Author Topic: What Did You Did To Your Motobrick Today ?  (Read 3596607 times)
Offline Idonthaveaclue
  • Veni, vidi, vici
« Reply #2475 on: February 11, 2017, 05:49:57 PM »
I "installed" my new tank bag ($79 from Cycle Gear) and rode it the furthest yet. 250 miles!
  • Queen Creek, AZ
  • 87' K75S | 16' H-D Road Glide Special
1987 K75S
« Reply #2476 on: February 11, 2017, 09:51:20 PM »
Nice sign. I don't think I would have trouble with constipation if I came face to face with one of your bears.   :mbird   :hehehe
Regards Martin
Offline Vespa no more
« Reply #2477 on: February 12, 2017, 05:07:39 AM »
There is this perception (Europeans ... Pommies probably) of Australian wildlife that if it doesn't bite it stings.
Well, when camping in the Rockies and Canada, those nighttime noises can get concerning - especially in "Bear Country". I made sure that the food was locked up, we left no scraps and that the family were sure to spit toothpaste into the embers of the fire. With the rest of the family snoring contentedly and me awake listening to some (not too distant) noise, a summer tent (and denial) was all I had for protection.
Been phaffing around with project #2 ... no real joy yet...ie. ignition
Question time: Re K1100LT 1993.
1) Wait for it.... Not starting: battery (newish, 12.75V), fuses (checked and connections cleaned (not DEOXIT - some auto electrical connection cleaner), relays cleaned and checked (switch circuit clicking in each relay, and all make the horn work when substituted, good earth lead (cleaned), new plugs, injectors serviced. Can't hear the fuel pump whining - although removed this and checked with 12V (spun like it should). Now... when testing the fuel tank plug (4 wires: 2 to fuel level sender and two to fuel pump) am I sticking multimeter probes / pins into the plug to determine 12V at this point (to fuel pump can't remember the colours but do have the right ones) OR am I putting red probe into each (female) plug and black to earth on bike? Will ashamedly confess - bit of a novice with this elementary stuff. Question 2 below will reveal that I have the return fuel line (from pressure regulator) disconnected for now - but this should not be an issue I think.
2) replacing fuel line from fuel rail to fuel pressure regulator and then back to tank is errr... problematic. Before I try to start it up I want to flush bad fuel from all the lines. Obviously there is a bit more plumbing than on my K100RT 1984. Tried to remove the air filter assembly but top section is giving me the arse - the crankcase ventilation hose clamp (as it comes out of the top of the motor) is nigh on impossible to get to (even after I drilled a hole in the bottom of the relay box to get a screwdriver onto it. So learned friends... what's the trick? I want to get a dremel to the fuel hose clamps at the pressure regulator but can't create space by removing the air filter upper
3) Oh and another one... put 3.75 litres of engine oil (drained filter) in (as per Clymer) but no oil visible in the oil level glass on side of motor (bike on flat surface). This is an ex-police bike. I could keep adding more but wanted to check if something could be blocking the oil rising or if police bikes might have bigger sumps??
Thanks for any help
Regards
Guy
  • Wollongong NSW AUSTRALIA
Offline Scud
« Reply #2478 on: February 12, 2017, 08:52:12 AM »
Do bears get constipated in the woods?
If they take Bearlax, can they shit a brick?
  • Carlsbad, CA
Offline jakgieger
  • itinerant farmer
« Reply #2479 on: February 12, 2017, 08:58:40 AM »
Guy, show us a picture of the 1100 police machine!
  • Kansas USA
  • 1989 K100rs se
  • Veni, vidi, vici
« Reply #2480 on: February 12, 2017, 09:03:00 AM »
Hey Martin - pretty sure everything down your way is trying to kill you. Snakes, spiders, and kamikaze Kangaroos!
These are the important questions we need to be asking!  :bmwsmile [size=78%] [/size]
  • Queen Creek, AZ
1987 K75S
Offline DavidATL
« Reply #2481 on: February 12, 2017, 10:21:00 AM »
Motolax would work better
  • Atlanta
« Reply #2482 on: February 12, 2017, 02:46:46 PM »
Idonthaveaclue you forgot the sharks, crocs, sea snakes, jelly fish, cone shells, stone fish, blue ringed octopi, emus, cassowaries, stoned zombie  koalas but I do feel safe.  :hehehe
« Reply #2483 on: February 12, 2017, 03:53:58 PM »
Replaced the $255 POS BMW master cylinder with a $9 one that works a helluva lot better. :riding:
Offline RobP
« Reply #2484 on: February 14, 2017, 09:18:33 AM »
Quote
What master did you use?  Is there a related thread to this?
  • Driftwood, TX
  • 1985 K100RS
Offline Snowman
  • Aberdeen SD.
« Reply #2485 on: February 14, 2017, 09:54:28 AM »
Started rebuilding the front end. Sending the forks off to RaceTech in Corona CA for new springs, gold valve emulators, seals, bushings etc. I've done the seals and bushings myself in the past but they are due for a complete re-do. While they are away I'll be doing wheel bearings and brakes.
« Reply #2486 on: February 14, 2017, 10:10:03 AM »
He is replacing the OEM rear master cylinder. His description of the process is embedded within another thread. His descriptive posts start here.
Offline RobP
« Reply #2487 on: February 14, 2017, 11:39:25 AM »
OK my brain cramp.  I equated master = front.
  • Driftwood, TX
  • 1985 K100RS
« Reply #2488 on: February 16, 2017, 03:47:53 PM »
Finished the last winter job today when I replaced the disintegrating under windshield trim, added a fuel gauge, and installed a switch and LED in my heated jacket controller.
Three pages of maintenance, repair, and upgrades on three bikes done!  All I need now is some salt free highway.
Offline Snowman
  • Aberdeen SD.
« Reply #2489 on: February 17, 2017, 03:42:31 PM »
My new rear Ram Shox for my K1100LT just arrived from Realm Engineering in the UK. Great people to work with, $325, included shipping to my door in S.Dakota. Custom built for my weight and riding style and fully rebuildable, quality is on par with Ohlins except $700 less. :eek:
I have had their suspension on my hill climb car for 10 years. http://www.ramshox.com/
« Reply #2490 on: February 17, 2017, 04:33:04 PM »
That's a great price, wish I knew of those before I bought a Progressive
Offline Snowman
  • Aberdeen SD.
« Reply #2491 on: February 17, 2017, 04:56:04 PM »
With the British pound taking a dump against the dollar it makes shopping in the UK better than ever.
« Reply #2492 on: February 17, 2017, 07:07:31 PM »
looks like you have the same garmin car gps i do.  what mount did you use?
« Reply #2493 on: February 17, 2017, 08:58:52 PM »
I make my own mounts for my Garmin Nuvi 40's.
I start with one of those $2 mounts from eBay and cut off the ball and about a half inch of the arm it mounts to.
I drill a hole in the arm to take a sheet metal screw.
For the RT I heat up and wrap a piece of ABS sheet around the crossbar and screw the ball to it.
For my K75S I bent a strip of aluminum, screwed it to the handlebar switch pad and attached the ball to that.  I have attached a photo that should give you an idea of how I did it on the S.  As you can see I have to flip the GPS up to use the switches.  The position of the GPS is such it does not block the speedo cluster.
« Reply #2494 on: February 24, 2017, 01:24:17 PM »
A little bit of gloating today.
Just put my Bun Burner Gold tag on Ilsa's license plate.   Not too bad for a geezer on an old bike.
Also noticed that the logo for the BBG has a K1100RS on the artwork.
Offline Scud
« Reply #2495 on: February 24, 2017, 02:07:49 PM »
Holy crap... that's over 60MPH average if you're going non-stop for 24 hours - and you gotta make a few stops to fill some things and empty others.
Where and how do you knock off that kind of mileage?
  • Carlsbad, CA
« Reply #2496 on: February 24, 2017, 02:43:37 PM »
Fort Collins, CO to Buffalo, NY.  I-80 to I-90 super slab.  75 to 85+ mph when I can get away with it.  5 minute gas stops, one 30 minute  stop for a meal and coffee in Ohio.  1544 miles in 23:40.  Rained all the way across Nebraska and most of Iowa.  RT fairing is sweet!
When I say these bikes like to fly I know of what I speak.   Tim Tyler knows too.  The K75 is a beautiful slab machine as well as nice in the twisties.
Offline Scud
« Reply #2497 on: February 24, 2017, 02:57:21 PM »
Cool - and congratulations. My K75s is quite happy in the  ...+MPH range on the slab.
For me, I usually look for the twistiest route between two points.  :curvy-road
But CO to NY in a day??? That's freakin' amazing...  :mbird
  • Carlsbad, CA
Offline Elipten
« Reply #2498 on: February 24, 2017, 03:05:34 PM »
I would need a catheter!  Gas in 5 minutes, drinks and bathroom.  Most impressive!  I would put a long range tank on the bike, camel back drink bag.
  • San Antonio, TX
  • 1990 K75RT
« Reply #2499 on: February 24, 2017, 05:37:26 PM »
I avoid anything(especially coffee) but water in small amounts.  Can do about three tanks before I have to stop for the bladder drain.   Did a large coffee about 2am when I had 4 hours to go.
By drinking minimal coffee in the weeks before, that coffee hits like a ton of bricks.
