Author Topic: Runs while on the center stand.  (Read 21920 times)
Offline gpcrane
  • Simian Wrench rides a brick
Re: Runs while on the center stand.
« Reply #25 on: February 15, 2016, 05:54:25 PM »
The first pic is the EFI and cable just outside the bike frame, the second pic is the EFI in place.
Greg
  • 87 K 75S 02 R 1150RS
Online Laitch
« Reply #26 on: February 15, 2016, 05:56:35 PM »
Your images are blacked out, gp; my images are appearing. Can you see your images on your screen?
Offline gpcrane
« Reply #27 on: February 15, 2016, 05:58:18 PM »
As you can see it needs to be bent tight to get past the frame.  Once in place it still has a tight bend.  Are other bricks not like this?
« Reply #28 on: February 15, 2016, 05:58:52 PM »
all images visible from here.
cable routing looks like mine.  sharp bend down after exiting ECU.
Offline gpcrane
« Reply #29 on: February 15, 2016, 05:59:33 PM »
My pics show up on my page
Online Laitch
« Reply #30 on: February 15, 2016, 06:02:02 PM »
Well, I don't know what's happening here.
How's the ECU mounted? Is it in the bottom of the tool box that's mounted to rubber bushings attached to the frame?
« Reply #31 on: February 15, 2016, 06:13:18 PM »
yup. his mounting looks standard/normal.
Online Laitch
« Reply #32 on: February 15, 2016, 06:17:13 PM »
It looks decided abnormal to me, now that I've got the images. That thing is out of position. I don't know what's in the way but it should be further under the seat. The tool box should be mounted over two frame-mounted  rubber donuts  that fit within plastic half moons molded into the front side of the box. If it were mounted correctly it would be higher, more forward and the plugs cable would be inside the frame rails and have a more of a curve and less right angle bend.
Online Laitch
« Reply #33 on: February 15, 2016, 06:21:34 PM »
I see it shoved back in there but is it mounted on the bushings, gp?
« Reply #34 on: February 15, 2016, 06:23:47 PM »
The ECU position and bend at the connector looks pretty normal to me.
Offline gpcrane
« Reply #35 on: February 15, 2016, 06:32:13 PM »
Laitch, yes it is mounted on the bushings.  The split in the bushings is slotted in the plastic frame.
Online Laitch
« Reply #36 on: February 15, 2016, 06:35:07 PM »
That's not what I'm talking about. There are bushings mounted on frame spikes that the tool box rests on. Is that happening?
Offline gpcrane
« Reply #37 on: February 15, 2016, 06:41:05 PM »
Yes, the tool box is on the bushing sticking out from the gas tank side.
Offline gpcrane
« Reply #38 on: February 15, 2016, 06:45:28 PM »
I have to go to work now, back in 14 hours.  I work nights.  Greg
Online Laitch
« Reply #39 on: February 15, 2016, 06:47:10 PM »
Thanks for checking that, gp. It's probably the fish-eye look of that image that is skewing things for me. If this radical bend in the cable is typical from yours and rbm's experience. I'm right baffled. You've got it working though and that's what counts.
Online Laitch
« Reply #40 on: February 15, 2016, 08:17:49 PM »
Damn! I can't get this thing to gallop! :beatdeadhorse:
Anyway, these are for comparison. If the battery were installed it wouldn't impinge on the cable. The lower cable tie on the left diagonal frame member could be removed to allow the cable to be straightened and the right side cable loop to be extended further rearward but it's ok as is.
