Author Topic: Odometer  (Read 11392 times)
Offline Justdirt
Odometer
« on: July 09, 2014, 10:38:00 AM »
On my 1994 K75, the speedometer and the tachometer works correctly, but the odometer and the trip meter is not turning during driving.  The reset knob is working correctly.  Could a wire be unplugged?  Possible fix?  I had the instrument panel rebuilt last year with new plastic numbers.  Any help will be appreciated.
Re: Odometer
« Reply #1 on: July 09, 2014, 11:02:32 AM »
greetings justdirt...
welcome to motobrick.com...
thats whack... your new numbers not turning...
Offline koapono
Re: Odometer
« Reply #2 on: July 09, 2014, 11:40:17 AM »
speedo and tach work off electric signal.
odometer and trip meter are driven by plastic gears, an electric signal does cause the main shaft/gear cog to turn and that may have been damaged when numbers were replaced. link below, hi-jacked from liberry, shows various gear trains used.
reckon you'll have to disassemble instrument cluster and check wires/pin connectors and gear assembly.
tedious but after you've done it a few times it's like changing a light bulb!
g'luck
http://www.odometergears.com/products/BMW/R+%26+K+Motorcycles/42
  • 1994 K1100LT
Offline Justdirt
Re: Odometer
« Reply #3 on: July 09, 2014, 01:17:20 PM »
g'luck
Thank you for the information and the link. :bmwsmile
Re: Odometer
« Reply #4 on: July 09, 2014, 02:00:16 PM »
If it was rebuilt, whoever rebuilt it should fix this. I would assume they put the new gears in, or at least should have if they were either seemingly worn or soft. It's not too hard to replace them though.
Offline Justdirt
Re: Odometer
« Reply #5 on: July 10, 2014, 05:36:45 PM »
  I would appreciate any information on how to remove the Instrument Cluster off of the 1994 K75.  I will deliver to a speedometer shop for repair.  :bmwsmile
Offline Elipten
Re: Odometer
« Reply #6 on: July 10, 2014, 06:50:44 PM »
Look for my recent post on the repair shop in Austin that does this work
  • San Antonio, TX
  • 1990 K75RT
Offline Justdirt
Re: Odometer
« Reply #7 on: July 10, 2014, 07:17:30 PM »
I looked up the post and I thank you for the information. :bmwsmile
Offline Elipten
Re: Odometer
« Reply #8 on: July 10, 2014, 07:18:45 PM »
Welcome use my name when contacting.  He is good.
  • San Antonio, TX
  • 1990 K75RT
Offline Justdirt
Re: Odometer
« Reply #9 on: July 10, 2014, 07:26:44 PM »
Do you know of an "WWW Link" or You Tube Video on how to remove the Instrument Cluster from a 1994 K75?
Offline Elipten
Odometer
« Reply #10 on: July 10, 2014, 08:17:03 PM »
Not much to it but no doubt varies by model.  I can only speak for a 1990 K75RT.  What year and model do you have?
  • San Antonio, TX
  • 1990 K75RT
Offline Justdirt
Re: Odometer
« Reply #11 on: July 10, 2014, 09:05:11 PM »
I have the 1994 K75 basic version; no abs; no fairing; mine is red;  it is identical to the photo on the specs page for this web site.
Offline Elipten
Re: Odometer
« Reply #12 on: July 10, 2014, 09:35:18 PM »
Anybody help Justdirt?
  • San Antonio, TX
  • 1990 K75RT
Re: Odometer
« Reply #13 on: July 10, 2014, 09:51:29 PM »
Removing them is pretty easy if there isn't a fairing. Remove the headlight bucket/assembly. Remove the cover for the wires (1 screw) and unplug the unit. There should be 4 bolts/screws holding the gauges on. That's all there is to it.
Offline Justdirt
Re: Odometer
« Reply #14 on: July 10, 2014, 10:02:57 PM »
Many Thanks, I am heading into the garage to begin removal.  Have a great Weekend.
Offline Justdirt
Re: Odometer
« Reply #15 on: July 10, 2014, 10:46:05 PM »
Removal of Instrument Cluster completed.  Thank you very much for your assistance. :bmwsmile
