Checking Brake Pad Wear on K75
Topic: Checking Brake Pad Wear on K75 (Read 6971 times)
TimTyler
Adrninistrator
March 03, 2013, 04:24:10 PM »
What's a worn brake pad look like when viewed while it's installed? I could not see any wear indicating marks.
frankenduck
Adrninistrator
Re: Checking Brake Pad Wear on K75
Reply #1 on:
March 03, 2013, 04:41:39 PM »
Min spec is 1.5mm.
New to K bikes?
Click here.
K Bike Maintenance & Mods:
Click here.
TimTyler
Adrninistrator
Reply #2 on:
March 03, 2013, 04:51:05 PM »
Thanks, Duck.
I pulled out one of the pads and I'm good at 4mm.
frankenduck
Adrninistrator
Reply #3 on:
March 03, 2013, 06:21:07 PM »
In reality it really doesn't matter unless it wears all of the way down to the metal back of the pad and destroys your rotor.
New to K bikes?
Click here.
Click here.
Chaos
Administrator
Mars needs women!
Reply #4 on:
March 03, 2013, 06:33:38 PM »
Sometime when they get around 1mm or so the pad can flake off all at once. Don't ask
sw ohio
1987 K75S VIN 0231
rbm
Reply #5 on:
March 03, 2013, 09:57:59 PM »
My experience is that as the pad material thins, it tends to squeal more readily. The back brake on my K75 was making a racket and, when I checked the pads, they were at minimum thickness. No squeal with the new pads.
Regards, Robert
1987 K75 - Build Blog @
http://k75retro.blogspot.ca/
frankenduck
Adrninistrator
Reply #6 on:
March 03, 2013, 10:19:54 PM »
Disc squeal is caused by high frequency vibrations as the caliper pistons vibrate against the backs of the pads. Very easy to cure by spraying this on the backs of the pads:
New to K bikes?
Click here.
Click here.
Qdude
Reply #7 on:
March 04, 2013, 12:29:04 AM »
I have found that the squealing can be cured by applying a thick layer of grease to the rotors as well.
Stopping then becomes an issue though.
Mitcam62
Reply #8 on:
March 18, 2013, 08:46:12 AM »
Makes for an interesting ride though, no? LOL!
Chaos
Administrator
Mars needs women!
Reply #9 on:
March 19, 2013, 12:23:33 AM »
Apply the grease evenly to both sides or you will stop in circles :loco:
sw ohio
1987 K75S VIN 0231
