Author Topic: Mounting a top case  (Read 5053 times)
Offline bamaboy
  • bamaboy; ROLL-TIDE!!
  • '94 K1100RS
Mounting a top case
« on: September 21, 2013, 04:17:01 PM »
I'm starting to sort out all my planned mods, I drilled and mounted my "sandwich rack" and looked at the hardware that came with my top case (looks like a GIVI knock off??) except when you get to the mounting plate. Could you look at what I'm working with and offer an aesthetically pleasing solution to raise the bracket up in a level stance
They call him Big Al,
women love him,
men want to be him...
Re: Mounting a top case
« Reply #1 on: September 21, 2013, 05:34:08 PM »
The only thing that comes to my mind is longer bolts/spacers for the rear for leveling, but then you are at potential of reducing the "stability" of the mount when rolling down the road.
Offline philmc
« Reply #2 on: September 22, 2013, 04:35:03 AM »
I mounted a top box very similar to that by taking off the metal frame on the tail section and bending two pieces of flat ali for the rear brackets to bring the top box up level
Offline roninvt
  • free range, cage free
« Reply #3 on: September 22, 2013, 07:34:36 PM »
I used a Givi E181 top case rack.
1990 K75C
1993 K1100RS
AR-Trvlr
Re: Re: Mounting a top case
« Reply #4 on: September 22, 2013, 11:48:35 PM »
That's what I use as well.  Seems to be a good solution.
