Author Topic: replacement for Lock Ring D6,0 #07129934318  (Read 3972 times)
bubbas45
« on: May 07, 2014, 11:40:41 PM »
Howdy, folks. I've lost one of the lock rings for my K75S seat assembly. Clymer calls it a "special clip." Lots of online stores carry these, but the shipping is absurd for an item that weighs about as much as a couple of houseflies and could just be dropped in an envelope.
I was wondering if anyone has ever successfully replaced these with some common clip from a hardware store. I can take one of the others from the seat assembly in and start comparing, but if someone can point me to a substitute, that would be great.
Sure, I could pick one up from a dealer, even a car dealer since they use these in a bunch of models, but for the time and fuel to get over to a dealer and back, I might as well pay the brutal shipping charges. The hardware store is nearby.
thanks, bws
Re: replacement for Lock Ring D6,0 #07129934318
« Reply #1 on: May 07, 2014, 11:48:44 PM »
Just a 6mm external "Jesus" clip. Hardware store stuff will be fine. The stock one has a lip that makes it a bit easier to get it on or off without it moving into another dimension. Just buy a few from the hardware store and be done with it.
http://www.mcmaster.com/#retaining-rings/=rvbur8
Mcmaster would be another option. I'm not sure if the 6mm refers to the shaft or groove diameter though.
You can also get the exact one from a BMW car dealer.
http://realoem.com/bmw/partxref.do?part=07129934318
E31: Details on E31E31 840Ci CoupeE31 840i CoupeE31 850Ci CoupeE31 850CSi Coupe
« Reply #2 on: May 08, 2014, 06:22:36 AM »
i replaced those clips with a hairpins long ago...
bubbas45
« Reply #3 on: May 08, 2014, 01:42:25 PM »
Thanks, guys.
bws
