Author Topic: New brick owner....  (Read 10777 times)
Offline jamie92j
New brick owner....
« on: September 30, 2012, 07:52:07 AM »
hello all!
Im a new owner of a fine BMW 'brick' K100LT and new member of this forum!!
Overall its a good bike, 89 model, 36,000 miles and tidy condition
Few bits i would like to know....
What reading do people normally have on the temp gauge? I'm in the UK with average temp today around 14c, temp gauge seems to be around half way in city riding, is this right?! My old Honda temp gauge never used to go much over a quarter!
The screen is epic at keeping the wind off, there are two little adjustable flaps on the side of the screen at the top, the mounts for these are all cracked up and look like they will fall apart while on the motorway, anyone know where to get replacement ones from?
The radio dosent work! which is a bummer as i quite fancy blasting some music out! Any guides on fixing these?!
Any help would be greatly appreciated!!!
Offline Inge K.
Re: New brick owner....
« Reply #1 on: September 30, 2012, 10:10:07 AM »
Welcome Jamie!
Your temp gauge have normal reading (just below the middle mark).
Parts for the flaps which is used at the comfort screen, you can get from your BMW dealer.
Since you`re from UK, you also could try: Motobins, Motorworks, James Sherlock.
If the battery have been disconnected, you need a pin code to get the radio to function.
You find a users manual for the radio in the bookshelf.
http://www.motobrick.com/index.php/board,22.0.html
Inge K.
  • Norway
Offline argent brick
« Reply #2 on: September 30, 2012, 05:40:51 PM »
Welcome Jamie!
You are going to love owning a flying brick.
How about some pictures? Brickheads like pictures.
Lynn
1995 K75/3A Standard
1978 Yamaha xs750(P.O.S.)
1976 R60/6 RIP
Offline jamie92j
« Reply #3 on: September 30, 2012, 06:45:56 PM »
well here it is......
Offline jamie92j
« Reply #4 on: September 30, 2012, 07:02:40 PM »
couple more questions for all the Brickheads...
Radio: It does have one although but not connected, im not to sure where all the wires connect in, does anyone have a wiring diagram for these? Its not an original BMW radio, it is some old Ford unit with radio and tape deck! Is it possible to just wire a 3.5mm audio jack instead of using the radio head unit?!
Coolant: How do you go about topping it up?! I think the radiator cap is under the left side of the fairing? and the little coolant auxiliary tank fills under the seat somewhere?!
Splines: Any comprehensive guides for the greasing of splines? I read a little trick of using longer bolts to avoid stripping the rear end totally
ABS: seem to have a fault with the ABS, the light starts flashing at me once iv pressed the front brake on start up, and the ABS does not work
Oil: going to change the engine oil as it hasn't been done for a year ( bike only done 1k in the year though) should i do transmission oil at the same time?
Offline Inge K.
« Reply #5 on: September 30, 2012, 07:25:35 PM »
Radio: ask Ford.........wiring to the genuine radio is in the user`s manual.
Coolant: Radiator cap is under front, right of the tank...expansion tank is on right side under the seat.
Splines: look at the lieberry................lieberry card catalog.
ABS: check fault codes http://www.largiader.com/abs/absfault.html
Oil: change all fluids, then you know....
Inge K.
  • Norway
« Reply #6 on: September 30, 2012, 07:36:09 PM »
I hooked up the output from a Blaupunkt unit to some headphones and it worked.
You're better off doing a complete spline lube so that you can clean out the clutch splines of the old stuff well.
Here's a write-up for a K1100RS spline lube - similar but not identical to a K100.
K1100 ABS II Spline Lube Notes and Checklist
More on splines: Dr. L. Duck Hubbard explains: Splientology
General maintenance tips.
ABS Voodoo
Offline jamie92j
« Reply #7 on: September 30, 2012, 07:37:31 PM »
Inge K.
cheers inge
You ever heard of anyone with just a 3.5mm jack instead of the radio unit?
Can you point me in the direction of a wiring diagram?
Offline Inge K.
« Reply #8 on: September 30, 2012, 07:55:04 PM »
http://www.motobrick.com/ducktech/kwiring/K1100LT_94on/k11lt_94on_radio_wiring.jpg
http://www.motobrick.com/ducktech/kwiring/misc/K_Radio_Wiring.jpg
To a newer model than yours, but most would be identical. Probably you ain`t got the antenna amplifier.
3,5mm jack instead of the radio unit?
Do you mean 3,5mm to headphones instead of the loudspeakers.......shouldn`t be any problem as long the resistance is above 4 ohms.........AFAIK most headphones is 8-32 ohms.
  • Norway
Offline jamie92j
« Reply #9 on: September 30, 2012, 08:19:51 PM »
thanks again inge
will keep you updated on how i progress....
Offline jamie92j
« Reply #10 on: September 30, 2012, 08:23:37 PM »
no the other way round, so no radio head unit, just a 3.5mm wire for plugging an iPod into
Offline Inge K.
« Reply #11 on: September 30, 2012, 08:36:02 PM »
I don`t think an Ipod has power enough for the loudspeakers in the fairing, if it is that you have in mind.
You probably need an amplifier between.......but now I`m on thin ice, as I don`t now that much about
this modern things as ipod, ipad, iphone, ipid, ipyd etc.
Inge K.
  • Norway
Offline jamie92j
« Reply #12 on: September 30, 2012, 08:52:28 PM »
that is what i wanted, although not any product begining with i  :giggles
Im going to look further into this, i think i can make it work...
« Reply #13 on: October 01, 2012, 03:17:36 PM »
Inge K.
You are 100% correct on this. Very few speakers are efficient enough to run on an iPod without a amplifier, and those that can will not be loud enough for a bike.
Lynn
1976 R60/6 RIP
