Author Topic: Foaming transmission oil  (Read 15345 times)
Offline frodef
  • 1986 K75C
« on: August 25, 2013, 04:20:17 PM »
I checked the transmission oil level on my K75 today, and the stick came up with some really frothy oil. I'll change the oil I suppose, but how worried should I be otherwise?
Re: Foaming transmission oil
« Reply #1 on: August 25, 2013, 06:33:58 PM »
i have heard abouts folks removing the oil fill cap and pizzing in the engine oil which causes frothing... butts i never heard of pizzing the the gear box... butts if they did it will most certainly froth...
« Reply #2 on: August 25, 2013, 08:08:10 PM »
There's a breather vent on the top of the transmission.
If you've pressure washed your bike or ridden in a hurricane, it's likely some water got in there.
Offline bmw-rider
« Reply #3 on: August 26, 2013, 08:39:07 AM »
What oil are you using?
Offline frodef
  • 1986 K75C
« Reply #4 on: August 27, 2013, 03:16:26 AM »
A 75W-90, saying "API GL-4/5, API MT-1".
Offline bmw-rider
« Reply #5 on: August 27, 2013, 09:46:34 AM »
That's OK then, but only API-GL5 is the correct one for you're bike.
Offline frodef
  • 1986 K75C
« Reply #6 on: September 01, 2013, 01:16:04 PM »
So apparently my gearbox has been running on honey for some time...  :musicboohoo:
I bought some (extremely expensive) 75w140 and put in there now, hopefully that will work too.
Btw. I put a crush washer on that drainplug, guessing there's supposed to be one there? There was only a somewhat conical washer there, fixed to the plug.
« Reply #7 on: September 01, 2013, 01:41:04 PM »
You removed the "conical washer", right? That's the old crush washer.
Offline frodef
  • 1986 K75C
« Reply #8 on: September 01, 2013, 02:02:03 PM »
I didn't remove it because it was much too narrow to pass over the threads. You can see it in the picture if you enlarge it. If that's the old crush washer, it's extremely deformed, so I thought it was supposed to be there... but it isn't?
Offline frodef
  • 1986 K75C
« Reply #9 on: September 01, 2013, 02:04:04 PM »
Is that a rubber piece? A lot of my rubber is starting to disintegrate... Would that be under the battery, approximately?
« Reply #10 on: September 01, 2013, 02:05:22 PM »
If you can drain, save and re-use the trans fluid you just put in, I suggest you remove that ancient washer (and ideally the new one too) and put it all back together with a new washer.
It's possible that you won't have a leaking problem if you leave things as-is, but...
You'll find that the old washer can be pried off without too much trouble.
« Reply #11 on: September 01, 2013, 02:06:20 PM »
The breather vent cap is not rubber.
Offline frodef
  • 1986 K75C
« Reply #12 on: September 01, 2013, 02:26:20 PM »
Ok, thanks for the info, I'll see if I can get it removed sometime.
« Reply #13 on: September 01, 2013, 08:45:28 PM »
i use mobil 1 75-140 in the gear box...
« Reply #14 on: September 01, 2013, 09:47:09 PM »
I did that by mistake once. Couldn't figure out why I paid $20 instead of $10 until I looked at the empty bottle the next day.
« Reply #15 on: September 01, 2013, 10:55:06 PM »
I run Redline Shock-proof. Works really well.
« Reply #16 on: September 01, 2013, 10:58:29 PM »
im pretty certain that somebody opened your oil fill and pizzed in your sump... ive seen it before and it looks exactly like this...
« Reply #17 on: September 02, 2013, 12:35:29 AM »
im pretty certain that...
Who does that?
Seems like a lot of effort and aim when deflating tires or cutting wires would be quicker without leaving DNA behind.
« Reply #18 on: September 02, 2013, 01:28:33 AM »
yawl...
pizzing in the gear box... thats why they offer locking oil fill caps...
crazy aint it...
Offline frodef
  • 1986 K75C
« Reply #19 on: September 02, 2013, 03:00:54 AM »
Well it didn't smell like piss... although I'm pretty desensitized to the smell as we're in the middle of potty-training the youngest now.
