Author Topic: Gear oil tool  (Read 7125 times)
Offline Texbid
Gear oil tool
« on: August 03, 2014, 01:25:12 PM »
Changed my gear oil today. Made a tool based on instructions and just wanted to share the photos. The wire is standard household Romex. Long end that goes into the gearbox is 115mm long.  Works a charm
Re: Gear oil tool
« Reply #1 on: August 03, 2014, 03:19:14 PM »
Ad 10 mm.....then you also have the low level mark, and not only the high level mark...easier to check.
Offline Texbid
Re: Gear oil tool
« Reply #2 on: August 05, 2014, 07:00:04 AM »
good idea.  Ill make anoterh one, and strip the wire so its copper for the low  level.
Offline richarddacat
Re: Gear oil tool
« Reply #3 on: August 05, 2014, 08:53:51 AM »
Factory tool kit that includes the rear shock preload wrench doubles as a gear box dip stick.
But looks like a good solution, if you're missing this tool.
Re: Gear oil tool
« Reply #4 on: August 05, 2014, 09:06:39 AM »
Not on a K11 (as Texbid have)...........it's a piece of sheet metal, bent in the shape as above.
Re: Gear oil tool
« Reply #5 on: August 05, 2014, 10:23:55 AM »
Noted, I'll keep that in mind,
Offline Texbid
Re: Gear oil tool
« Reply #6 on: August 09, 2014, 06:40:50 PM »
Update model
Re: Gear oil tool
« Reply #7 on: August 09, 2014, 07:28:41 PM »
Good for testing for contaminated alien blood too.
