Author Topic: Steering Head Bearings & Races  (Read 3778 times)
Offline MCRyder
« on: September 24, 2015, 10:28:04 PM »
I'm looking at replacing the steering head bearings on my K75RT.  I've found an aftermarket source for the bearings from All Balls, #22-1024-A, OEM Cycles.  It shows the correct application for the RT.  Has anyone used this set and do the races (which also need replacing) come with the bearings or are they ordered separately and what source?
Thanks.
Mark - East Texas
'14 Suzuki V-Strom 1000
'12 Aprilia Shiver
'92 BMW K75RT (#3)
Offline gone_ape
  • 94 K75RT (Now Standard)
Re: Steering Head Bearings & Races
« Reply #1 on: September 25, 2015, 11:04:59 PM »
People have used those which you've mentioned.  IIRC the "under bearing cup seals" provided in their "kit" are not correct and apparently OEM seals are the only alternative.
BMW P/N:  31 42 1 234 509    RING (from 08/91)
I wrote this article here and documented my experience with bearings available from NAPA Auto parts.
http://www.motobrick.com/index.php/topic,6906.0.html
Enter a search and you'll find the info on the "All Balls" alternative.
  • Austin, TX
Offline MCRyder
« Reply #2 on: September 26, 2015, 09:55:02 PM »
Thanks for the reply.  I found the OEM bearings with the races at Max's BMW, they still show the superseded part #.  Might go that route, more $ but less worry about fit when installing.  I'll also get the seals, when I make the order.
I'd found the video by Chris Harris, you're right about the "colorful language" but he does know his stuff and does a good job of making it straight forward.  I like how he doesn't remove the fairing to do the job.  I'd contacted a local BMW shop who said they'd have to do that to do the bearings, after watching Chris' video I thought "why?"
Mark - East Texas
'12 Aprilia Shiver
'92 BMW K75RT (#3)
Offline racinrich
« Reply #3 on: September 28, 2015, 06:21:54 PM »
did mine k1100lt without removing fairing , did not need torch , welder or profanity ! got head bearing tightening procedure and specs from local bmw dealer .
1993 k1100 lt silk blue
des plaines ill
USA
