Tach was working now not!
Topic: Tach was working now not! (Read 5430 times)
lhead71
June 24, 2011, 10:05:20 PM »
I took apart the instrument pod and had to replace the gear indicator lcd. After I put it all back together, my tach does not work anymore. I had to remove the tach needle and face to get to the lcd. Any ideas as to why?
Scott_
Administrator
Re: Tach was working now not!
Reply #1 on:
June 24, 2011, 11:09:38 PM »
Well it's hard to say.
Possibly something happened to the meter movement when you put the needle back on.
Or there is something electrical that's not making connection now.
Is everything else working? all the lamps and indicators, and speedometer?
My Garage
frankenduck
Adrninistrator
Reply #2 on:
June 25, 2011, 02:33:24 AM »
You should've asked this question ahead of time. It's possible to replace the GPI without removing the tach faceplate - you can do it from behind.
http://www.motobrick.com/index.php?topic=517.0
New to K bikes?
Click here.
K Bike Maintenance & Mods:
Click here.
lhead71
Reply #3 on:
June 25, 2011, 06:49:10 AM »
Doh! Everything else is working ok even the new gear indicator. I noticed when I took it apart again last night that the needle seems to add too much weight to the shaft of the Tach and presses the rear of the assembly into its housing casuing it to bind. Is the needle weighted?
lhead71
Reply #4 on:
June 25, 2011, 02:52:42 PM »
Well, It is definitely mechanical. When I hold the cluster straight up and down attached to the bike and the bike is running tach works no problem, then add the tilt to the pod and it seizes up.
Anybody have a used cluster for sale?
