Author Topic: What Did You Did To Your Motobrick Today ?  (Read 3442933 times)
Offline drut
« Reply #1100 on: April 16, 2014, 03:19:40 PM »
Had a slight weep from n/s/f caliper so fitted new seal kit & bled brakes,first time I have used my new lift.It certainly makes working on the bike much easier although I was a bit nervous loading it on to the lift.
  • Newcastle upon Tyne UK
Offline F14CRAZY
« Reply #1101 on: April 16, 2014, 10:03:07 PM »
aw man those K100RS' in white with blue...timeless bike right there
  • Grand Rapids, MI
  • '87 K75C
Offline roninvt
  • free range, cage free
« Reply #1102 on: April 18, 2014, 10:29:14 PM »
Drained gearbox and final drive and filled them with hypoid 75w90. lubed final drive spline with Guard Dog moly....good for another 10k miles!!  :bmwsmile
1990 K75C
1993 K1100RS
Offline F14CRAZY
« Reply #1103 on: April 19, 2014, 07:11:18 PM »
I gave it a good wash for the first time today. I used some Purple Power to do a little de-greasing (fortunately no active leaks, except for my Progressive rear shock that began to weep this week). I would not suggest using it on bare aluminum because it seems to be slightly corrosive after a few minutes...not like it was burning a hole in it but left it looking a little different (wasn't a disaster or anything on the bike  :2thumbup:)
Previous owner cracked the fairing and its got a rear drum but hey I still love this view on K's. Anyone else notice how a Monolever with a drum brake looks like a Paralever?
  • Grand Rapids, MI
  • '87 K75C
« Reply #1104 on: April 19, 2014, 09:01:38 PM »
Well today was service day.
Both bikes, coolant, oils, and a battery in the '95.
Tomorrow comes the brake fluid flush.
Spent more time trying to reset my fuel+ system only to find a broken wire at the battery connection, and created an abs fault in the process...... more time to diagnose and reset.
Done for tonight. Time for some M*A*S*H and a beer or 2. :2thumbup:
1995 K1100LT 0302044 (R.I.P)
« Reply #1105 on: April 20, 2014, 11:45:30 PM »
new front brake line, bypassing the non-working ABS pump.
I was hoping for a blue a little closer to my bike's blue, but oh well...
Offline vintagemilano
« Reply #1106 on: April 24, 2014, 06:29:53 PM »
Had a few moments of free time so finally got around to changing my frayed clutch cable and installed the headlight relay kit. Interestingly there is not a single instruction anywhere about changing the clutch cable in Haynes or BMW, just how to check and adjust.
  • Cranbrook, BC, Canada
  • 1990 K75RT
Non bricks include
06 Yamaha FZ6
1996 Yamaha xt225
1993 Suzuki GSF400
Offline Zipster
« Reply #1107 on: April 25, 2014, 07:12:34 PM »
Today I did a strip down, clean up and rebuild of my front master cylinder after finding some fluid had wept out of the rubber seal. There were loads of crystal deposits around there so it must have been leaking for a while. All seems good now though.
I also created a new phone mount by adapting a mirror mount 1" ball and bolting it to the dash. Now my phone which is also my sat nav is in a better position.
  • Northern Ireland
  • 1996 K1100 LT SE - sold with 104,500 miles in 2015; 2001 R1150RT - 68,000 miles; 2013 Triumph Trophy SE - 50,000 miles; 2007 Harley Ultra Classic - 50,000 miles (Canada bike for stateside use only)
Add life to your days, not days to your life!
Offline Zipster
« Reply #1108 on: April 26, 2014, 01:22:21 PM »
Looks like I'm gonna need to investigate my master cylinder further as I'm still getting brake fluid leaking. On the plus side, the phone mount is just about perfect!
  • Northern Ireland
Offline drut
« Reply #1109 on: April 26, 2014, 01:30:56 PM »
I fitted a seal kit to my master cylinder(Magura 20mm) but still leaked slightly,ended up fitting new cylinder.
Offline voodooskin
  • gone: 1997 K1100LT
« Reply #1110 on: April 28, 2014, 01:18:10 AM »
Replaced the battery, which was starting to give me the 'ol ABS  :nono on most startups, with an Odyssey PC680
  • Oregon
1997 K1100LT 49K miles
Offline Zampano
« Reply #1111 on: April 28, 2014, 10:57:05 PM »
Firstly, I want to thank you dudes for the advice/help.
Over the past few days I have managed to:
  • remove/clean tank
  • soak fuel pump and run submerged in a container of techron
  • install new damper & reinstall
  • change fuel / air filter
  • get injectors serviced by mr. injector and back on without incident
  • pull final drive and lube splines (couldn't get to front of driveshaft)
  • change final drive oil
  • change transmission oil
  • get new rear tire on.
  • drink innumerable $1.69 25 oz cans of Rolling Rock
Still need to get a hose on the fuel filter strainer. Two auto stores had no submersible hose, so any mice in the tank could be sucked up by the filter. Cest la vie. Could that affect how it runs? Does that upper aluminum tube do anything?
Also need to balance throttle bodies. Either with my homemade contraption or an actual carbtune esque device. Anyone in san diego with one? There are two bottles of green flash in it for you... (the other two are mine.)
Also need get the tire put on and balanced again; this time rotating in the right direction. I have had a front tire mounted incorrectly at the dealer and now my rear mounted backwards at another shop. And they come with arrows on them. Just goes to show you that whether you are in "the sticks" or a "nice city", there are folks everywhere who just want to finish the day and get home. You cannot assume a thing about any work except your own.
I have a strong feeling I will be changing the water/oil pump seal plus/minus the timing chain guides (i've been told these can be ignored but the rattling is driving me bonkers.) By the time that is fixed the tranny will give out or the rear seal will explode. In the meantime we keep on riding it.
thanks again for the help here!!
'92 K75S
Offline drut
« Reply #1112 on: April 29, 2014, 03:22:17 PM »
R/H fork seal blew,still not happy with front left hand brake caliper:it seems to have a slight weep between caliper halves so bike in bits again.I like working on bike well enough but today it was warm & sunny and I really would have liked to have gone for a ride but that's life.
Offline TaosBrick
  • RedHotMotoBricker
« Reply #1113 on: April 29, 2014, 09:10:45 PM »
Figgered I needed a prescription for Radials for my '92 K75, so I consulted with the Good DRxBMW, who happened to have a three-spoke rear wheel in his pharmacy. For a very reasonable price, the Good Doctor sent the wheel AND a nearly new Michelin Mac 50  :2thumbup:.
  So today I slapped that puppy on Chile Red. Tomorrow, I ride from Taos, NM to Nashville TN. And... some months from now I will mount me some Radials!
- Samurai Maxim
« Reply #1114 on: May 01, 2014, 01:57:25 AM »
Valve Check and Shim Adjustment
I noticed I was only getting about 38mpg on the Twisty Bovine ride....
Following up on this. I'm getting 44mpg now. Valves in spec is a good thing.
Offline F14CRAZY
« Reply #1115 on: May 03, 2014, 07:26:56 PM »
Changed engine oil/filter along with the trans and final drive. Previous owner gave me some Coastal synthetic blend 75w90 so I used that as the gear oil. He also gave me like 5 Bosch oil filters (seems he bought a Beemer Boneyard kit). I used that Bosch along with Valvoline 20w50 motorcycle oil. I know it's always up for debate but I felt it won't hurt to use "motorcycle" oil even if we have dry clutches and self contained transmissions. It's like $4.79/quart at Meijer so I don't feel like I'm wasting money on "motorcycle" oil
  • Grand Rapids, MI
  • '87 K75C
Offline roninvt
« Reply #1116 on: May 03, 2014, 10:28:21 PM »
Bought a 1993 K1100RS. Brother brought it to his place in Mebane NC.  So far I have installed gps, worked out some funky wiring chit, changed oil and filter, changed gearbox and final drive oil and topped off rear brake master...heading from Mebane to home in Vermont Sunday morning.   Pix of new bike to follow!!!
1990 K75C
1993 K1100RS
« Reply #1117 on: May 04, 2014, 01:01:08 AM »
rode it!
Offline Glacial
« Reply #1118 on: May 04, 2014, 05:49:15 PM »
Fitted a Givi rack in place of the OEM version.
  • Cambridge, UK
  • 1990 K75S VIN 0109678
« Reply #1119 on: May 04, 2014, 10:33:34 PM »
Rode the piss out of it, couldn't break it :eek:
Offline Zampano
« Reply #1120 on: May 05, 2014, 06:24:23 AM »
"hey, nice rack !!"  :2thumbup:
i attempted to adjust throttle bodies with my roman engineered makeshift sync tool. #3 was little high in vid. Eventually got them steady and even. Tach needle at idle much more steady. Engine sounds feels about the same.
http://www.youtube.com/embed/5fBoW3V1FDE
The tire change was biggest improvement yet. BT-45. Feels like a different bike. I should have dumped that balding one earlier but was being cheap.
1st/2nd shifting still dodgy. Some whirring that feels like it is originating in the tranny but who knows. Had a cali highway 2 a.m. ride and it was mostly solid at 80 mph (warp speed.)  Some vibration in footpegs. A little more on the right (could that be alternator bushings?)
2 cent = I think a better windscreen would top my list. Too much buffeting. Ducking under and the ride is a different feel altogether. Does the lip add-on raise the pocket enough? Not a lot of options for a K75s.
'92 K75S
Offline Motorhobo
  • +25 years of K75
« Reply #1121 on: May 05, 2014, 08:18:56 AM »
Put the transmission back on after spline lube. Put a new fan motor in the fan assembly. Rode the other K75 a couple hundred miles...heated grips switched off for a welcome change.
Love the Givi -- have it one on K75 and the OEM top case on the other one -- the OEM case is falling apart and doesn't fit much. Givi better but IMO doesn't look as good. Also -- dumbass installer drilled an extra hole in the cowl for the Givi -that's gonna be a PITA to fix and paint-match. So if anybody's considering a Givi -- measure twice drill once.
Offline Red
« Reply #1122 on: May 09, 2014, 03:28:54 AM »
Back in the latter part of March '14, I performed a spline lube and clutch replacement on my '97 K1100LT. At the time all went well , no leaks and I was pretty happy that I had gotten through my first spine lube job. Well, about 300 miles down the road I noticed that telltale oil drip coming off the bottom of the engine again ... but, this time, after I had settled down and really took a look at the oil drip, I thought that it must be oil coming from the transmission and not engine oil coming from my rear main seal. So I tore the bike apart again and sure enough the front of my transmission was all oiled up and that transmission oil had splashed all over the back side of my new clutch, (friction plates). I had to clean up the new clutch, replaced the friction plates, (thought about those oil resistant plates, but just did not have the additional monies to get them). Was deathly afraid of tearing into the transmission, but even though the manuals said to pop the lid, my transmission cover allowed me to pull the seals from the outside.  :bmwsmile   I also had a problem in that with this second teardown I cracked the plastic covers on the swingarm bearings .... I had an old spare swingarm available and utilized that when putting the bike back together. Plan is to replace the bearings in the original swingarm down the road.  :musicboohoo:  I've got about 100 miles on the LT so far, as a test, and no leaks. I plan to take off tomorrow, Friday, heading up into Northern California, to (Mt. Shasta, CA. USA). The overall trip should be around 800 miles. We shall see how well she holds up.  :mm
Bill
1997 K1100LT
1985 K100RS.
'94 YZ250 Yamaha - sold
Offline roninvt
« Reply #1123 on: May 10, 2014, 09:29:31 PM »
I put a set of Michelin Pilot Road 3s on my K1100 :yes
1990 K75C
1993 K1100RS
« Reply #1124 on: May 11, 2014, 06:52:09 PM »
Added some LED running lights per these instructions: http://classickbikes.com/ckb.tech/0.ckb.tech.files/auxled/auxled.htm
