Author Topic: Missing Bolt?  (Read 4198 times)
Offline MCrenshaw
Missing Bolt?
« on: February 04, 2014, 03:19:28 PM »
Hi, last week I took possession of a '94 K1100RS.  I had the chin cowl off to inspect the spark plugs, and noticed a missing bolt or screw on the right front corner of the oil pan.  The bolt hole comes in from the right side, not the bottom.  I can't imagine this being like this from the factory so I presume that the bolt/screw is missing.   A look at the microfiche does not show this bolt because it is on the right side; the diagram only shows the front and left sides.  Any suggestions if this is a special bolt?  -Mike
Re: Missing Bolt?
« Reply #1 on: February 04, 2014, 04:01:14 PM »
Is it the one in the picture you have in mind? If so, it's used for mounting crash bars and engine spoiler
bracket, when not in use a plastic plug covers the hole.
Re: Missing Bolt?
« Reply #2 on: February 04, 2014, 04:20:18 PM »
i remove my plastic plug covers to shed weight... then i raise my ride height... then i can lean more before i scrape peg...
Offline MCrenshaw
Re: Missing Bolt?
« Reply #3 on: February 04, 2014, 05:49:20 PM »
Yep, that's the one.  I like your idea of weight savings.  I could probably save a few miligrams if I were to plug it with a twig instead of a steel bolt.  Thanks for the quick reply!  -Mike
Re: Missing Bolt?
« Reply #4 on: February 04, 2014, 08:39:44 PM »
When I worked on the Berkeley formula racing team, they had me machining bolts on a lathe to remove a thread or two to save weight.
