Author Topic: k100 gas tank repair  (Read 9091 times)
jeffhestand
« on: March 23, 2013, 06:40:15 PM »
last fall i stripped paint from tank only to reveal some ugly repair jobs on each bottom side. Is there a good alternative to having tank rewelded or should i find a local Kansas City welding shop and see what they can do? I like to look of the bare metal polished tank with painted other parts but dont like the idea of fuel seeping out. Any advice appreciated. Jeff
Offline orforester
Re: k100 gas tank repair
« Reply #1 on: March 23, 2013, 10:40:48 PM »
I used a product sold at NAPA stores, specifically for gas tank repair.  Small kit, mix two parts together, quickly, and quickly spread on the gap/leak.  I hardens qucikly and is VERY HARD within a few minutes.  So far it is the best/only thing I have found that seals.
I used some JB weld the year before and it began seeping after about 3 tankfuls, slight, but still a leak.  So far the NAPA stuff is holding well.  On the 10th or better tankful, 1000+ miles.
When mixed it can be spread, kinda like drywall mud, and it is a dull grey color, so against a bare tank it would look close to the same color.
It costs about $14.00 for a small package.
Bob
Bob
1989 K 100 RS se (SOLD)
1985 K 100 RS, now RT
2008 R 1200RT
jeffhestand
« Reply #2 on: March 24, 2013, 09:20:41 AM »
that sounds good bob. I guess welding it would be cost prohibitive. I could probably just get a new replacement for what it would cost to weld up the tank. Not sure but im guessing.
Jeff
grant71
« Reply #3 on: March 24, 2013, 02:48:58 PM »
I ve used a product called Q bond. Go to olym@worldonline.co.za Its petrol resistant. Btw. Im in S Africa
Offline orforester
« Reply #4 on: March 24, 2013, 10:18:02 PM »
Jeff, if it is not too bad, I would try everything prior to welding, unless you find some nut job who wants to weld Aluminum and gas.  AL is hard to weld and I could find no one to weld on a gas tank, at all.
Try a two part expoxy first.  Even if you weld it will just sluff off under the heat, so you got nothing to lose.
Bob
2008 R 1200RT
Tighthead
« Reply #5 on: March 27, 2013, 06:42:22 PM »
You could try this stuff:
http://www.hirschauto.com/prodinfo.asp?number=GTS
I used it on my '67 Volvo's tank with good results. The smaller can even says "Special motorcycle formula!" even though it's the exact same thing.
Offline orforester
« Reply #6 on: March 27, 2013, 10:47:18 PM »
So here are a couple of shots of the stuff I used from NAPA, part number 765-1546, like I said before about $15.00 =/-
Another
Bob
2008 R 1200RT
chrish8846
« Reply #7 on: April 03, 2013, 08:26:47 PM »
I used the Eastwood Gas tank repair stuff that you slosh around in the tank to seal leaks, mine had lots of pin holes on both sides and there was not enough metal left to weld(way too thin). I repainted the tank but polished the gas cap to a mirror finish.(looks cool)
