Author Topic: k75 clutch cable adjustment  (Read 10475 times)
i-man
« on: September 22, 2014, 08:31:42 AM »
I've found a number of written descriptions for adjusting the clutch cable on a k75, here and other places, but I can't find any videos. Chris Harris has a video, and it seems it would work for the K75, but he says that it's not for the K75.
Anyone seen this video? How is the procedure presented in the Chris Harris video different then the procedure for adjusting the k75 clutch? I'm sure i can make it work without one, but I really find the videos easier to understand.
i-man
Re: k75 clutch cable adjustment
« Reply #1 on: September 22, 2014, 08:33:29 AM »
oh yeah,
« Reply #2 on: September 22, 2014, 09:55:55 AM »
oh yeah,
That's a great video. Same for k75.
i-man
« Reply #3 on: September 22, 2014, 10:41:01 AM »
Seems the same to me as well, from what I've read. So why is Chris so emphatic that it's not the same for the k75???
« Reply #4 on: September 22, 2014, 11:16:40 AM »
... but he says that it's not for the K75.
Where does he say it's no good for K75's?
i-man
« Reply #5 on: September 22, 2014, 12:33:45 PM »
in the comments section, on the youtube page.
i-man
« Reply #6 on: September 22, 2014, 12:38:47 PM »
Actually it says
PLEASE SEE AMENDMENT: This procedure is NOT for the K75 models. I will show how to adjust the K75 clutch in an upcoming video. I am sorry for any confusion. Happy 2014, Chris
Video Description: How to adjust the clutch on a BMW K100, K1 or K1100.
right below the video.
« Reply #7 on: September 22, 2014, 01:11:25 PM »
AFAIK the only difference between K75's and others is the dead travel on the handlebar lever.
K75's 2mm, all others 4mm.
i-man
« Reply #8 on: September 22, 2014, 02:16:30 PM »
Good to know. If anyone else wants to second that notion, please don't hold back.
i-man
« Reply #9 on: September 22, 2014, 07:48:16 PM »
I was thinking. the 'free play' part of the cable adjustment is sometimes a matter of personal choice on japanese bikes. Is it different for bmw'S? i could see how you need some free play as to not burn your clutch out, but does it matter how much free play the clutch has after that? does it matter that you 'should' have 2mm on the k75, but you put in 4mm of free play?
Offline ReneZ
« Reply #10 on: September 28, 2014, 04:03:09 PM »
Not really (in my view). Only difference between the K100 and the K75, as far as the clutch is concerned, is that the clutch parts themselves slightly different are (spring disk etc) and that the clutch push rod is slightly different (can't be removed from the rear of the gearbox), but I see that clearance more as an operational thing than absolute science. However, you need to realize that a wearing/worn down clutch will reduce the clearance, so if it was OK first and you don't have clearance now it's time to have a look at your friction disk.
Greetings, Rene
BMW K100 - 1984
BMW K1200GT - 2003
