Author Topic: What Did You Did To Your Motobrick Today ?  (Read 3587071 times)
« Reply #1050 on: January 29, 2014, 01:19:11 PM »
+1 on the Marc Parnes and good job on the DIY tire swap. You did more than I do. I take 'em to my car tire guy and he slaps them on, no charge. Then I balance....
Offline subforry
« Reply #1051 on: February 01, 2014, 09:46:37 PM »
Oil change and filter.  Pulled the plugs.  They were ok but I ordered some replacements.  Bosch XR7LDC from Summit Racing for $3.97 each, plus $4.95 shipping.  As usual on my K both were easy jobs.
  • Hermosa Beach, CA, USA
  • 1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
Offline Elipten
« Reply #1052 on: February 02, 2014, 01:24:00 AM »
Continued the rebuild of my 1990 K75RT.  Installed engine rear main seal, o-ring, and clutch.  Took out throttle bodies.  Waiting for parts, will send injectors out for cleaning.  However the tiny seal in the transmission for the clutch rod has beaten me.  I tried twice and failed so another seal on order and tranny will go to local dealer for seal install.  Driveshaft is at Bruno, for modification.
  • San Antonio, TX
  • 1990 K75RT
« Reply #1053 on: February 02, 2014, 02:18:53 PM »
headlight failure yesterday... brake padds gotts 50k on them... its cool at 65 degrees and cloudy... perfect motobrick work weather...
scored a silverstar ultra h4 9003 bulb... already had ebc organic padds... did the deal... now ready for some more yeeehaaaaa...
« Reply #1054 on: February 04, 2014, 07:53:57 PM »
swing arm bearing 104 thousand miles...
lior rebuilt my old final drive... now i have it as a spare... scored the parts new unused oem... $310 total... took abouts an hour... pays to have the right tools and the experience of doing these on r motos...
« Reply #1055 on: February 09, 2014, 01:38:12 PM »
hit it hard 1 up yesterday... right fork started leaking...
the workshop...
made a sealmate outta a cascade ice water bottle... ive done this before with 100% success... this time pulled a substantial piece of sand outta my fork seal with my homemade sealmate...
donts wanna single droppage on the ground...
my suspension fluid injector is cracked... hummm...
so i made a funnel outta a solo water cup...
had to take the top caps off to getts the funnel in there...
usually just count how many 30ml injectors i push in the forks... butts now i gotts no way to measure... so i borrowed a measuring cup from the vegan restaurant next door...
easy goes it...
wrapped it up... no seal leakage... yawl...
Offline subforry
« Reply #1056 on: February 22, 2014, 09:28:41 PM »
New Race Tech front springs installed from the top with forks in place.  Once I did one side the other was easy.  It really helped to have a long 4mm screw.  Changed from 7.5wt oil to 15wt.  The 7.5wt was definitely too soft.  New rear shock should be arriving next week.
  • 1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
« Reply #1057 on: February 22, 2014, 09:42:07 PM »
installed new blind spot mirrors...
read about it here...
mack75
« Reply #1058 on: February 24, 2014, 07:28:08 PM »
Fitted a set of bar risers bought off eBay, sent from the USA and came to the UK in three days!!! ( they lifted the bars on my K75s and improved the comfort so much better than before, but the bars are still a tad narrow) fitted a YSS rear shock and dialled it in wow! much improved and worth the money, put spacers on the fixings for my after market "Skidmarx" screen so it changes the screen angle and deflects the wind over my head, tried it all out and was well pleased. All in all it has transformed the bike. :riding:
Offline voodooskin
  • gone: 1997 K1100LT
« Reply #1059 on: March 02, 2014, 01:59:15 AM »
Flush brake fluid, new pads, speed bleeders:
Off with the OEM nibs.  I had a panic when I thought I cross threaded one of the speed bleeders into the top of the ABS unit, I bet that's a costly mistake.  Turns out it was just the cruft the speed bleeders put on the threads for some reason makes them feel like they're cross threaded, <whew>
The juice:
This was a failure.  Worked to suck out the old fluid from the master cylinder, but the brake fluid must react with acrylic or lexan or whatever this thing is made from because 30 minutes later it was lying in ruins on my garage floor in shards:
Cyl had some kind of snot-like … snot on the walls of the cylinder.  The cyl was installed new two years ago the last time the fluid was flushed.  Maybe they're serious when they say flush the fluid every year (I let this slide a year).  I didn't see this stuff anywhere other than the front master cylinder.
New pads, got them from beemer boneyard.  Not brave enough to try the $27 pads people are finding on ebay although who knows maybe they all come from the same factory.  Maybe next time I'll try the cheaper pads.  I liked these because they specifically said "make sure you have the Brembo brakes" which made me think they would fit my K.
  • Oregon
1997 K1100LT 49K miles
Offline ruben
« Reply #1060 on: March 10, 2014, 08:51:52 AM »
Hello Johny,
Great pic on those bearing changeout on the FD.
I'm about to perform that same task but only manage to get a "17 ball" bearing, instead of the "19 ball" bearing from the shop.
Will there be issue using the '17 ball' bearing?
Any advise on this, anyone??
« Reply #1061 on: March 10, 2014, 09:33:56 AM »
greetings ruben...
welcome to motobrick.com...
dont know... some think going from 19 to 17 is the reason for the uptick in k + r 1150  + 1200 final drive failures...
i can tell you why mine failed... wore that f-er out... and it was 100% yeeeehaaaaaa....
Offline ruben
« Reply #1062 on: March 11, 2014, 09:19:06 AM »
oic, thanks J O!
greetings ruben...
« Reply #1063 on: March 11, 2014, 12:14:39 PM »
Installed Heavy Duty Battery Cables on the K75
Ordered some $26 heavy duty battery cables from Euromoto Electrics in Denver on Friday afternoon and received them in the mail Monday!
Removed the seat, tank, Jetronic and the battery. Popped the cover off the relay box and removed the starter relay. Disconnected the two stock cables from the starter relay and snipped them at the other ends near the connectors. There are a couple of little wires attached to the stock cables near the connectors on the other ends, so I'll leave the connectors and just connect them in parallel with the news cables.
I hadn't noticed before but the stock cables to and from the starter relay are not very heavy duty. Maybe 10 gauge? Replacements are 4 gauge, the same as the stock grounding cable that connects the battery to the transmission housing. I've had problems with my starter relay locking up at odd times over the last couple of years, so these new cables will ensure enough juice reaches the starter and will hopefully solve the relay problem.
Attached the L-shaped ends of the new cables to the starter relay and fed them through the rubber sleeve which I temporarily removed from the bottom of the relay box. I marked the battery-side end of the cable that connects to the relay with a + since it's just black. Red electrical tape would have been better. Had to widen the rubber sleeve a bit with a razor knife to accommodate the thicker cables. Re-installed the relay, the rubber sleeve, and closed-up the relay box. Re-installed the battery.
Connected the other ends of the cables to the battery positive terminal and starter relay. (Also connected the old connectors to the battery and starter relay since they're still feeding something through those little wires). Replaced the ground cable to the transmission housing with the new cable. Replaced the Jetronic and fuel tank. Bike fired right up. Replaced seat.
Expecting real sun today so time for a ride.
« Reply #1064 on: March 14, 2014, 12:02:16 PM »
too much straightlining...
Offline drut
« Reply #1065 on: March 14, 2014, 04:06:29 PM »
"too much straightlining..."
Maybe,but by the look of that tire you don't spare it in the twisties either...
  • Newcastle upon Tyne UK
« Reply #1066 on: March 16, 2014, 09:41:42 PM »
Pulled my gas tank and front fenders.  Am going to get the blue the same color as the fairing/lowers which was painted a slightly different "Royal Blue" last year.
Offline Mongrel
« Reply #1067 on: March 18, 2014, 12:04:25 AM »
Too many deferred maintenance items over the past 2-3 years, so this spring's going to be heavy chores. Best get started...
Done today:
- Oil change (that, I do every year - usually when I put the bike away)
- Coolant flush
- Fuel filter change
- Removed the seat to take it and get it recovered.
Lots left to do, but it was a fair start.
Still on the list (some I want to do right away, some just "this spring"):
- Put seat back on (lol)
- Brake fluid change
- Final drive & transmission fluid change
- Cable spot lubrication/cable check
- Fill centre stand with expanding foam
- Air filter check & replacement
- Gas tank rubber grommet replacement
- Try (again) to diagnose slightly wonky headlight (this one's confounded several people)
- Spline lube (got to wait for warm weather to borrow a spot to do this - can't do it at my apartment)
'86 K75c
Offline subforry
« Reply #1068 on: March 19, 2014, 01:49:04 PM »
Cut 10mm off the spring spacers I installed with the Race Tech springs.  I am getting good at pulling the springs from the top with the forks in place.  Took me less than 2 hours.
Also reduced the Hagon rear shock pre-load by 5mm.  Overall increased the static sag.  Feels a little softer and sits lower.
  • 1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
Offline healthy
  • get up!
« Reply #1069 on: March 19, 2014, 02:45:36 PM »
Well, I went ahead and bought a second brick (k75) that showed up on the chicago craigslist. about a year earlier than i had planned, but the bike was too good and too clean to pass on.
I'm moving from my '86 K75 with ~140k miles to a '96 K75 with ~13k.
need to take it through it's paces and start my list of what needs to be tackled on the new bike. besides the normal oil/fluid changes and inspections i'm going to have to re-add heated grips, headlight relays, etc.
still not sure if i dig the low seat or not. i guess time and miles will tell.
All in all i'm pretty happy
1986 K75T, her name is JEZ.
and now a 1996 K75, BUE.
Offline frodef
  • 1986 K75C
« Reply #1070 on: March 21, 2014, 08:00:23 AM »
I fitted rbm's LED GPI circuit as a replacement for the original LCD GPI in my instrument box, so now I should have fully functional instruments for the first time since I got this thing  :yes  Last year I replaced the clock for some generic 12h thing from china, but soon I'll replace that with a different one that does 24h, temperature and volts (I'll add a mode switch on the "console").
When pulling the bike out from winter storage I managed to drop it and scratch the tank, and to twist off one of the mirror bolts that somehow had rusted stuck over the winter.  :musicboohoo:  Should make for some nice welding practice.
Offline frodef
  • 1986 K75C
« Reply #1071 on: March 22, 2014, 04:40:02 PM »
I rebuilt my front brake-light switch, fingers crossed it'll work too  :euro .
Offline roninvt
  • free range, cage free
« Reply #1072 on: March 22, 2014, 08:31:13 PM »
Today i figured out my f'up in my denali d2 installation...can't wait to try them out on a ride...replaced crankcase breather hose and wired in the lead for my powerlet jacket liner
1990 K75C
1993 K1100RS
Offline tg4360
« Reply #1073 on: March 23, 2014, 12:05:29 PM »
Not today but over the past four months.....
Tony G
'79 XS750 "The Triple"
'72 A65T "The T-Bolt"
'68 B25 "The Blue Bike"
Offline Rightsideup
  • Get your motor running...
« Reply #1074 on: March 26, 2014, 03:46:31 PM »
Well it's a nice bright day in Scotland, new clutch cable and balancedTBs - runs even smoother than before!
'74 Ducati 750GT | '78 MZ TS250/1 | '92 BMW K75RT
In the high latitudes of Finland, in the parching heat of Africa, under the most different operating conditions these motor-cycles run to the satisfaction of their owners.​
