Author Topic: K engine driving an ultralight  (Read 9172 times)
Offline FranK75
« on: November 14, 2015, 09:57:12 PM »
The K engines are powerful, high output for their weight, reliable. I am considering using a K75 engine to power an ultralight airplane. May have to shave off weight where ever possible.
  • Murrells Inlet, SC
  • K75
Re: K engine driving an ultralight
« Reply #1 on: November 14, 2015, 10:07:09 PM »
good ones are pretty cheap on the market too.  Not sure how you'd shave weight aside from the transmission & clutch.  Maybe lighten the flywheel.
Offline FranK75
« Reply #2 on: November 14, 2015, 10:11:57 PM »
I would grind off as much aluminum as possible from all over the engine
  • K75
« Reply #3 on: November 14, 2015, 11:36:38 PM »
Seen R100 and 1100 engines on ultralites and small planes.  Makes sense, no radiator to worry about
Offline Mongrel
« Reply #4 on: December 07, 2015, 01:08:03 AM »
Yeah, maybe something air-cooled would have a better power-to-weight ratio? Not sure, but worth looking into!
'86 K75c
Offline FranK75
« Reply #5 on: December 07, 2015, 10:34:40 AM »
Great points on the air cooled. Thanks - makes more sense.
Frank
  • K75
Offline wmax351
« Reply #6 on: December 09, 2015, 11:49:55 AM »
Air-oil cooled R11's or R12's are probably a better bet. The oil cooler can be thermostatically controlled, and potentially controlled with flaps. Also, carbureted and can be set up with dual plugs and (potentially) magnetos. Don't want engine failure from electrical failure. That way you can duplicate critical parts.
Counter Balancer adds some weight too.
BMW bike engines are good for this, they have a high duty rating, and separate engine/transmission.
You will need to consider the thrust loading on the output shaft. If you are doing a reduction drive (which I would assume you are) that will take care of it.
  • Albuquerque, NM
Bikes:
Offline F14CRAZY
  • Grand Rapids, MI
  • '87 K75C
« Reply #8 on: December 09, 2015, 01:12:39 PM »
It'd be more adventuresome to use a Ural engine; however, you'd probably be making shorter flights. :hehehe
Offline FranK75
« Reply #9 on: December 09, 2015, 10:50:43 PM »
No problem. I would bring lots of tools and spare parts.
  • K75
« Reply #10 on: December 09, 2015, 11:26:30 PM »
As a rabid Uraligist I resent that remark though I cannot argue with it  :giggles
Offline F14CRAZY
« Reply #11 on: December 10, 2015, 05:53:20 AM »
How about a Chang Jiang engine?
  • Grand Rapids, MI
  • '87 K75C
