Author Topic: What Did You Did To Your Motobrick Today ?  (Read 3597070 times)
Offline F14CRAZY
« Reply #1200 on: July 07, 2014, 06:14:09 AM »
The still-working bulb from the right ride works fine in the left side (the suspect side) so I figure it must be the bulb
  • Grand Rapids, MI
  • '87 K75C
Offline drut
« Reply #1201 on: July 07, 2014, 06:36:54 PM »
Ram rear shock arrived today so fitted it & set initial sag.Hoping to try it & dial it in later in the week.Seems well made and really nice people to deal with.
  • Newcastle upon Tyne UK
« Reply #1202 on: July 07, 2014, 07:20:28 PM »
looks ramtastic... i betts its gonna be yeeehaaaaaa...
Offline drut
« Reply #1203 on: July 07, 2014, 07:31:23 PM »
I hope so!I took your advice from I asked about rear shocks but had to wait till I had funds & not sorry:unit appears really high quality.Really looking forward to trying it out.
Offline Zipster
« Reply #1204 on: July 07, 2014, 07:35:06 PM »
Brake pads changed all round and my monthly calliper check, clean and lube done.
  • Northern Ireland
« Reply #1205 on: July 07, 2014, 07:48:12 PM »
so im nibbling on weed cheez and weed crackers and figger i better go fetch some more heffeweedzen...
im sitting at this t-boner figger i must twist the wrist or wait for all the hodags to pass... so i twist the wrist and at the apex i lose power and nose down... then without notice im at full power fishtailing out in front of the hodags...
i find the plastic housing where the throttle cable meets the grip is broken allowing whackness down at the engine...
so i didds what all motobrickers should do... i jbwelded it...
Offline F14CRAZY
« Reply #1206 on: July 07, 2014, 07:52:45 PM »
Is that a K100RS SE?
  • Grand Rapids, MI
  • '87 K75C
Offline drut
« Reply #1207 on: July 07, 2014, 08:09:33 PM »
"Is that a K100RS SE?"
No its a 1990 K100RS 16v,resprayed in Ford Frozen White
Offline richarddacat
« Reply #1208 on: July 07, 2014, 08:33:02 PM »
Of course my side stand has been bent for awhile and Dad added a block underneath for a fix. This got in the way of the center stand so you had to put the center stand up before the kick stand.
Well the other day the foot arm broke off on the side stand and gave me another reason to fix it.
So, I welded the foot arm back on, straighten the stand back out and since I most likely weaken it by heating it I also welded a piece of key stock to the back side.
BUT, during the repair I still rode the bike and didn't know about the bushing in the frame swing mount. What made me think about this was that noise I heard riding home from work that sounded like a nut falling off my bike and that slight twist of the rear tire when I know there wasn't anything in the rode.
Part now on order.  :musicboohoo:
Offline subforry
« Reply #1209 on: July 14, 2014, 12:09:21 PM »
Didn't work on the brick so much as built an item that will be installed on the brick.
Made this 555 IC based timer to start the fan at the push of a button and run for 5 minutes.  It has a potentiometer so the time can be adjusted from 1-10 minutes.
I am waiting for the push button to arrive.  It has a led that I will light up to show the timer and fan are running.
  • Hermosa Beach, CA, USA
  • 1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
« Reply #1210 on: July 14, 2014, 04:03:23 PM »
I want one of those -- need to learn how to do that kind of cool stuff.
Replaced clutch and choke cable on my black motobrick. Took off and drained tank to finish the paint job I never finished last year. Took off the rear right turn signal on the red motobrick and bent it back into shape with a heat gun after I guess someone had dropped it and it was tilted upwards 7 degrees. Put an exhaust gasket made from two strips of beer can aluminum with copper high-heat RTV sandwiched in between on the black brick -- tried it out on red brick and it worked pretty good -- not a single backfire in 500 miles. Drained the oil and CD-2 mix from the black brick which I hope cleaned that sprag clutch after 300 miles and replaced with good clean Mobil 1.
Offline roninvt
  • free range, cage free
« Reply #1211 on: July 14, 2014, 09:42:14 PM »
Replaced fork seals,  filled forks with Belray 10w, installed fork gators and new front pads.  Feels nice to have a suspension.  Odering a new shock this week
1990 K75C
1993 K1100RS
Offline Bokobob
  • I am a 1936 Model
« Reply #1212 on: July 17, 2014, 08:25:33 PM »
 :bmwsmile Dealer checked valves that had not been adjusted in several years and found them all to be within spec range....new rear tire installed....New plugs.......Replaced front brake master cylinder....flushed brake fluid.....replaced coolant......(had splines greased a couple of weeks ago so should be good for three years or so with only oil changes unless something "breaks")..
  • Gastonia, NC
Grace + Peace,
Bob
1995 BMW K75
1994 Honda Magna 750 V4
1996 Kawasaki Vulcan 500
Offline chico
« Reply #1213 on: July 22, 2014, 05:28:08 PM »
I tried to repair the broken boss on the radiator trim.
Tore off the fiberglass repair attempt leftover from previous owner.
1. Sanded area well on boss and on panel.
2. Cleaned with soap and water.
3. Wiped down with rubbing alcohol just cause it was there.
4. Mixed some plastic epoxy and applied to boss edges and panel.
5. Ran a bead around the edges and let it dry a day.
6. Went back and sanded again.
7. Applied another layer to try to get wider contact patch.
8. Let dry a day and installed.
We'll find out if it worked next time I pull it off!!   :dunno2:
Fixed my girlfriend's birdie too!
  • '86 K75
Offline hartrepair
  • Reich-rocket rider
« Reply #1214 on: July 24, 2014, 10:51:12 AM »
I rode from Flowery Branch Ga to Mojave California. Took some scenic routes. Used 200cc of oil. No problems. New job here in Cali.
'70 Mobylette
'61 Lambretta
'76 Suzuki GT550
'51 BMW R51/3
'71 Moto Guzzi Ambassador
'74-'75 Suzuki RE5...4 of them at once!
'95 K1100RS
« Reply #1215 on: July 24, 2014, 08:48:48 PM »
Mounted new Avon RoadRider's and painted the fork sliders yesterday so to allow them to dry overnight.
Offline subforry
« Reply #1216 on: July 25, 2014, 02:36:43 PM »
Welcome to CA
  • 1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
Offline Grim
« Reply #1217 on: July 25, 2014, 11:49:24 PM »
Broke the same part today. Thankfully not while I was on the road. I stopped at my mothers to mow her yard. Decided to grab her mail at the street jammed it in the glove box (LT) and as I was parking it got against the cable and broke the elbow. :(.
The way it broke I was able to take a zip tie to hold it together. That elbow is part of the cable so $37 cable is in my future.
1995 Morea Green K1100LT
Offline Diveschool
« Reply #1218 on: July 29, 2014, 03:09:48 PM »
Worked on my k75rt and changed fan motor (it was bad), drain and flush radiator, fixed bad wires on stereo, installed Antenna for radio, install red running light pod, and brakes led light, fixed top case.   Changed windshield, so nice to be able to see again
Still to do, Installing Johnny blanket, and of course...  Re installing the faring
1992 K75RT ABS
K75C, K1100RSA, plus a few Japanese bikes
Offline Zipster
« Reply #1219 on: July 29, 2014, 03:52:48 PM »
After having a panic moment on Sunday when the brake lever hit the twist grip with very little effort and the bike didn't slow much, I've now fitted stainless steel braided lines to the front of my K1100LT and the difference is amazing. After changing the pads last month, the stopping power now is so much better than it was.
  • Northern Ireland
KMGuy
« Reply #1220 on: July 31, 2014, 02:40:46 PM »
I got shafted by the auto-retract clutch! Trying to reattach the left mirror/signal assembly now! Any tips 'cuz this bites, doesn't want to go back on......
grant71
« Reply #1221 on: July 31, 2014, 02:55:22 PM »
yes. i had the same problem. could not get it right. frustrated, i went to a friend and he did it in about 5 secs. i wont even try again. seems he pushed it from rear forward towards the front     wheel if you follow my lousy description.
grant71
« Reply #1222 on: July 31, 2014, 02:56:27 PM »
Offline drut
« Reply #1223 on: July 31, 2014, 04:43:32 PM »
Confidence & a little bit of lube/oil on the 3 "posts" helps,when I first tried I was too gentle,placing in position then slapping end of housing "positively" works for me.
Offline subforry
« Reply #1224 on: August 01, 2014, 02:56:09 PM »
Finished job.  Short video to show fan tuning on.  It will shut off after about 5 1/2 minutes.
https://www.youtube.com/watch?v=dke15_qpa8o&feature=youtu.be
Switch - comes in different colors
http://www.amazon.com/gp/product/B00HENI7OW/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
Timer kit if you don't want to build your own.  This kit is a little big but could fit in the relay box.  Use a smaller relay to save space.
http://www.amazon.com/gp/product/B000TA7A04/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
  • 1996 K1100RS
1981 Suzuki GS850G
1996 BMW K1100RS
2009 BMW K1300GT
