Author Topic: Alarm  (Read 7733 times)
Offline Tuco
  • Gone ridin' !
  • Ready, Set, Go!
Alarm
« on: January 31, 2014, 03:03:35 AM »
Is the alarm on my 87LT worth a darn or should I remove it? Is it reliable? Can it be removed?
  • Waldport, Oregon
Re: Alarm
« Reply #1 on: January 31, 2014, 07:49:41 AM »
I could dig thru the bmw diagrams to be sure of easy removal, but if it's not working I'd pull it and ditch it. If it's working and by chance your insurance co is offering you a premium discount for having it, I'd consider keeping it. It's not hurting anything.
Offline Tuco
  • Gone ridin' !
  • Ready, Set, Go!
Re: Alarm
« Reply #2 on: January 31, 2014, 11:48:41 AM »
I think I figured the whole thing out. The plunger switch under the seat is the culprit. A few strips of duct tape on the inside of the cover the plunger pokes through and I was on my way. This keeps the plunger pushed all the way in.The plunger on the switch must be right at its limits so the engine would occasionally cut out. Home is a couple hrs ride from here so later today should prove if I'm right.
  • Waldport, Oregon
Offline Tuco
  • Gone ridin' !
  • Ready, Set, Go!
Re: Alarm
« Reply #3 on: January 31, 2014, 05:48:36 PM »
I just rode about 40 miles and the cutting out seems to have ceased. The ride home is 60 miles so hopefully it won't act up then. We'll see!
  • Waldport, Oregon
Offline Tuco
  • Gone ridin' !
  • Ready, Set, Go!
Re: Alarm
« Reply #4 on: February 01, 2014, 03:30:34 PM »
Scott
Would you see if the factory alarm can be removed. It acted up again last night. I'm worried about being in the middle of nowhere and having problems with some obscure switch. Thanks Al
  • Waldport, Oregon
Offline Inge K.
Re: Alarm
« Reply #5 on: February 01, 2014, 04:33:00 PM »
If you got the factory alarm, it won't affect the engine behaviour....it have only a alarm function.
You have to look elsewhere for your engine running problem.
And it won't make any problems to disconnect it........on/off key-switch you find on the left hand
side of the relay Box.
  • Norway
Offline Tuco
  • Gone ridin' !
  • Ready, Set, Go!
Re: Alarm
« Reply #6 on: February 01, 2014, 11:23:47 PM »
That looks like what I have. If I make sure that plunger is all the way down it runs, if the seat is up/open it won't run.
  • Waldport, Oregon
Offline Inge K.
Re: Alarm
« Reply #7 on: February 02, 2014, 03:45:48 PM »
According to BMW own wiring diagrams this alarm isn't connected to any wiring that would affect engine
running..........could be that the alarm system is modded.
On models that didn't use this switch (alarm mounted in the ducktail), it was disabled with a 10x1mm cap nut.
  • Norway
Offline Tuco
  • Gone ridin' !
  • Ready, Set, Go!
Re: Alarm
« Reply #8 on: February 02, 2014, 11:35:31 PM »
Thanks for looking at the factory diagrams. I'll be back next Sat so I'll investigate further then.
  • Waldport, Oregon
Offline Tuco
  • Gone ridin' !
  • Ready, Set, Go!
Re: Alarm
« Reply #9 on: May 15, 2014, 02:41:11 PM »
Scott, I've decided to remove the alarm if its not too difficult. One less thing to figure into the equation. I'm seriously frustrated. The thing quit a month ago, been sitting at a shop the whole time. Still not fixed and the shop owner told me to come and get as he does not know how to fix it. Al
  • Waldport, Oregon
Offline orforester
Re: Alarm
« Reply #10 on: May 15, 2014, 04:38:23 PM »
Al, if it not working when I get back June 1, holler, I can help you out by at least looking at it.  I have lots of experience in things that don't run, not saying I can fix it, but at least look at it, good as you have now.
You know where I live and my number
Bob
Bob
1989 K 100 RS se (SOLD)
1985 K 100 RS, now RT
2008 R 1200RT
