Repair Guidance
Fork seals - but what else?
Topic: Fork seals - but what else? (Read 3391 times)
Gio
^ Proficient Motobricker
December 24, 2014, 06:00:50 PM »
Right side fork damaged in transit (leaking) so planning to replace seals/fluid both sides (main seals ordered) - but thinking about what else might be required / recommended ? I'm not familiar with the Showa shock (yet) but Haynes manual says that both lower sealing washers (#22 and 25 in diag - presumably aluminium crush) should be replaced - but what about the upper O rings (#3 and 5) ? I will be able to inspect bushings etc once everything is apart.
Bike has ~64k miles and do not know if PO's have done any fork maintenance - so am assuming not. Any experience / recommendations / tips from those that may have serviced the Showa would be very much appreciated.
Gio
NS, Canada
K75s ("Buttercup")
Halifax, NS
1994 K75s (UK spec)
1984 Honda 200ES (Big Red)
Scott_
Administrator
Re: Fork seals - but what else?
Reply #1 on:
December 24, 2014, 06:17:15 PM »
I suppose it depends on how they look when you remove them, but I'd suggest the brass bushings. #14 and #20. As they wear, it will allow excess movement and can allow the seals to leak oil.
My Garage
johnny
TrailBrakingThrottleWhacker
Reply #2 on:
December 24, 2014, 06:28:42 PM »
rodger that underscore...
was chronic leaker... when i replaced 14 and 20 i never had a leaker again... at least not a leaker that needed more than a seal mate...
Gio
Reply #3 on:
December 26, 2014, 02:27:44 PM »
Thanks Scott , Johnny - I'll give them a look over when forks apart.
Cheers!
Gio
NS, Canada
K75s ("Buttercup")
Halifax, NS
1994 K75s (UK spec)
