Author Topic: New leak in an old spot  (Read 11395 times)
Offline tsbt
« on: February 21, 2013, 12:54:02 PM »
Last summer I replaced the main seal and clutch. Was leaking on the driveway. After putting her back together and taking a trip to NYC last year I arrived home with a new leak same spot. Thinking it's the front and rear seals in the tranny which I should have replaced the first time I was down there. Lesson learned. Was also having trouble shifting and really had to stomp on it in lower gears at lights. Even after using Dog Moly trasmission additive which apparently smooths shifting out on the Ks. Wondering now if it's just getting worn. So this spring I'll be heading back down the same path this time to open and inspect the tranny. Wish me luck.
92 K100RS 4V
75 KE125
Re: New leak in an old spot
« Reply #1 on: February 21, 2013, 07:49:37 PM »
Is it leaking oil or transmission fluid? The answer will tell you which seal is leaking.
Did you replace the O-ring when you did the rear main seal?
Offline Qdude
  • Dyslexic Agnostics Wonder if there is a Dog...
« Reply #2 on: February 22, 2013, 03:32:58 AM »
Good Luck...
Sorry for the two timer problem.   :popcorm
96 K 1100 LT
77 KZ650C
77 KZ650C
I believe in Life before Death
Offline tsbt
« Reply #3 on: February 25, 2013, 03:13:27 PM »
Good question, hard to tell because I use DogMoly Gear Additive so tranny oil is the same color as engine oil basically, might need a bright day to examine it closer. The leak is minimal only leaks after a ride. Replaced the O-ring.
92 K100RS 4V
75 KE125
« Reply #4 on: February 25, 2013, 03:24:43 PM »
Gear oil and motor oil smells quite differently.
Inge K.
« Reply #5 on: February 25, 2013, 03:32:43 PM »
Gear oil smells like sulfur.
Offline tsbt
« Reply #6 on: May 09, 2013, 04:36:18 PM »
It's definitely gear oil. Ordered two transmission seals and she's coming off again. Who's taken a transmission apart here, anything I should know about other than, don't drop it?
92 K100RS 4V
75 KE125
Offline cy7878
« Reply #7 on: May 09, 2013, 05:29:56 PM »
When I did the spline and RMS, I didn't want to mess with anymore seals than I already did.  I paid my local dealer to do the seals, I think it was 4 and a cover plate and bill came to $340 parts and labor.   I just dropped the gearbox there and picked it up after a few days.
Chuck
San Diego
1985 K100RS
Offline tsbt
« Reply #8 on: May 09, 2013, 05:51:46 PM »
I'm too cheap and I like the challenge plus the gearbox is a little clunkier than it was last year gives me an excuse to suss out other things :yes
92 K100RS 4V
75 KE125
Offline JamesInCA
« Reply #9 on: May 09, 2013, 05:55:29 PM »
This is an absolutely epic transmission rebuild thread for a '93 K1100RS. Not exactly the same unit, but enough to give you a sense of the thing: http://www.advrider.com/forums/showthread.php?t=476934
Offline Grim
« Reply #10 on: May 09, 2013, 07:20:01 PM »
Search "grub screw".
1995 Morea Green K1100LT
Offline tsbt
« Reply #11 on: May 11, 2013, 11:42:24 AM »
These transmissions are exactly the same as far as I know, perfect link thanks!
And by "grub screw" do you mean study the properties of it because there are many of these in a transmission? I'm elaborating to understand your point.
92 K100RS 4V
75 KE125
Offline tsbt
« Reply #12 on: May 11, 2013, 01:29:53 PM »
JamesInCA, I've spent a good deal of time on that thread you sent today. Some extremely good documentation of every detail thanks again for it. To do this properly, replace the seals AND any shot bearings which could be the cause of rough shifting, it would seem I'd need some factory specific tools. Soooo I could replace the seals for now, replace the seals and bearings or live with my slow leak or get a transmission with lower clicks. My feeling is that dropping it off at my mechanic is a hefty bill so that's not in the cards. Back to the shed...
92 K100RS 4V
75 KE125
Offline JamesInCA
« Reply #13 on: May 12, 2013, 04:46:01 PM »
The "grub screw" is what Americans would more often call a "set screw," and is the screw inside the transmission that holds the shift lever shaft in place with the rest of the shift mechanism. Apparently they have a tendency to come loose, and require an inordinate amount of work to reach in order to re-tighten. The symptom is slop in the shift lever.
