Author Topic: Estimated weight? K11/K100  (Read 9404 times)
Offline ramnaam
« on: December 09, 2015, 09:58:52 AM »
Has anyone weighed a k100 or k11 without fairing and ABS deleted? Or any condition close by. Or could anyone estimate the weight?
  • Sweden, Norrköping
  • BMW K1100 Police
Offline F14CRAZY
Re: Estimated weight? K11/K100
« Reply #1 on: December 09, 2015, 11:49:55 AM »
My K75c with its Pichler full fairing, side cases, and 35L top case is 608 lbs
  • Grand Rapids, MI
  • '87 K75C
« Reply #2 on: December 09, 2015, 12:55:18 PM »
This site gives the weight of a naked K100 with a full fuel tank. It doesn't specify whether it has ABS brakes.
http://www.bmbikes.co.uk/specpages/K100.htm
« Reply #3 on: December 09, 2015, 01:08:15 PM »
If data isn't coming in fast enough for you, ramnaam, you can go to this site and add up the weight of the various components that interest you.
http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51754&rnd=07012015 :sip:
« Reply #4 on: December 09, 2015, 06:28:57 PM »
Assuming you're talking the K100RT fairing.  Looking up specs for the bikes -- RT, Naked -- the difference in weight for the fairing is about 14KG / 31 lbs.  Add in the weight of ABS of about 11 KG / 25 lbs.  means the equipment delete will net you about 25 KG / 56 lbs. savings in weight.
Offline Snowman
  • Aberdeen SD.
« Reply #5 on: December 11, 2015, 09:15:18 AM »
I think the ABS weighs more than 25lb. I was really surprised when I picked up the box of components after removing ABS from my K11LT, it was a 'lift with your knees moment'. I might throw it on a scale and see.
« Reply #6 on: December 11, 2015, 09:29:37 AM »
MAX BMW lists K100RS ABS modulators at around nine pounds each.
http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51709&rnd=07012015
Offline ramnaam
« Reply #7 on: December 13, 2015, 08:10:36 AM »
Thanks all, great feedback
  • BMW K1100 Police
