Author Topic: 94 k75s upshift without clutch lever  (Read 5275 times)
Offline ludwig
« on: December 15, 2014, 02:26:39 PM »
Hello,
Returning from a ride yesterday noticed that my transmission upshifted without pulling the clutch lever....between 1-2, 2-3 when I was "pre-loading" the shifter.
I had not noticed this happening the last times I attempted "pre-loading" the lever ( for smoother shifting).
The lever has about 5 mm of freeplay before engaging.
Thanks for any advice.
  • manhattan
  • 94 k75s 95 k75s 81 Yamaha XS850s (gone but never forgotten)
ludwig
Re: 94 k75s upshift without clutch lever
« Reply #1 on: December 15, 2014, 02:32:51 PM »
Pre-loading?  Your lifting the shift lever without pulling the clutch?
Offline ludwig
« Reply #2 on: December 15, 2014, 02:41:01 PM »
Yes, just a little bit sometimes makes it smoother.
  • manhattan
ludwig
« Reply #3 on: December 15, 2014, 03:54:31 PM »
i often upshift and downshift without using the clutch... its a speed rpm thang...
« Reply #4 on: December 15, 2014, 05:00:05 PM »
Me too...I speed-match the rpms with the the target gear and shift. I do work the clutch some but it's just a formality, I don't think I squeeze hard enough to get much past the free play range.
Offline ludwig
« Reply #5 on: December 15, 2014, 06:42:21 PM »
OK Thx guys, was not sure if it was something of concern, but apparently not.
Cheers
  • manhattan
ludwig
Offline HYPERR
« Reply #6 on: December 18, 2014, 12:16:25 AM »
Same here.  You really only need to squeeze the clutch to the friction zone, no more.  It shifts much smoother that way.
As for the clutchless upshifts, I do it on occasion.  Load the shifter slightly, close the throttle just a smidgen, and it always snicks into next gear sooo smoothly.
1995 K75S Arctic Silver
