Author Topic: What Did You Did To Your Motobrick Today ?  (Read 3219862 times)
Offline Scud
« Reply #2500 on: February 24, 2017, 06:21:26 PM »
By drinking minimal coffee in the weeks before, that coffee hits like a ton of bricks.
,,,or 3/4 ton of bricks in the case of the K75.  :hehehe
  • Carlsbad, CA
« Reply #2501 on: February 24, 2017, 06:31:51 PM »
 :clap:
Offline White Dog
« Reply #2502 on: February 24, 2017, 06:58:25 PM »
Bladders come in different sizes, thus the capacity of each is different.  I got the extra small (not by choice).  You must have the 4XL.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
'96 R1100RT Burnt Orange
2008 Goldwing Black
2014 CB1100 Std. Black
Reside in NC
« Reply #2503 on: February 24, 2017, 08:16:40 PM »
I stand corrected.
Offline jaxon
« Reply #2504 on: February 24, 2017, 08:42:41 PM »
I rode'd it. Turned it off and had to push start it. Seems I have a sprag clutch issue. Whines, doesn't start. Seems to work intermittently. I'm off to getting some CD2 oil detergent.
Bummer.
  • Indiana
  • '92 K75S, '17 R1200GS LC
This space for rent
« Reply #2505 on: February 24, 2017, 09:30:56 PM »
Keep after it with the treatment. It might take multiple treatments. Plenty of successful reports using the high detergent oil method.
In the meantime, starting it with a running jumpstart can build endurance and coordination so it's not all bad. Good luck!
« Reply #2506 on: February 24, 2017, 09:58:56 PM »
I don't know about CD2.  I used a full can of Seafoam in my engine with a gallon of cheap SAE30 and a fresh filter.  Ran about 25-30 miles and did a full oil change and filter, refilling with Rotella T6 synthetic 10W40.
The Seafoam has pretty strong cleaning solvents in it, and the Rotella is formulated for heavy duty diesels which generate a lot of crap in the oil.  Engine and starter have worked flawlessly now for over 6,000 miles.
« Reply #2507 on: February 24, 2017, 10:19:26 PM »
Bummer.
I run some Rinsoline once a decade or so, never had a sprag clutch issue but if I do might try this.  From a previous post here, drill hole in case and lube it directly, cover hole with rubber plug. Take precaution for chips getting in there but aluminum is soft so a little might not be fatal.
Offline Supershooter
« Reply #2508 on: February 26, 2017, 04:37:13 PM »
Reassembled the valve cover, last time I reassembled it leaked, keeping fingers crossed this time.
Supershooter
  • 85 K100 RT
Offline White Dog
« Reply #2509 on: February 26, 2017, 07:03:14 PM »
Fuel Sender Unit.  Several hours yesterday, same for today.  Removed, disassembled, cleaned, adjusted the wiper arms and reinstalled.  Still no fuel warning light.  Yes, I pulled the instrument cluster, pulled and checked resistance on the bulb and it is good.  The only thing I haven't been able to figure out is how to test continuity of the wiring from the plug at the back of the gas tank to wherever those 4 wires go to the front.  The Clymer repair manual shows the wiring for a K75RT which has a gas gauge in addition to low fuel light.  K75 only has low fuel light so the wiring schematic was hard for me to follow.  I had an "early on" light and adjusted the gear wheel on the underside of the sending unit.  Then, I lost the light altogether.  I have decided that I'll forget about the fuel warning light and rely on the odo, as I know about how many miles I can go before sweat pops out on my forward and I am in panic mode looking for a 100% gas station.
I followed the excellent write up done by poster robmack back in 2014 on the K100 forum as my guide for bench testing.
  • Basement Garage
  • '95 K75 ABS.
'95 K75 ABS Red
2008 Goldwing Black
Reside in NC
Offline Vespa no more
« Reply #2510 on: March 03, 2017, 06:45:09 AM »
Nothing
Have been distracted on a car I bought for my daughter for $450 ... Rover 75 Connoisseur...$60,000 when released 14years ago. It's so british - too british with all it's lothario faux-walnut dash.
It depreciated like the K1100LT ($21000 new) bought for $500
Am about to replace all the throttle body rubbers (top and bottom) on K100 '84.. to cure the vibrations and possible air leaks.
But one last ride
  • Wollongong NSW AUSTRALIA
Offline Elipten
« Reply #2511 on: March 03, 2017, 07:58:36 AM »
That is a heck of a lot of depreciation.  But that interesting leather color could be part of the issue.  Here in the States a 16 year old Camry with 200,000 miles goes for $2,500-5,000.  I've been looking as I have a son about to start drivers training. Therefore I need a learner car to potentially be sacrificial.
I can't find a single K75 for less than $3,000.
  • San Antonio, TX
  • 1990 K75RT
« Reply #2512 on: March 03, 2017, 08:48:41 AM »
So this is degenerating into a "wheels for my kid" thread?  My daughter is off to college next fall, still needs to get more proficient with my 01 Jetta's stickshift.  They grew up together ....
Offline bocutter Ed
« Reply #2513 on: March 03, 2017, 08:56:00 AM »
Interesting ... I would have expected RHD.
  • Toronto, Canada
Offline Filmcamera
« Reply #2514 on: March 03, 2017, 09:28:47 AM »
Sore point for me - a couple of months ago I let my son, 19 and recently passed his test, borrow my other toy - a 1987 Suzuki Samurai which has been fairly heavily modified for off road use - the results were somewhat catastrophic, at least for the other guy
  • San Jose, Costa Rica
Poserbricker
Offline bocutter Ed
« Reply #2515 on: March 03, 2017, 09:53:32 AM »
... my other toy ...
Needs a Tonka decal ...  :yes
  • Toronto, Canada
Offline cycle thread
« Reply #2516 on: March 03, 2017, 06:39:14 PM »
I finished wet sanding the fuel tank and the radiator cowling, think my fingerprints are now a bit fainter.......
John
  • Somerset United Kingdom
  • 1989 K75 Low Seat
« Reply #2517 on: March 04, 2017, 06:06:14 PM »
got new tires....mich activs
replaced all three rotors with EBC's and pads with EBC HH sintered.
still waiting on the rebuilt pinion for the FD before back on the road.
Offline kmev
« Reply #2518 on: March 04, 2017, 08:37:05 PM »
I like those tires.
  • Madison, Wisconsin
  • 1994 K75s
« Reply #2519 on: March 04, 2017, 09:31:39 PM »
Just the other day my wife and I drove by the office park where I taught my stepdaughter to drive a stick. Good times . . .
« Reply #2520 on: March 05, 2017, 07:23:10 AM »
Those dry, clear days are hellish for traction control—at least for some drivers.  :giggles
« Reply #2521 on: March 05, 2017, 10:25:36 AM »
Removed the wheels, trying to decide where to take them for tire replacement. Our local car mechanic said they put a few mc tires on each year. I'm just wondering if I'm farther ahead to take them to a mc shop ro have them mounted and balanced? Thoughts?
Supershooter
  • 85 K100 RT
Offline jakgieger
  • itinerant farmer
« Reply #2522 on: March 05, 2017, 11:00:05 AM »
If you take just the wheels...be sure you have the orientation correct in your mind :bmwsmile .  Took mine to a BMW "professional", and the front tire got mounted wrong(directional arrow on tire going backwards).  Irony is that there were other k-bikes in the shop at the time so tech should have been able to look for correct orientation... :dunno
  • Kansas USA
  • 1989 K100rs se
« Reply #2523 on: March 05, 2017, 11:12:39 AM »
I change my own tires.  Comes from my old days racing dirt bikes.  Takes about $100 in tools to do the BMW wheels because of the special balancer adapter for the rear wheel .  I can do both wheels in under two hours once they're off the bike.  Could do it faster, but I am obsessive about balancing.  The actual tire change takes about 15 minutes per wheel.
If you have a shop do it, DON'T buy your tires on line.  My experience is that if you buy the tire from them and bring the wheel to mount it, they'll usually do it for free or just a couple bucks.  Bring in your own tire and you'll be paying their minimum shop fee which is usually 1/2 hour at $85-100/hour per wheel.
Offline mw074
« Reply #2524 on: March 05, 2017, 11:20:36 AM »
I do my own as well. Low quality, wheel scratches, and high prices locally. I use a Nomar tire machine and wheel balancer. Good equipment but expensive.
  • Michigan
