Author Topic: Fuel Sending Unit and Tank Pad Adhesive  (Read 11109 times)
Offline kris
« on: February 01, 2015, 10:08:49 AM »
Hi all,
Does anyone know where to source a new fuel sender unit for an '86 K100RT? Mine is rusty as hell and thought I'd change it out while I'm at everything else. Also, the rear tank pad came off. The factory adhesive had turned to slime. What have others used to re-attach this thing/ knee pads, etc.?
Much appreciated!
"I got bike fever bad!!"
Offline Brad-Man
Re: Fuel Sending Unit and Tank Pad Adhesive
« Reply #1 on: February 01, 2015, 05:01:05 PM »
Your BMW dealer can order one...
  • Marietta, GA
  • '85 K100
'74 RD350
Offline kris
« Reply #2 on: February 02, 2015, 09:11:02 AM »
Hi Brad-Man,
I appreciate the reply. I absolutely figured that but thought there might be someone out there with a salvageable part for less than $131. In fact I am going to try to re-wire the damaged part. It's worth a shot. It's very fine angel hair type wire. Not sure if I'll be able to source it or not.
Offline Brad-Man
  • Marietta, GA
  • '85 K100
'74 RD350
« Reply #4 on: February 02, 2015, 12:38:28 PM »
Kris, Snap that bugger up immediately!!  That price for its condition is amazing.
Offline kris
« Reply #5 on: February 02, 2015, 07:33:44 PM »
Thank you Brad-man!!
Offline Brad-Man
« Reply #6 on: February 02, 2015, 09:25:40 PM »
yw!
That's cheaper than I paid for one...
  • Marietta, GA
  • '85 K100
'74 RD350
Offline kris
« Reply #7 on: February 02, 2015, 09:59:45 PM »
Trying to see if he'll ship to Canada...closed at the moment but thanks so much for the heads-up. Kind of you.
Offline Brad-Man
« Reply #8 on: February 03, 2015, 04:45:16 PM »
I've gotten so much help here I was glad to be able to...
  • Marietta, GA
  • '85 K100
'74 RD350
Offline mw074
« Reply #9 on: February 04, 2015, 01:55:20 PM »
3M Super Weatherstrip Adhesive for the tanks pads.
  • Michigan
Offline kris
« Reply #10 on: February 04, 2015, 04:23:46 PM »
thanks so much...ended up going with silicone...should hold fine
Offline kris
« Reply #11 on: February 05, 2015, 02:40:48 PM »
The fuel sender guy wouldn't get back to me and it's gone. I now have a New York address I could have had it shipped to....c'est la vie. I'll keep shopping or maintain my efforts to repair the one I have.
Thanks so much. This is quite a community of good people!!
Offline Elipten
« Reply #12 on: February 05, 2015, 02:46:18 PM »
Just remember the bulk of that unit is to send a signal to a fuel gauge most bikes don't have, the other option is to trigger the low fuel light and to get power and ground to the fuel pump.  The first two well one can live without, the last is required to operate.   So one can make do.
  • San Antonio, TX
  • 1990 K75RT
Offline kris
« Reply #13 on: February 05, 2015, 04:33:40 PM »
Thanks for your note. Yes, I am aware of the functionality of the total unit. In a pinch I'm good with no fuel guage for a period. I'll get there eventually.
I appreciate your comment.
« Reply #14 on: February 05, 2015, 07:04:15 PM »
Even though your current fuel sender may look rusted and horrid, it probably is still functional.  Refer to my page on Messing with the In-tank Fuel Sender to see how you can renovate it.  The one I used for the photos was pretty bad but it still functioned.
Offline kris
« Reply #15 on: February 05, 2015, 10:28:55 PM »
Hi RBM, I'm afraid I pooched the fines wires not realizing there were wires under all the gunk. Can I still use it by flipping the board as you've indicated or wouldn't the electrics work at that point?
Thanks,
Kris
« Reply #16 on: February 05, 2015, 10:53:50 PM »
Unfortunately, no.  Once damaged, that resistor cannot be repaired and is trash.  Continue your search.  I found a sender from Germany at a good price last year; search for "Kraftstoffmesser Benzinstandgeber".  Here's one I just found:
http://www.ebay.de/itm/BMW-K100-LT-RT-K100LT-K100RT-Kraftstoffmesser-Tankgeber-Schwimmer-/251789113918?pt=DE_Motorradteile&hash=item3a9fccfa3e
Offline Brad-Man
« Reply #17 on: February 07, 2015, 06:45:55 PM »
I believe I have a fuel sender for '86+.. let me check tomorrow.
Looks like postage to Canada w/b ~$16.55 US...
  • Marietta, GA
  • '85 K100
'74 RD350
Offline kris
« Reply #18 on: February 07, 2015, 10:38:55 PM »
Thanks Brad-man!
Offline Brad-Man
« Reply #19 on: February 08, 2015, 07:38:51 PM »
Yeah - I've got one.  I'll check tomorrow to see if it will fit in one of the flat-rate boxes.
  • Marietta, GA
  • '85 K100
'74 RD350
Offline kris
« Reply #20 on: February 08, 2015, 08:17:54 PM »
Hey Brad-man, thanks for checking into it. What would you be asking for this unit?
Thanks,
Chris
Offline Brad-Man
« Reply #21 on: February 11, 2015, 05:12:15 PM »
$50 + shipping.
It will fit in a US Priority Flat Rate box!
If you give me the Us address you'll save bucks...
~$17 vs ~$66
  • Marietta, GA
  • '85 K100
'74 RD350
