Author Topic: K75s 1987-a few more questions-Heated Grips  (Read 3845 times)
Jbuffalo
« on: March 11, 2014, 07:00:46 AM »
I am waiting for parts before I start up the bike.  Now fixing the heated grip(left grip is the problem). The left grip has the Bmw wiring through the bar ends and I am going to replace the thin resistance wiring.  The left grip cover is cut and I will have to get a new one.  Were these grips grey or black in color?  I do not want to remove the Right Grip because of the possibility of destroying the thin heat wire but I would like them to match. I would buy the whole unit if it would match. Were do I get a matching left grip that is for heated grips that will match the right grip which is now a grey color?  thanks Jim
Re: K75s 1987-a few more questions-Heated Grips
« Reply #1 on: March 11, 2014, 08:23:08 AM »
Grey.
mack75
« Reply #2 on: March 13, 2014, 04:34:56 PM »
You can save the original grip if in good condition by using a high pressure air line to blow the grip off the bar, takes a bit of trying but it works.
But check the connection from the switch first before going for the bar windings.
Offline GasStation
  • 93 K75S Mystic Red
« Reply #3 on: March 15, 2014, 04:17:18 PM »
I purchased heated grips last year for K75S and the kit came with grey handles.
93 K75S Mystic Red
IBA #9469
