Throttle overhaul
Topic: Throttle overhaul (Read 4415 times)
dfx
^ Motobrick Curious
Throttle overhaul
April 16, 2015, 03:41:57 PM »
Hi,
I was wondering if there is an article on this in the forum. Mine on my 85 K100 seems heavy and I get pins and needles in my thumb after around 30 mins. Also the throttle stays in whatever position I put it when I take my hand off.
Alsace, France
K100RT 1986
Scott_
Administrator
Re: Throttle overhaul
Reply #1 on:
April 16, 2015, 05:54:15 PM »
Have you had the bike a while?
By chance is there a throttle lock screw on the perch? or possibly a throttle lock(throttle meister or similar) on the end of the bar where the bar end weight would normally be.
My Garage
1995 K1100LT 0302044
1997 K1100LT 0302488 (R.I.P.)
subforry
^ Proficient Motobricker
Reply #2 on:
April 16, 2015, 08:16:23 PM »
sticky throttle not good. I find my K1100 has light throttle meaning that it does not take much force to twist the grip. Could be a gummed up or rusted throttle cable. Give it some wd40. If that works look into a longer term solution.
Hermosa Beach, CA, USA
1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
Scott_
Administrator
Reply #3 on:
April 16, 2015, 09:58:57 PM »
Ah, I would advise no to the wd40 unless you want the cable to totally seize up. Any type of lubricant will cause the cable interior lining to swell.
Check for any binding at the butterfly shaft, possibly the tps switch causing issues.
My Garage
kris
^ SuperNatural Motobricker
Reply #4 on:
April 16, 2015, 10:07:57 PM »
I agree with the "no lubricant" comment. These cables are teflon coated. When I first got my bike I cleaned out the whole chain/ gear mechanism at the grip. It will take some light grease but my suggestion would to not go crazy gumming up the works with really heavy stuff or too much of anything. If that doesn't go then maybe replace the throttle cable or clean/ lubricate further down the line.
In The Hammer!! Hamilton, Ontario, Canada
1986 K100RT (Heinz) 2004 Kawasaki Concours (Eddy) 2007 Moto Guzzi Breva 1100 (Linda) Previous: 1968 Honda CD175 1973 Kawasaki S2350 1975 Honda CB550K
"I got bike fever bad!!"
dougrs
Motobrick Curious
Reply #5 on:
April 16, 2015, 10:13:36 PM »
On my 75 I had to remove the throttle tube and grip and clean up the ruster bar.
MD
'89 Yamaha FJ1200, '94 BMW K75
Chaos
Administrator
Mars needs women!
Reply #6 on:
April 17, 2015, 09:08:04 AM »
Quote from: dougrs on April 16, 2015, 10:13:36 PM
+1. LOTS or crud built up between the twist tube and handlebar. Made a world of difference just cleaning that.
sw ohio
1987 K75S VIN 0231
Throttle overhaul
