Author Topic: Oil filter bolts hogged out.  (Read 6753 times)
Offline Nantucket_Red
« on: July 02, 2015, 05:39:39 PM »
So the oil filter allan heads are stripped out. About to cut the heads off and order bolts. What is a better idea.... I'm sure someone has dealt with this before.
  • Cape Cod,MA
  • 1987 BMW K100RT
Re: Oil filter bolts hogged out.
« Reply #1 on: July 02, 2015, 06:14:33 PM »
Well, to be able to work on it the easiest, remove the entire pan bottom then you can work on a bench without laying under the bike.
You could also drill them out with left handed drill bits/extractors, but yes you will need some new ones.
A good local hardware store may have some without them having to come from BMW.
M6x20mm is the screw size for the filter cover, the pan mounting screws are M6x25mm if you want to take one of them to the local store for sizing....
« Reply #2 on: July 02, 2015, 06:33:08 PM »
you could also use a dremal to cut a slot in them
« Reply #3 on: July 02, 2015, 06:51:43 PM »
I like that idea chaos. Gonna try it. If all else fails I'll drop the pan and go from there. Is there a gasket or is it goo I need to use for it?
  • Cape Cod,MA
  • 1987 BMW K100RT
« Reply #4 on: July 02, 2015, 08:06:53 PM »
No gasket.
I used RTV blue the last time I had one off.
Offline pallum
« Reply #5 on: July 03, 2015, 02:01:56 AM »
No gasket.
RTV is a necessity. Blue or Black from Permatex both work well  :2thumbup:
  • Federal Way, WA
Offline drut
« Reply #6 on: July 03, 2015, 06:59:15 AM »
Had some success with removing rounded allen bolts by hammering in slightly bigger torx bit.
  • Newcastle upon Tyne UK
« Reply #7 on: July 03, 2015, 06:53:39 PM »
Okay so I won't the battle. Replaced the hardware as well. Before I go and dump m oil in how full should the sight glass after the bike has been run up to operating temperature and then shut off? Should it be full or at the dot in the sight glass.
  • Cape Cod,MA
  • 1987 BMW K100RT
« Reply #8 on: July 03, 2015, 07:08:03 PM »
anywhere between the top and bottom is good.  dot is ideal.
« Reply #9 on: July 03, 2015, 07:51:39 PM »
Awesome. Bike runs again. Thanks for all the help guys.
  • Cape Cod,MA
  • 1987 BMW K100RT
Offline kryder
  • Realryder
  • Ryde ' em when I can.
« Reply #10 on: July 03, 2015, 07:58:47 PM »
This is the way I've done it in the past. After cutting a slot with a Dremel I use a big flat head and remove, then replace with new. The last K I bought had them overtightened.
  • Salida, Colorado and Park City, Utah
  • 1993 K75S
I live west and ski west, I ride east and west and sometimes north and south.
Motos currently owned,  or do these motos own me?
1993 K75S ( the Kryder )
2000 R1100S ( Blackie )
1986 R80RT ( Ole Red ) 1986 R80RT ( Ole Blue )
1994 BMW R1100RS ( Traveler )
Motos I have owned in the past; gone but not forgotten.
1964 Yamaha 55cc YJ1-K ( ringdinger )
1965 Yamaha Santa Barbara 125 ( ringdinger #2 )
1966 Honda CB160
1971 Honda CL350
1973 Yamaha RD350
1987 BMW K75T
1992 BMW K75S
1994 BMW R1100RSL
1978 BMW R100RS
