #10 on: March 24, 2016, 07:31:02 PM »
Does it come in 9mm?
  • Florida
Re: ABS lights
« Reply #11 on: March 24, 2016, 08:49:45 PM »
Standard part - £40
Hmmm...
How did you decide on that switch, alexis?
Offline alexis291
Re: ABS lights
« Reply #12 on: March 25, 2016, 04:51:02 AM »
Laitch I found it here:
http://www.k100-forum.com/t8323-k1100-front-brake-light-switch
BTW, my post to Johnny has evidently been jacked as those who read it before yesterday will know. I'm not going to abuse anyone who is not an a-hole.  So I would be grateful if whoever jacked it will admit it and stop being a f-ing a-hole.
  • UK
  • K1100RS 1995
Re: ABS lights
« Reply #13 on: March 25, 2016, 09:54:55 AM »
Here's that same switch available in the US
http://www.alliedelec.com/-dc1c-c3lc/70356572/
Offline alexis291
Re: ABS lights
« Reply #14 on: March 31, 2016, 06:06:52 PM »
Switch now fitted and works fine. It has three wires so you will need to work out which two to use to copy the original switch. The wires are shorter than the original switch but plenty long enough. I de-pinned the original connector and re-used it.
  • UK
  • K1100RS 1995
