Author Topic: Those that have tip over bars...  (Read 5003 times)
Offline richarddacat
« on: September 20, 2014, 12:48:08 PM »
/crashbars.....on a K75.
The top bolt that replaces the frame to engine mount bolt, numbers 24 and 28 http://www.bikebandit.com/1988-bmw-k75c/o/m89#sch345053. I'm assuming the shorter bolt is on the clutch side and the longer one is on the throttle side.
I'm putting on a set without instructions and I don't have part list #64. IS this a solid spacer about an 1.25" long?
 Thx  :2thumbup:
Offline Bokobob
  • I am a 1936 Model
Re: Those that have tip over bars...
« Reply #1 on: September 20, 2014, 01:05:23 PM »
24 is throttle side...
  • Gastonia, NC
Grace + Peace,
Bob
1995 BMW K75
1994 Honda Magna 750 V4
1996 Kawasaki Vulcan 500
« Reply #2 on: September 20, 2014, 03:09:56 PM »
 :fall down: the diagram shows 24 the clutch side. Why do you say its for the throttle side? The shorter bolt installs fine on the clutch side.
And, #64 looks to be a spacer, steel I presume, just wanted to confirm or just make my own spacer.
« Reply #3 on: September 20, 2014, 03:19:09 PM »
According to the diagrams at Max, both bolts have the same length and no spacer.
Exept RT which have the spacer mounted together with a longer bolt on the throttle side.
« Reply #4 on: September 21, 2014, 12:53:36 AM »
Hmmm, thanks. Maybe I have an RT set, once again assuming that there are two styles.
« Reply #5 on: September 21, 2014, 06:31:40 AM »
RT's have different bars than other K75's, and it also was a change in -92 on the RT's.
The part number should be stamped on the bars lower end.
« Reply #6 on: September 21, 2014, 10:51:28 AM »
Makes sense.
Found this nugget of information.
the K75RT crash bars are NOT the same as K75 crash bars. The K75 bars bolt (via rubber-mounted studs) to the engine. The K75RT bars do NOT bolt to the engine at the top; they bolt to a bracket which, in turn, bolts to the engine. They fit through the vent in the fairing lower; no cutting is necessary.
