Author Topic: Model Specs  (Read 128634 times)
Model Specs
« on: May 14, 2011, 12:12:18 AM »
The easy way to tell if you’ve got an “FYK” engine (1985 US K100)
Scroll down to see the specs and illustrations of the 1984 to 1997 model year motobricks.
BMW K100
BMW K100
BMW K100RS (2 Valve)
BMW K100RT
BMW K100RT
BMW K100LT
BMW K100LT
BMW K75
BMW K75
BMW K75C
BMW K75C
BMW K75S
BMW K75S
BMW K75RT
BMW K75RT
BMW K1
BMW K1
BMW K100RS 4 Valve
BMW K100RS - 4 Valve
BMW K1100LT
BMW K1100LT
BMW K1100RS
BMW K1100RS
BMW K1100LT Specifications
« Reply #1 on: May 14, 2011, 12:13:56 AM »
BMW K1100LT
BMW K1100LT
Production
Start of Production1991
End of Production1999
Number Sold22.757
Price22.850,- DM
Engine
Motor Typefour-stroke, horizontal four-cylinder in-line engine, liquid-cooled
Bore x Stroke70,5 x 70 mm
Cubic Capacity1092 ccm
Max Power100 hp (74 KW) at 7500 rpm
Max Torque107 Nm at 5500 rpm
Compression Ratio11.0 : 1
Valves per Cylinder4
Valve ControlDOHC, using drive chain and cup tappets
Carburation Systemelectronic injection, Bosch Motronic MA 2.2
Engine Lubricationwet sump
Power transmission
Clutchdry single plate
Number of Gears5
Gear Selectiondog-type gearbox (ratchet foot lever)
Gear Ratios   4.50 / 2.96 / 2.30 / 1.88 / 1.61 :1
Rear Wheel Ratio1 : 2.81
Bevel / Crownwheel11 / 32 teeth
Electrical system
Ignitionelectronic ignition, Bosch Motronic MA 2.2
Alternator12 V 460 W (1993-)
12 V 700 W (1994+)
Starter0.7 kW
Spark PlugsBosch XR 5 DC, Beru 12 R-5 DU
03/97 on: XR7LDC
Chassis
Type of Frametubular space frame, engine serving as load-bearing component
Front Suspensiontelescopic fork with hydraulic shock absorber
Rear SuspensionBMW Paralever swinging arm
Spring Travel front/rear135 / 120 mm5.32" / 4.72"
Rims front2.50 x 18 MT H 2
Rims rear3.00 x 17 MT H 2
Tyres front110/80-VR 18
Tyres rear140/80-VR 17
Brakes frontdual-disc brake 305 mm dia11.22"
Brakes rearsingle disc brake 285 mm dia12.01"
Dimensions / Weights
Length x Width x Height2250 x 915 x 1450 mm88.6"(7' 4.6") x 36.0"(3') x 57.1"(4' 9.1")
Wheel Base1565 mm61.6"(5' 1.6")
Tank Capacity22 l5.81 Gal - 4.84 Imp Gal
Unladen Weight, full Tank290 kg639 lb
Max permissible Weight500 kg1,102 lb
Ground Clearance125 mm4.9"
Fuel Consumption4,9 l/100 km (at constant 90 kph)48.0 mpg (@ 60 mph)
Top Speed210 kph130 mph
Acceleration0-100 kph         4,3 sec0-60 mph
Power and torque:
BMW K100RS 4 Valve Specifications
« Reply #2 on: May 14, 2011, 12:15:45 AM »
BMW K100RS4V
Production
Start of Production1989
End of Production1992
Number Sold12.666
Price19.950,- DM
Engine
Bore x Stroke67 x 70 mm
Cubic Capacity987 ccm
Max Power100 hp (74 KW) at 8000 rpm
Max Torque100 Nm at 6750 rpm
Carburation Systemelectronic injection, Bosch Motronic MA 2.1
Power transmission
Number of Gears5
Bevel / Crownwheel11 / 31 teeth
Electrical system
Ignition   electronic ignition, Bosch Motronic MA 2.1
Starter0.7 kW
Chassis
Spring Travel front/rear135 / 140 mm5.32" / 5.51"
Rims front3.50-17 MT H 2
Rims rear4.50-18 MT H 2
Tyres front120/70-ZR 17
Tyres rear160/60-ZR 18
Length x Width x Height2230 x 875 x 1260 mm87.8"(7' 3.8") x 34.4"(2' 10.4") x 49.6"(4' 1.6")
Unladen Weight, full Tank259 kg571 lb
Max permissible Weight480 kg1,058 lb
Ground Clearance140 mm5.5"
Fuel Consumption4,7 l/100 km (at constant 90 kph)50.0 mpg (@ 60 mph)
Top Speed232 kph144 mph
Acceleration0-100 kph         3,9 sec0-60 mph
Power and torque:
BMW K1 Specifications
« Reply #3 on: May 14, 2011, 12:16:54 AM »
BMW K1
BMW K1
Production
Start of Production1988
End of Production1993
Number Sold6.921
Price20.200,- DM
Engine
Power transmission
Number of Gears5
Rear Wheel Ratio1 : 2.75
Bevel / Crownwheel12 / 33 teeth
Electrical system
Starter0.7 kW
Chassis
Length x Width x Height2230 x 875 x 1210 mm87.8"(7' 3.8") x 34.4"(2' 10.4") x 47.6"(3' 11.6")
Unladen Weight, full Tank234 kg516 lb
Fuel Consumption4,2 l/100 km (at constant 90 kph)56.0 mpg (@ 60 mph)
Top Speed240 kph149 mph
Power and torque:
BMW K75RT Specifications
« Reply #4 on: May 14, 2011, 12:21:46 AM »
BMW K75RT
BMW K75RT
Production
End of Production1996
Number Sold21.264
Price16.900,- DM
Engine
Motor Typefour-stroke, horizontal three-cylinder in-line engine, liquid-cooled
Cubic Capacity740 ccm
Max Power75 hp (55 KW) at 8500 rpm
Max Torque68 Nm at 6750 rpm
Valves per Cylinder2
Carburation Systemelectronic injection, Bosch LE-Jetronic
Power transmission
Number of Gears5
Gear Ratios4.50 / 2.96 / 2.30 / 1.88 / 1.67 :1
Rear Wheel Ratio1 : 3.20
Bevel / Crownwheel10 / 32 teeth
Electrical system
Ignitionelectronic ignition, Bosch Le-Jetronic
Starter0.7 kW
Spark PlugsBosch X 5 DC, Beru 12-5 DU
Chassis
Rear SuspensionBMW Monolever swinging arm
Spring Travel front/rear185 / 114 mm7.28" / 4.49"
Rims front2.50-18 MT H 2
Rims rear2.75-18 MT H 2
Tyres front100/90-18 56 H
Tyres rear120/90-18 56
Brakes frontdual-disc brake 285 mm dia11.22"
Brakes rearsingle disc brake 285 mm dia11.22"
Length x Width x Height2230 x 916 x 1460 mm87.8"(7' 3.8") x 36.1"(3' 0.1") x 57.5"(4' 9.5")
Wheel Base1516 mm59.7"(4' 11.7")
Tank Capacity21 l5.55 Gal - 4.62 Imp Gal
Unladen Weight, full Tank258 kg568 lb
Max permissible Weight450 kg992 lb
Ground Clearance175 mm6.9"
Fuel Consumption4,5 l/100 km (at constant 90 kph)52.3 mpg (@ 60 mph)
Top Speed185 kph115 mph
Acceleration0-100 kph         4,6 sec0-60 mph
Power and torque:
BMW K75S Specifications
« Reply #5 on: May 14, 2011, 12:22:31 AM »
BMW K75S
BMW K75S
Production
Start of Production1985
End of Production1995
Number Sold18.649
Price13.990,- DM
Engine
Power transmission
Number of Gears5
Rear Wheel Ratio1 : 3.20 or 1 : 3.09
Bevel / Crownwheel10 / 32 teeth or 11 / 34
Electrical system
Starter0.7 kW
Chassis
Rims rear2.75-17 MT H 2
Tyres rear130/90-17 56
Brakes rearsingle disc brake 285 mm dia7.78" / 11.22"
Length x Width x Height2220 x 900 x 1340 mm87.4"(7' 3.4") x 35.4"(2' 11.4") x 52.7"(4' 4.7")
Unladen Weight, full Tank229 kg504 lb
Fuel Consumption4,2 l/100 km (at constant 90 kph)58.8 mpg (@ 60 mph)
Acceleration0-100 kph         4,7 sec0-60 mph
Power and torque:
BMW K75C Specifications (includes the US only K75T model)
« Reply #6 on: May 14, 2011, 12:24:38 AM »
BMW K75C
BMW K75C
Production
End of Production1990
Number Sold9.566
Price12.890,- DM
Engine
Power transmission
Number of Gears5
Rear Wheel Ratio1 : 3.20 or 1 : 3.36
Bevel / Crownwheel10 / 32 teeth or 11 / 37
Electrical system
Starter0.7 kW
Chassis
Brakes rearsimplex drum brake 200 mm dia or single disc brake 285 mm dia7.78" / 11.22"
Length x Width x Height2220 x 900 x 1300 mm87.4"(7' 3.4") x 35.4"(2' 11.4") x 51.2"(4' 3.2")
Unladen Weight, full Tank227 kg500 lb
Top Speed200 kph127 mph
Power and torque:
Re: BMW K75C Specifications (includes the US only K75T model)
« Reply #7 on: May 14, 2011, 12:27:33 AM »
Footnote: The K75T was a US only version of the K75C.  It had a "naked" K100 fairing and a handlebar mounted large windscreen:
BMW K75 Specifications
« Reply #8 on: May 14, 2011, 12:29:43 AM »
BMW K75
BMW K75
Production
Start of Production1986
Number Sold18.485
Price11.990,- DM
Engine
Power transmission
Number of Gears5
Electrical system
Starter0.7 kW
Spark PlugsBosch XR 5 DC, Beru 12-5 DU, Champion A 85 YC
Chassis
Top Speed200 kph124 mph
Power and torque:
BMW K100LT Specifications
« Reply #9 on: May 14, 2011, 12:31:28 AM »
BMW K100LT
BMW K100LT
Production
End of Production1991
Number Sold14.899
Price18.530,- DM
Engine
Max Power90 hp (66 KW) at 8000 rpm
Max Torque86 Nm at 6000 rpm
Compression Ratio10.2 : 1
Power transmission
Number of Gears5
Gear Ratios4.50 / 2.96 / 2.30 / 1.88 / 1.61:1
Rear Wheel Ratio1 : 2.91
Bevel / Crownwheel11 / 32 teeth]
Electrical system
Starter0.7 kW
Chassis
Spring Travel front/rear185 / 110 mm7.3" / 4.3"
Tyres front100/90-V 18 or 100/90-VR 18
Tyres rear130/90-V 17 or 130/90-VR 17
Brakes frontdual-disc brake 285 mm dia11.2"
Brakes rearsingle disc brake 285 mm dia11.2"
Length x Width x Height2220 x 920 x 1155 mm87.4"(7' 3.4") x 36.2"(3' 9.2") x 45.5"(3' 9.5")
Tank Capacity22l5.81 Gal - 4.84 Imp Gal
Unladen Weight, full Tank283 kg623 lb
Max permissible Weight480 kg1,056 lb
Fuel Consumption4,4 l/100 km (at constant 90 kph)54.7 mpg
Top Speed215 kph134 mph
Acceleration0-100 kph         4,1 sec0-60 mph
Power and torque:
BMW K100RT Specifications
« Reply #10 on: May 14, 2011, 12:32:43 AM »
BMW K100RT
Production
Start of Production1984
End of Production1989
Number Sold22.335
Price15.600,- DM
Engine
Power transmission
Number of Gears5
Electrical system
Starter0.7 kW
Chassis
Unladen Weight, full Tank253 kg557 lb
Power and torque:
Like Like x 1 View List
BMW K100RS Specifications (2 Valve)
« Reply #11 on: May 14, 2011, 12:33:54 AM »
Production
Start of Production1983
Number Sold34.804
Price15.190,- DM
Engine
Power transmission
Number of Gears5
Bevel / Crownwheel11 / 31 teeth]
Electrical system
Starter0.7 kW
Chassis
Length x Width x Height2220 x 800 x 1271 mm87.4"(7' 3.4") x 31.5"(2' 7.5") x 50.0"(4' 2.0")
Tank Capacity22l]5.81 Gal - 4.84 Imp Gal
Unladen Weight, full Tank249 kg548 lb
Top Speed220 kph137 mph
Power and torque:
BMW K100 Specifications (The great grandaddy of them all.)
« Reply #12 on: May 14, 2011, 12:36:27 AM »
BMW K100
BMW K100
Production
Number Sold12.871
Price12.490,- DM
Engine
Power transmission
Number of Gears5
Rear Wheel Ratio1 : 2.91or 1 : 3.00 [K 100/2 from 1987 : 1 : 2.81
Bevel / Crownwheel11 / 32 teeth or 11 / 33 [K 100 / 2 from 1987: 11 / 31 teeth]
Electrical system
Starter0.7 kW
Chassis
Length x Width x Height2220 x 960 x 1155 mm87.4"(7' 3.4") x 37.8"(3' 1.8") x 45.5"(3' 9.5")
Tank Capacity22 l [K 100/2 from 1987: 21l]5.81 Gal - 4.84 Imp Gal[5.55 Gal - 4.62 Imp Gal]
Unladen Weight, full Tank239 kg [K 100/2 from 1987: 240 kg]527 lb[529 lb]
Max permissible Weight450 kg [K 100/2 from 1987: 480 kg]992 lb[1,058 lb]
Fuel Consumption5,0 l/100 km (at constant 90 kph)47.0 mpg
Power and torque:
BMW K1100RS Specifications
« Reply #13 on: February 08, 2015, 10:37:40 AM »
BMW K1100RS
BMW K1100RS
Production
Start of Production1992
Number Sold12.179
Price21.950,- DM
Engine
Power transmission
Number of Gears5
Electrical system
Alternator12 V 700 W
Starter0.7 kW
03/97 on: XR7LDC
Chassis
Tyres front120/70-VR 17
Tyres rear160/60-VR 18
Length x Width x Height2230 x 802 x 1260 mm87.8"(7' 3.8") x 31.6"(2' 7.6") x 49.6"(4' 1.6")
Unladen Weight, full Tank268 kg591 lb
Max permissible Weight485 kg1,069 lb
Acceleration0-100 kph         3,8 sec0-60 mph
