Author Topic: 1985 K100 part out - lots of good stuff - price drops! buy it before i scrap it  (Read 17839 times)
NickAndHisBrick
Seams that I will never be able register this bike, so unless I want an overweight coffee table I have to part it. Here goes.
Project pics are in my build thread (near the top of page 1 in the projekts section
I'm posting this from my phone so sorry its not detailed properly. Shipping is extra. All prices are OBO
I can't take PayPal cause I don't have a bank account, or a computer to print shipping labels from. Money orders would be the best / quickest.
Original bike:
Gas tank. No dents, no scratches through the paint. No corrosion. Come with pump, filter, cap and key$100
(may get frisky and strip / polish this)
Starter. Opened it up and it looked so nice I didn't fuss with it. Fresh paint $30
Before and after paint
Coil cover. Sanded and painted, might have the powerport someplace. $10
Rear Fairing. Comes complete. No deep scratches, no cracks. $40
Plug Cover. Looks great. Took way to much effort. $10
Stock seat. It was probably the nicest part on the bike when I got it. Pretty sure it's a new cover & foam. All I did before taking the pics was one quick wipe with detailer. Pan has very minor surface rust. Still totally rock solid.$50
Hard cases. Left side has a hole in the back and good latches, Right side is good EXCEPT for the latches
$50 (right case + the good stuff off the left)
Hard case brackets: $15 each
One can be seen above. Other one looks just like it. Especially when covered with a hard case!
Radiator. Needs a wash and maaaaybe a coat of paint. $40
Front fender. Sanded and primed $15
Coolant hose set. Great condition. $10
Throttle body set. Cleaned and painted.
Some parts satin black, some gunmetal. $55
Font and rear wheels (as a set because I removed the casting line on both) come with the tires ... $80
Front:
Primer spot on front wheel after running over it with 220. As you can see the previous sanding marks are quickly fading. I specifically primed this spot as a test because it was the roughest spot on the wheel
Only bend in the front wheel. Small enough th fix with an adjustable wrench and some protective blocks
Rear wheel:
Final drive & swing arm $55 for both
Painted gunmetal using duplicolor wheel paint
Rear rotor: $75
Front rotors: look the same as the rear really. Painted semigloss black. $150 (pair)
Brake calipers and associated bits
Hand controls: all work properly, levers are barely bent if at all
Computer $30
Front forks. Cleaned and painted but may need rebuilt
Screen for rad shroud. Straight but needs paint $5
Intake plenum: cleaned sanded primed and painted semigloss black $15
Plenum to TB couplers: umm.... They still couple perfectly?
Coils: $15 (pair)
Side panels: $10 each
No broken tabs
Left side
Right side
more to come, if you need something ask.
The following parts however are not suitable for resale:
frame: no title
engine: one corroded intake port,other 3 burn oil, plus the lower case leaks.
alternator: brushes shot, may also have other probs.
Alt cover: stepped on
front fairing& bracket: been ripped half off at least twice
rad shroud: cracked around the forks
Glove boxes: doors are missing
Gear sensor: internally corroded
stilbo
Re: 1985 K100 part out - lots of good stuff (updated some more)
« Reply #1 on: September 28, 2014, 09:47:18 AM »
Hello. Do you have front calipers and rear disc? Thx
NickAndHisBrick
« Reply #2 on: September 29, 2014, 01:20:06 AM »
Yes I do. Ill get pics of them when it's daylight again.
NickAndHisBrick
« Reply #3 on: September 29, 2014, 03:43:01 PM »
Brake pics
NickAndHisBrick
« Reply #4 on: October 01, 2014, 02:55:00 AM »
Now with way more pics!
Offline AgPete139
I saw that you are selling the tank and pump pump assembly together.
Are you able to sell the fuel pump collar / connecting pieces / dampener / fuel pump / etc separately?
My '87 K75 only has the spade connectors, fuel hose, and a Purolator bump that bounces around inside my tank.
1987 K75C
Progressive front springs & rear shock
EBC pads
Shaved down & recovered seat in black leather
Front fairing removed
Complete tune-up and new parts + painted
fixed kickstands
Pirelli Demon Sport tires 110mm & 120mm
Offline AgPete139
1987 K75C
EBC pads
fixed kickstands
Offline AgPete139
PM sent. Thank you, Nick.
1987 K75C
EBC pads
fixed kickstands
Offline AgPete139
Do you have the right hand controls and handlebars?
1987 K75C
EBC pads
fixed kickstands
Offline Billk
Can you put up a picture of the rear brake hose
  • NYS
Travisaurus
Would you be willing sell the left side controls, handlebars, shift lever, muffler, left foot peg bracket, the spring thingy that clips the back of the gas tank (I have have no idea what BMW called it lol), and/or the valve cover bolts?
I think AgPete139 asked about the handlebars first, but I am in desperate need of those left hand controls (the left side of my '87 K75S and my left shoulder took a bit of a tumble back in June)
Offline AgPete139
I don't need the bars or controls anymore. I actually had some spare cafe parts already.
1987 K75C
EBC pads
fixed kickstands
Offline Par751
Seat still available. I see its been a few months.
Offline Elipten
Are the side panels still for sale?
  • San Antonio, TX
  • 1990 K75RT
Offline AgPete139
Hi Nick,
I mailed you the check 3 weeks ago for the fuel pump assembly. I have not heard back from you. I saw that you cashed the check on November 12 though.
What is the status? Please respond to me here or via PM.
Thank you,
Peter
1987 K75C
EBC pads
fixed kickstands
Shadrach
I sent him $$ for stuff a few weeks back and I haven't heard a peep since. did anyone get what they bought from this guy?
Offline AgPete139
No! I'm still waiting, too! It's been over a month, and not a single reply or peep since! Nick, return our messages. You cashed my $45, and no package, tracking number, or reply.  This is unacceptable! I have sent you several private messages now.
I trusted you, a fellow gear head, and sent you a personal check against my better judgement with Paypal. Please respond or refund my money.
1987 K75C
EBC pads
fixed kickstands
Offline orforester
While I don't have brake parts or fuel pump. I do have fairing parts, I will send  you, if you pay shipping, ...For free if this guy doesn't deliver, if that is what you ordered?
Shipping from 97355
Bob
1989 K 100 RS se (SOLD)
1985 K 100 RS, now RT
2008 R 1200RT
stilbo
Do you still have the center stand and mounting hardware? Pretty sure my "helper" threw mine in the TRASH. Thanks!
arkman84
im looking for the fan motor. do you have one still?
