FRAME WELDING
Topic: FRAME WELDING (Read 4485 times)
grant71
FRAME WELDING
April 22, 2014, 02:29:34 PM »
hello everybody. my horn snapped off the steel fairing frame. i am going to have it welded. now besides disconnecting the battery, is there any other precaution that must be taken? tks
Inge K.
Re: FRAME WELDING
Reply #1 on:
April 22, 2014, 02:32:40 PM »
Alternator, injection ECU and ignition ECU.
And to be on the safe side also disconnect instruments, heat management relay and flasher relay.
Norway
grant71
Re: FRAME WELDING
Reply #2 on:
April 22, 2014, 03:39:51 PM »
how do i disconnect? remove fuses? remove relays ?
rbm
Re: FRAME WELDING
Reply #3 on:
April 22, 2014, 09:55:39 PM »
Pull connectors from the alternator and the computer stuff like Injection ECU, ignition ECU, instruments. Pull the relays from the sockets.
Regards, Robert
1987 K75 - Build Blog @
http://k75retro.blogspot.ca/
johnny
TrailBrakingThrottleWhacker
Re: FRAME WELDING
Reply #4 on:
April 22, 2014, 10:38:46 PM »
if it was my horn i would velcro it on there and leash it with a fishing line leader...
drut
^ Proficient Motobricker
Re: FRAME WELDING
Reply #5 on:
April 23, 2014, 12:56:14 AM »
When I worked in a car bodyshop they used a surge protector
http://www.goodallmfg.com/antizap-surge-protection/
when mig welding with no problems.However if I was welding my bike I would unplug ecu & disconnect battery earth,a good clean earth point as close as possible to the weld area would also be wise.
Newcastle upon Tyne UK
1990 K100RS + 1980 Moto Guzzi V50 II + 1971 Aermacchi/HD 350ss
Grim
Re: FRAME WELDING
Reply #6 on:
April 23, 2014, 10:06:56 PM »
Why not take the bracket off and weld it off the bike?
For record when I'm welding on my cars I take the cables off the battery and tie the ground to the positive to make everything electrically common. Don't know if that's 100% right but haven't had a problem yet.
1995 Morea Green K1100LT
FRAME WELDING
