Seams that I will never be able register this bike, so unless I want an overweight coffee table I have to part it. Here goes.
Project pics are in my build thread (near the top of page 1 in the projekts section
I'm posting this from my phone so sorry its not detailed properly. Shipping is extra. All prices are OBO
I can't take PayPal cause I don't have a bank account, or a computer to print shipping labels from. Money orders would be the best / quickest.
Original bike:
Gas tank. No dents, no scratches through the paint. No corrosion. Come with pump, filter, cap and key$100
(may get frisky and strip / polish this)
Starter. Opened it up and it looked so nice I didn't fuss with it. Fresh paint $30
Before and after paint
Coil cover. Sanded and painted, might have the powerport someplace. $10
Rear Fairing. Comes complete. No deep scratches, no cracks. $40
Plug Cover. Looks great. Took way to much effort. $10
Stock seat. It was probably the nicest part on the bike when I got it. Pretty sure it's a new cover & foam. All I did before taking the pics was one quick wipe with detailer. Pan has very minor surface rust. Still totally rock solid.$50
Hard cases. Left side has a hole in the back and good latches, Right side is good EXCEPT for the latches
$50 (right case + the good stuff off the left)
Hard case brackets: $15 each
One can be seen above. Other one looks just like it. Especially when covered with a hard case!
Radiator. Needs a wash and maaaaybe a coat of paint. $40
Front fender. Sanded and primed $15
Coolant hose set. Great condition. $10
Throttle body set. Cleaned and painted.
Some parts satin black, some gunmetal. $55
Font and rear wheels (as a set because I removed the casting line on both) come with the tires ... $80
Front:
Primer spot on front wheel after running over it with 220. As you can see the previous sanding marks are quickly fading. I specifically primed this spot as a test because it was the roughest spot on the wheel
Only bend in the front wheel. Small enough th fix with an adjustable wrench and some protective blocks
Rear wheel:
Final drive & swing arm $55 for both
Painted gunmetal using duplicolor wheel paint
Rear rotor: $75
Front rotors: look the same as the rear really. Painted semigloss black. $150 (pair)
Brake calipers and associated bits
Hand controls: all work properly, levers are barely bent if at all
Computer $30
Front forks. Cleaned and painted but may need rebuilt
Screen for rad shroud. Straight but needs paint $5
Intake plenum: cleaned sanded primed and painted semigloss black $15
Plenum to TB couplers: umm.... They still couple perfectly?
Coils: $15 (pair)
Side panels: $10 each
No broken tabs
Left side
Right side
more to come, if you need something ask.
The following parts however are not suitable for resale:
frame: no title
engine: one corroded intake port,other 3 burn oil, plus the lower case leaks.
alternator: brushes shot, may also have other probs.
Alt cover: stepped on
front fairing& bracket: been ripped half off at least twice
rad shroud: cracked around the forks
Glove boxes: doors are missing
Gear sensor: internally corroded
