Author Topic: OK to use battery tender?  (Read 5529 times)
Offline MartDude
« on: October 07, 2012, 04:02:24 PM »
Is it OK to connect a battery tender via the accessory socket under the seat (K100 RT, 1989)? Used to this for the R100RS, but I spotted a warning in one of the manuals (Clymer?Haynes? Can't recall which ATM), advising not to use this socket for battery charging, due to a risk of damaging electronics.
If not, how do you connect your battery tender?
Thanks in advance,
Martin
Re: OK to use battery tender?
« Reply #1 on: October 07, 2012, 04:14:34 PM »
Yes.
Offline BexarWolf
  • 1994 K1100RS - Rubik
« Reply #2 on: October 07, 2012, 04:59:29 PM »
Yes.
.................is the short answer. The longer version is "yes, it's safe to use the socket for a battery tender". I have a Yuasa on mine with the powerlet adapter and all seems to be working well.
Sit tall in the saddle, hold your head up high. Keep your eyes fixed where the trail meets the sky. Live like you ain't afraid to die. Don't be scared. Just enjoy the ride. ~ Chris LeDoux
Offline argent brick
« Reply #3 on: October 07, 2012, 09:26:08 PM »
I know that BMW offers a charger(or used to) That could be plugged in under the seat. No adapter needed.   The one on the handlebars, however is a different story. Everything I have ever heard about it is that it can damage your electronics if you connect a battery charger by the handlebars. Better to be safe than sorry.
 "I have a Yuasa on mine with the powerlet adapter and all seems to be working well."
Did you buy the Yuasa "Sure Shot 900" ? Nice little charger for the money. Take the battery harness from the charger and install it on the right side of your bike so you have easy access from both sides:)
Lynn
1995 K75/3A Standard
1978 Yamaha xs750(P.O.S.)
1976 R60/6 RIP
« Reply #4 on: October 07, 2012, 09:30:47 PM »
Quote
Really. I do this routinely. No ill effects. Where did you here that one?
« Reply #5 on: October 08, 2012, 04:55:31 PM »
Quote
That is cool:) If you do it with no ill effects, then I should be able to also.
It was posted on a website for battery chargers or in a article I saw about chargers and BMWs. My brain is on vacation so I do not recall which. I think the article was about a newer "R" bike, but I can't see how that should make any difference.
Lynn
1976 R60/6 RIP
Offline Inge K.
« Reply #6 on: October 08, 2012, 05:11:26 PM »
On newer bikes with CANBUS a special charger is needed, which sends out a signal to keep the socket
connector "open", after the ignition have been switched off.
Inge K.
  • Norway
