Author Topic: Crankcase breather hose cracks  (Read 21787 times)
TechPoet
« on: April 04, 2013, 08:25:06 PM »
 :lol: Noticed on the left side of the K75s, short hose, perhaps 4" long with cracks at either end.
It seems to enter the engine right behind the last cylinder. I'm not gonna make you laugh by guessing where it goes and comes from. I just need to pull out the Clymers and flip pages...
Am curious whether most hoses can just be removed at will if the bike is cool?
I have attached a 72dpi, 800x800 jpeg, that is less than 300kb.
Re: What is this hose and are cracks a bad thing?
« Reply #1 on: April 04, 2013, 08:33:55 PM »
Crankcase breather hose.  Yes it should be replaced when cracks appear.
NickAndHisBrick
« Reply #2 on: April 04, 2013, 09:04:13 PM »
Yep, crank breather, which means that its likely that the vac hoses and throttle body boots could also be cracked, causing additional leaks. Any cracked hose / boot that hooks to the intake is a potential leak of "unmetered air" into the engine, which will cause ridability probs.
Oh, and check the 2 middle throttle bodies, they have caps behind the fuel rail that can also crack
TechPoet
Re: Crankcase breather hose cracks
« Reply #3 on: April 05, 2013, 02:01:39 PM »
Thanks ever body, i fixed the subject for future searchers.
I found the crankcase breather hose http://www.beemerboneyard.com/11151460480.html. Did not find it in Clymers.
I will search for, but if you have links to parts please reply: vac hoses, throttle body boots, and middle throttle bodies.
Offline argent brick
« Reply #4 on: April 05, 2013, 02:27:00 PM »
FWIW, I have been told that the OEM crankcase hose is known to be problematic and marginal at best. Also was told that the aftermarket one you find for sale is even worse. With that being said, the OEM hose is double the cost. Personally, I opted for the factory hose because I have a dealer nearby.
Lynn
1995 K75/3A Standard
1978 Yamaha xs750(P.O.S.)
1976 R60/6 RIP
Offline Bassv
  • Ride it like you stole it
« Reply #5 on: April 05, 2013, 02:28:36 PM »
Aha! Now I know where this hose is from. On my bike it's also cracked and around it, it's very dirty and oily. Will replace it soon!
Part nr. 11151460480
K75RT 1991
« Reply #6 on: April 05, 2013, 09:37:57 PM »
By the way, I am going to gently disagree that a cracked breather hose means the throttle body ducts are probably cracked as well.  Those are much sturdier and much harder to replace than a breather hose which is thinner and more commonly needs to be replaced.   The breather hose is replaced in 15 minutes while getting the throttle bodies and the rest off and replaced is a few hours plus and requires more mechanical acumen plus about $100 in parts (more for a four cylinder).
Of course, all rubber parts on these old bikes are suspect and each should be inspected and replaced as needed.
« Reply #7 on: April 05, 2013, 10:03:34 PM »
My breather hose was good but I had a leak in the "throttle body ducts", which BMW call gaskets. If your in there, look at my post here.
JamesInCA
« Reply #8 on: April 06, 2013, 02:36:01 AM »
3/16" vac hose from NAPA at 0.99/ft. Get two feet. You only really need one, but nice to have a few extra inches. Throttle rubbers are $5.26/ea at MaxBMW. (11 61 1 460 755) plus clamps, and the special pliers to crimp them. Lisle 30800, cheapest at Amazon.
« Reply #9 on: April 06, 2013, 03:10:35 AM »
Can you get hose clamps from BMW that do not need to be crimped?
Lynn
1976 R60/6 RIP
« Reply #10 on: April 06, 2013, 09:34:09 AM »
You can get clamps from McMaster Carr or auto parts stores.... but the only reason to use non-OEM is to replace the Oetiker clamps with screw-type ones that don't require the special clamping tool. For the screw-type clamps, BMW is not expensive and you know you're getting the correct size.
When you use non-OEM, don't use the worm drive type clamps on your fuel lines.
« Reply #11 on: April 06, 2013, 09:53:51 AM »
For the throttle body clamps see #3 response here:
http://www.motobrick.com/index.php/topic,3826.0.html
Those Suzuki clamps worked perfectly and look great.  Though you need to make sure the screw heads don't interfere with the throttle linkage.
Offline Niemand
« Reply #12 on: April 07, 2013, 10:45:12 PM »
One can frequently find the Knipex version of the Oetiker tool on eBay for about $20.  It snips and crimps those guys so easily, I always wonder what all the fuss is about.  I'll post the Knipex tool number later if anyone is interested...being too lazy at the moment, however.
Edit 4/10/2013:  I remembered incorrectly, as it is a crimp tool.  I used a good pair of diagonal cutters to remove them, then this tool to crimp.
Niemand
1994 K1100RS
« Reply #13 on: April 09, 2013, 02:05:33 PM »
Yes, please.
Lynn
1976 R60/6 RIP
Offline Niemand
« Reply #14 on: April 10, 2013, 02:51:24 PM »
Knipex 1099
To avoid any further hijack I created a new thread about the tool:
http://www.motobrick.com/index.php/topic,4014.0.html
Carry on with your crusty hose stories.
Niemand
1994 K1100RS
Offline Supershooter
« Reply #15 on: November 24, 2016, 09:26:32 PM »
I know it's been a while, since this was active, but why is it important to avoid worm drive clamps on these lines?
Supershooter
  • 85 K100 RT
Offline F14CRAZY
« Reply #16 on: November 25, 2016, 09:06:08 AM »
Supershooter
Fuel injection hose clamps hold better, which is important for the high pressure of the system. The worm ones can strip
  • Grand Rapids, MI
  • '87 K75C
Offline kennybobby
« Reply #17 on: November 25, 2016, 01:51:06 PM »
And the outer jacket of the fuel hose extrudes thru the slots in the worm clamps as they cut into the rubber.
Ridin' 87 K75S vin 1334,
Renchin' 86 75S vin 0061
