Author Topic: Strange smell with engine braking  (Read 3947 times)
Offline dfx
« on: May 29, 2014, 01:14:25 PM »
Hello,
I get a strange burning smell briefly, when engine braking at low speeds on my 84 k100rt. I say at low speed, maybe it just gets blown away at high speed before I can smell it. Could it be the clutch?
  • Alsace, France
  • K100RT 1986
Re: Strange smell with engine braking
« Reply #1 on: May 29, 2014, 01:39:01 PM »
Ekshaust ?
Offline dfx
« Reply #2 on: May 29, 2014, 03:32:15 PM »
Ekshaust ?
No, I don't think so. I once machined some Tufnol on a lathe many years ago. It reminds me of that smell.
  • Alsace, France
  • K100RT 1986
Offline K75RT Keith
« Reply #3 on: May 29, 2014, 04:12:53 PM »
If you're riding or slipping the clutch when you engine brake, then yes it is the clutch that is burning up.  K bikes have a dry clutch, just like a car and the K-bike clutch does not like to be slipped as one would with a wet clutch found in most other motorcycles.
1990 K75RT
Offline dfx
« Reply #4 on: May 31, 2014, 04:56:14 AM »
No, I'm not touching the clutch at all when that happens. In that case, I'm assuming that there is clutch slip when engine braking. But if that were true, surely I'd notice clutch slip while accelerating? Could it be something to do with the fact that under acceleration, the crankshaft provides the force and the rest of the bike the resistance, while under engine braking the reverse is true?
  • Alsace, France
  • K100RT 1986
Offline K75RT Keith
« Reply #5 on: May 31, 2014, 07:47:40 AM »
Not Likely.  The clutch plate and pressure plate should react the same under load regardless of which direction.
1990 K75RT
