Author Topic: Negative battery wire mount  (Read 3878 times)
Offline Big_B
« on: April 08, 2013, 04:26:18 PM »
After tearing my K1100 apart to repair the ignition switch I forget where the negative goes on the motor/chassis. It looks like it attaches to the starter, but I don't want to blow something over a simple mistake.
Does anyone know where the ground/negative wire is mounted to the motor or chassis? :dunno2:
  • North Easton, MA
  • 93 K1100RS
Re: Negative battery wire mount
« Reply #1 on: April 08, 2013, 07:45:08 PM »
Either one of the starter mounting bolts should work just fine.
cy7878
« Reply #2 on: April 09, 2013, 10:51:21 PM »
you can pretty much mount it anywhere.  But the actual spot is to the left side of gearbox housing, right next to the starter.  I think it's held my a 3mm hex bolt.
Offline Big_B
« Reply #3 on: April 09, 2013, 11:24:44 PM »
I ended up putting on the stock location right above the shit shaft. Thank you for the replies.  :2thumbup:
  • North Easton, MA
  • 93 K1100RS
