Author Topic: Wiring Acewell Speedo  (Read 12413 times)
monsterbrick
« on: October 23, 2012, 12:59:47 PM »
Morning Motobrick!
I have run into a little snag finishing my project.  After riding around like this for a couple months, I have decided to get serious and do some soldering. After cleaning everything up and connecting...no power besides clock to the acewell speedo. Starter relay is still clicking and brake lights still functional.
Currently connected:
Clock power
starter switch
Tac
ground
Is there any thing that needs to be connected further? Or a otherout areas of thethe electrical system i should be checking?
Re: Wiring Acewell Speedo
« Reply #1 on: October 23, 2012, 01:36:15 PM »
Are you pulling in the clutch?  Do you know if your clutch switch is good?
« Reply #2 on: October 23, 2012, 01:36:55 PM »
You find some info about it in this thread, including this solution from Frankenduck.
It is also other threads about this subject in that forum.
Inge K.
monsterbrick
« Reply #3 on: October 23, 2012, 03:00:52 PM »
Thanks for the quick responses!  The k100 forum has been a huge tool in my rebuild, from this I installed with the minimal wiring necessary for the bike to come on. Right now the bike alive, but the instrument cluster will not turn on. With same wiring configuration, prior to yesterday, bike would start with out clutch engaged or trassmission in neutral position. After cleaning up what i could, second fuse is burning out when key is turned to run position. Does this mean I may be using incorrect ground from wiring harness?
« Reply #4 on: October 23, 2012, 03:42:52 PM »
#2 is the parking light fuse.
What's an "incorrect ground?"  All of the brown wires on the bike are ground and connected to each other.
monsterbrick
« Reply #5 on: October 23, 2012, 06:40:24 PM »
Well a common problem with this bike has been the forward controlls. Currently trying to rebuild front brake light switch, i can only imagine starter switch is shorting some where. With everything on fuse two does this sound most plausable? Also could this be linked to no power on speedo?
monsterbrick
« Reply #6 on: October 23, 2012, 06:42:51 PM »
Excavated this
monsterbrick
« Reply #7 on: October 26, 2012, 07:53:16 PM »
Well connected cluster power and starter switch to same connection on acewel (red) starter. Working on running lights now. Herez the new front of bike.
« Reply #8 on: October 26, 2012, 08:08:42 PM »
Are you ever planing on riding in the rain?  Those horns will collect water.  Why not point them straight down like BMW does?
monsterbrick
« Reply #9 on: October 26, 2012, 09:13:29 PM »
Well hadn't really rain proofed the bike yet. But the horns may be turned down, still getting everythimg bolted on. Should i be worried about no alternator cover in the rain?
