Author Topic: Checking Brake Pad Wear on K75  (Read 6970 times)
« on: March 03, 2013, 04:24:10 PM »
What's a worn brake pad look like when viewed while it's installed? I could not see any wear indicating marks.
Re: Checking Brake Pad Wear on K75
« Reply #1 on: March 03, 2013, 04:41:39 PM »
Min spec is 1.5mm.
« Reply #2 on: March 03, 2013, 04:51:05 PM »
Thanks, Duck.
I pulled out one of the pads and I'm good at 4mm.
« Reply #3 on: March 03, 2013, 06:21:07 PM »
In reality it really doesn't matter unless it wears all of the way down to the metal back of the pad and destroys your rotor.
« Reply #4 on: March 03, 2013, 06:33:38 PM »
Sometime when they get around 1mm or so the pad can flake off all at once.  Don't ask
« Reply #5 on: March 03, 2013, 09:57:59 PM »
My experience is that as the pad material thins,  it tends to squeal more readily.  The back brake on my K75 was making a racket and, when I checked the pads, they were at minimum thickness.  No squeal with the new pads.
« Reply #6 on: March 03, 2013, 10:19:54 PM »
Disc squeal is caused by high frequency vibrations as the caliper pistons vibrate against the backs of the pads. Very easy to cure by spraying this on the backs of the pads:
Qdude
« Reply #7 on: March 04, 2013, 12:29:04 AM »
I have found that the squealing can be cured by applying a thick layer of grease to the rotors as well.
Stopping then becomes an issue though.
Mitcam62
« Reply #8 on: March 18, 2013, 08:46:12 AM »
Makes for an interesting ride though, no? LOL!
« Reply #9 on: March 19, 2013, 12:23:33 AM »
Apply the grease evenly to both sides or you will stop in circles  :loco:
