Author Topic: What Did You Did To Your Motobrick Today ?  (Read 2999239 times)
« Reply #2525 on: March 05, 2017, 11:20:56 AM »
If you take just the wheels...be sure you have the orientation correct in your mind :bmwsmile .  Took mine to a BMW "professional", and the front tire got mounted wrong(directional arrow on tire going backwards).  Irony is that there were other k-bikes in the shop at the time so tech should have been able to look for correct orientation... :dunno
Good point.  I have installed a tire backwards because I had the 4 spoke front wheel upside down.  Now, I make a small arrowhead on the rim near the valve stem pointing in the rotation direction with a sharpie pen BEFORE I take the wheel off the bike.  When I'm done, a quick wipe with some acetone on a paper towel takes the mark right off.
I don't trust my brain to be able to keep things straight anymore.
Offline Bill
« Reply #2526 on: March 05, 2017, 11:25:56 AM »
Sig[size=78%]n of a life well lived is a twisted mind .......[/size] :curvy-road
  • Sutton, Ontario, Canada
  • K100 LT
Current:  88 K100 LT
86 K100 R-?L?T parts collection in loose formation...
previous:
84 V45 Sabre
74 CB400
72 CB750
Offline TrueAce
« Reply #2527 on: March 05, 2017, 11:31:41 AM »
Hmmmmm........made me check the tires on the scrambler ( recently mounted). The front tire arrow is pointed the wrong way, on a semi-knobby tire. Pray tell, what difference does it make......the tread is so uni-directional it doesn't appear different. :dunno2:
  • Florida
« Reply #2528 on: March 05, 2017, 11:36:10 AM »
It makes your odometer run backwards which messes up all your fuel economy and maintenance interval calculations.  If you reach high enough speeds you could actually be going back in time without even exceeding the speed of light.
« Reply #2529 on: March 05, 2017, 01:16:38 PM »
yes, whether someone else does it or you do it...triple check the orientation!
i had mine done at Morton's BMW.  even though the service manager had a K75S and there were a couple K's in the shop, i still checked orientation on the tires before i carried the wheels out....
« Reply #2530 on: March 05, 2017, 01:29:52 PM »
I didn't notice my F-up until the ABS light informed me that the ABS ring was on the wrong side.  DOH!! :mbird
« Reply #2531 on: March 05, 2017, 01:40:32 PM »
LOL!!!   classic.
Offline TrueAce
« Reply #2532 on: March 05, 2017, 02:01:45 PM »
Since the scrambler has no speedometer, it may have taken a while before I realized the mounting error. Just so the mismatch in direction doesnt cause the front and rear to seize up.
  • Florida
Offline jakgieger
  • itinerant farmer
« Reply #2533 on: March 05, 2017, 05:30:51 PM »
Maybe a little a-retentive here :hehehe , but if the manufacturer put an arrow, maybe we should follow it??  Lots of web info on the rubber splice, tread pattern, water dispersion characteristics, etc.  Long story short, better to follow the arrow!
  • Kansas USA
  • 1989 K100rs se
« Reply #2534 on: March 05, 2017, 06:23:42 PM »
a front tire mounted backwards on a non-abs bike can simply be turned around without dismounting the tire.  btdt.
« Reply #2535 on: March 05, 2017, 07:11:39 PM »
They may swap ends though, so mark one of the tires using a paintball gun then take a picture so you can show the outcome to your fellow parishioners at the spring picnic, Brother Ace.
Offline milq
« Reply #2536 on: March 05, 2017, 07:14:01 PM »
Since I have the shock off already, decided to check the splines and flush rear brakes.
Happy to say the 16 spline shaft still looks in very good shape and wasn't dry, although it was close.
Seems like my rear brake pedal has a lot of travel (as it did prior to flushing and bleeding). The caliper is clamping down, just seems like a lot of movement before it does. Is that pretty common? My KTM has very touchy brakes, so maybe it's just different.
  • Southern IL
  • 1988 K75S
Offline mobydick
« Reply #2537 on: March 05, 2017, 08:22:07 PM »
Welded in a new  drive shaft spline section on my 87 K75C.  Now I can pull the transmission out and grease all the splines ready for my May/June  X Canada 150 cruise.
The PMW controllers for my heated jacket and pants arrived today,but still waiting on the silicon wire(china) and carbon heater strips(russia).  The (chinese) microphone board and amplifier  for my garmin nuvi GPS should be here in a month.   Also the USB and 12 V power ports are coming shortly.
Phew that's a mouthful.  Good start in a shi#@y winter.
MD
  • coquitlam bc canada
  • 1987 K75c 57k miles ex Burbank, 2001 K1200RS
Offline White Dog
« Reply #2538 on: March 07, 2017, 07:46:06 PM »
Got my K75 running!  Fix was to bend the female sockets on the 4 pin fuel pump plug so that the male pins from the tank would fit snugly.  Engine fired right up.  This is a known problem with the older cycles but I didn't know it until it bit me.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
'96 R1100RT Burnt Orange
2008 Goldwing Black
2014 CB1100 Std. Black
Reside in NC
Offline Filmcamera
« Reply #2539 on: March 07, 2017, 08:00:25 PM »
Way to go Whitedog, always nice to hear a success story
I installed a super bright LED headlight today to match my super bright LED driving/fog lights.  No one will ever be able to use the 'sorry I didn't see you mate' excuse now!
  • San Jose, Costa Rica
Poserbricker
« Reply #2540 on: March 07, 2017, 08:04:11 PM »
No one will ever be able you say, "you're not too bright" either, hopefully. :giggles
Offline Filmcamera
« Reply #2541 on: March 07, 2017, 08:29:42 PM »
I have never been accused of that yet but there is always a first time  :2thumbup:
Poserbricker
« Reply #2542 on: March 07, 2017, 11:27:50 PM »
Is that an H-4 bulb replacement?   Any information you can share?
When you get a chance to run it at night you have to let us know how it works.  I use some of the stuff from Super Bright LED's and have found it to be pretty good.
Offline Filmcamera
« Reply #2543 on: March 08, 2017, 07:09:00 AM »
I git it from Amazon for $16.00. Installation was easy though it comes with no instructions.  The toughest choice was which way round to install it.  There are three LED's - two are lit when it is on low beam and the third one lights up as well when you switch to high beam.  There is enough room at the back to my RS headlight so installation isn't any issue. though I did have to cut the rubber boot since the bulb comes with a fan and enclosing that behind the rubber boot didn't seem like a good idea.
Here is a link to the bulb
https://www.amazon.com/gp/product/B011NGEN3E/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Poserbricker
« Reply #2544 on: March 08, 2017, 08:41:25 AM »
I have been using halogen bulbs in my bikes, and so far have had to replace 2 of them.   Don't know if the problem is that I am not buying the $20 bulbs or some of the crap roads I commute on.
Been looking at LED replacements, but I do a lot of riding at night in deer country and I have heard that the LED lights while super bright don't have good patterns with the OEM headlight.  I want to be able to see down the road, but don't want other drivers flashing at me all the time either.  My LED driving lights are TOO BRIGHT at night.  The light up road signs so much that they blind me to anything beyond them.  Very scary in some of the places where I know the damn deer hang around the side of the road.
Very interested in how Filmcamera's new headlight works in the dark.
Offline Filmcamera
« Reply #2545 on: March 08, 2017, 09:08:58 AM »
I know what you mean about the driving lights.  Mine came with one fog and one spot, I am actually thinking of splitting them onto separate switches so I can turn them on and off independently at night.
I will let you know how the main headlight is at night - at least as soon as I can solve my front brake issues and actually ride again!
Poserbricker
« Reply #2546 on: March 08, 2017, 09:20:01 AM »
Please post a few photos of the high and low beam pattern down your driveway or a road, just to give us an idea of its effect.
Offline Filmcamera
« Reply #2547 on: March 08, 2017, 09:24:24 AM »
No problem, I will take some this evening, I was actually planning on experimenting on the positioning of the three LED's anyway.  Right now I have the two low beam ones at the bottom and the high beam at the top, I thinking I might try switching that around to see what gives me the best throw with the high beam active, as mentioned the bulb didn't come with any instructions so trial and error is the way to go.
Poserbricker
Offline Filmcamera
« Reply #2548 on: March 08, 2017, 09:47:33 AM »
Agreed.
However I mainly ride during the day so the bright lights are as much about being seen as seeing at night. I looked at Catz but at close to $300 as compared to less than $50 for the LED's driving lights and headlight I thought it was worth going the LED route to start with.
I am in Costa Rica - a small fairly densely populated country (at least where I live), I do not have endless unlit roads with deers to worry about, thankfully.
Cheesconsin is over three times the size of CR with a  population of 5.75 million as compared to 4.8 million in CR.
Poserbricker
Offline Filmcamera
« Reply #2549 on: March 08, 2017, 09:56:00 PM »
Some photos of the lights
Pic 1 just headlight
Pic 2 headlight on high beam
Pic 3 headlight plus driving lights.
I think I have the orientation of the LED wrong, switching on main beam seems to fill in underneath the light that was already there...
All photos taken at about 25 feet from the Suzuki.  Also think I need to point the driving lights a little higher...
Poserbricker
