Author Topic: Fork seals - but what else?  (Read 3679 times)
Offline Gio
« on: December 24, 2014, 06:00:50 PM »
Right side fork damaged in transit (leaking) so planning to replace seals/fluid both sides (main seals ordered) - but thinking about what else might be required / recommended ? I'm not familiar with the Showa shock (yet) but Haynes manual says that both lower sealing washers (#22 and 25 in diag - presumably aluminium crush) should be replaced - but what about the upper O rings (#3 and 5) ? I will be able to inspect bushings etc once everything is apart.
Bike has ~64k miles and do not know if PO's have done any fork maintenance - so am assuming not. Any experience / recommendations / tips from those that may have serviced the Showa would be very much appreciated.
Gio
  • NS, Canada
  • K75s ("Buttercup")
Halifax, NS
1994 K75s (UK spec)
1984 Honda 200ES (Big Red)
Re: Fork seals - but what else?
« Reply #1 on: December 24, 2014, 06:17:15 PM »
I suppose it depends on how they look when you remove them, but I'd suggest the brass bushings. #14 and #20. As they wear, it will allow excess movement and can allow the seals to leak oil.
« Reply #2 on: December 24, 2014, 06:28:42 PM »
rodger that underscore...
was chronic leaker... when i replaced 14 and 20 i never had a leaker again... at least not a leaker that needed more than a seal mate...
Offline Gio
« Reply #3 on: December 26, 2014, 02:27:44 PM »
Thanks Scott , Johnny - I'll give them a look over when forks apart.
Cheers!
Gio
  • NS, Canada
Halifax, NS
1994 K75s (UK spec)
