Author Topic: DIY Fuel Injector Cover (K75, K75C, K75S, K100)  (Read 11308 times)
« on: January 03, 2013, 01:59:49 PM »
CC Products of San Jose, CA used to make a molded plastic cover that mounted to the fuel rail and covered up the exposed fuel injectors to make the bike a bit more sleek looking.  Since they are long out of production and hard to come by I fabricated my own using some aluminum sheet metal that I cut, bent and then had powder coated.
Offline detbmw
Re: DIY Fuel Injector Cover (K75, K75C, K75S, K100)
« Reply #1 on: January 03, 2013, 03:48:15 PM »
Is there any problem with heat build up? It appears to be just one-sided, not closed on the ends - so I guess the air would still flow over the engine properly?
  • Nacogdoches, Texas
Rich
« Reply #2 on: January 03, 2013, 06:24:02 PM »
Nah, air just flows through it.
Offline argent brick
« Reply #3 on: January 03, 2013, 06:31:18 PM »
I always thought the covers made by CC Products were metal. If they are plastic, I think I have one on my brick. They are a nice touch for a sharp looking machine.  Dust and dirt still get behind them though.
Your DIY cover seems to be taller, which is a good thing. Nice job.
Lynn
1995 K75/3A Standard
1978 Yamaha xs750(P.O.S.)
1976 R60/6 RIP
Offline detbmw
« Reply #4 on: January 03, 2013, 10:42:09 PM »
I may have to make on of these. Duck, do you have a template?
Rich
Offline pdg
« Reply #5 on: February 21, 2013, 05:00:44 PM »
I assumed the plastic moulded injector cover that came with my bike was OEM... I'll get around to putting it back on soon :laugh
1988 K75S
« Reply #6 on: February 21, 2013, 05:41:49 PM »
I used the engine as my template.  The one thing to be careful about is bending the aluminum and having it crack in the process.  I did it in a vice between a couple of 2x4s and pounded the bends with a hammer while bending it so it wouldn't crack.
« Reply #7 on: February 21, 2013, 09:43:38 PM »
Great writeup Duck.
For those with less of a DIY penchant, Motorworks in the UK has picked up distribution of a new re-manufactured injector cover for the K75 and K1008V bikes.
Part numbers ACA66614, and ACA66615
« Reply #8 on: February 21, 2013, 10:19:30 PM »
Great writeup Duck.
Good find.  It's good to see that MWorks still does stuff like this.  Not sure why CC Products discontinued.  Once you've got the mold, running a batch or two now and then can only lead to more income.
