K75s 1987-a few more questions-Heated Grips
Topic: K75s 1987-a few more questions-Heated Grips (Read 3848 times)
Jbuffalo
March 11, 2014, 07:00:46 AM »
I am waiting for parts before I start up the bike. Now fixing the heated grip(left grip is the problem). The left grip has the Bmw wiring through the bar ends and I am going to replace the thin resistance wiring. The left grip cover is cut and I will have to get a new one. Were these grips grey or black in color? I do not want to remove the Right Grip because of the possibility of destroying the thin heat wire but I would like them to match. I would buy the whole unit if it would match. Were do I get a matching left grip that is for heated grips that will match the right grip which is now a grey color? thanks Jim
Inge K.
Re: K75s 1987-a few more questions-Heated Grips
Reply #1 on:
March 11, 2014, 08:23:08 AM »
Quote from: Jbuffalo on March 11, 2014, 07:00:46 AM
Grey.
Norway
mack75
Reply #2 on:
March 13, 2014, 04:34:56 PM »
You can save the original grip if in good condition by using a high pressure air line to blow the grip off the bar, takes a bit of trying but it works.
But check the connection from the switch first before going for the bar windings.
GasStation
^ Motobrick Curious
93 K75S Mystic Red
Reply #3 on:
March 15, 2014, 04:17:18 PM »
I purchased heated grips last year for K75S and the kit came with grey handles.
93 K75S Mystic Red
IBA #9469
