TECHNICAL DIRECTORY ~ MOTOBRICK SHOP MANUAL
Service Manuals ~ Parts Fiches ~ Model Specs
Model Specs
Topic: Model Specs (Read 132038 times)
frankenduck
Adrninistrator
Model Specs
May 14, 2011, 12:12:18 AM »
The easy way to tell if you’ve got an “FYK” engine (1985 US K100)
Scroll down to see the specs and illustrations of the 1984 to 1997 model year motobricks.
BMW K100
BMW K100
BMW K100RS (2 Valve)
BMW K100RT
BMW K100RT
BMW K100LT
BMW K100LT
BMW K75
BMW K75
BMW K75C
BMW K75C
BMW K75S
BMW K75S
BMW K75RT
BMW K75RT
BMW K1
BMW K1
BMW K100RS 4 Valve
BMW K100RS - 4 Valve
BMW K1100LT
BMW K1100LT
BMW K1100RS
BMW K1100RS
New to K bikes?
Click here.
K Bike Maintenance & Mods:
Click here.
frankenduck
Adrninistrator
BMW K1100LT Specifications
Reply #1 on:
May 14, 2011, 12:13:56 AM »
BMW K1100LT
BMW K1100LT
Production
Start of Production
1991
End of Production
1999
Number Sold
22.757
Price
22.850,- DM
Engine
Motor Type
four-stroke, horizontal four-cylinder in-line engine, liquid-cooled
Bore x Stroke
70,5 x 70 mm
Cubic Capacity
1092 ccm
Max Power
100 hp (74 KW) at 7500 rpm
Max Torque
107 Nm at 5500 rpm
Compression Ratio
11.0 : 1
Valves per Cylinder
4
Valve Control
DOHC, using drive chain and cup tappets
Carburation System
electronic injection, Bosch Motronic MA 2.2
Engine Lubrication
wet sump
Power transmission
Clutch
dry single plate
Number of Gears
5
Gear Selection
dog-type gearbox (ratchet foot lever)
Gear Ratios
4.50 / 2.96 / 2.30 / 1.88 / 1.61 :1
Rear Wheel Ratio
1 : 2.81
Bevel / Crownwheel
11 / 32 teeth
Electrical system
Ignition
electronic ignition, Bosch Motronic MA 2.2
Alternator
12 V 460 W (1993-)
12 V 700 W (1994+)
Starter
0.7 kW
Spark Plugs
Bosch XR 5 DC, Beru 12 R-5 DU
03/97 on: XR7LDC
Chassis
Type of Frame
tubular space frame, engine serving as load-bearing component
Front Suspension
telescopic fork with hydraulic shock absorber
Rear Suspension
BMW Paralever swinging arm
Spring Travel front/rear
135 / 120 mm
5.32" / 4.72"
Rims front
2.50 x 18 MT H 2
Rims rear
3.00 x 17 MT H 2
Tyres front
110/80-VR 18
Tyres rear
140/80-VR 17
Brakes front
dual-disc brake 305 mm dia
11.22"
Brakes rear
single disc brake 285 mm dia
12.01"
Dimensions / Weights
Length x Width x Height
2250 x 915 x 1450 mm
88.6"(7' 4.6") x 36.0"(3') x 57.1"(4' 9.1")
Wheel Base
1565 mm
61.6"(5' 1.6")
Tank Capacity
22 l
5.81 Gal - 4.84 Imp Gal
Unladen Weight, full Tank
290 kg
639 lb
Max permissible Weight
500 kg
1,102 lb
Ground Clearance
125 mm
4.9"
Fuel Consumption
4,9 l/100 km (at constant 90 kph)
48.0 mpg (@ 60 mph)
Top Speed
210 kph
130 mph
Acceleration
0-100 kph 4,3 sec
0-60 mph
Power and torque:
New to K bikes?
Click here.
Click here.
frankenduck
Adrninistrator
BMW K100RS 4 Valve Specifications
Reply #2 on:
May 14, 2011, 12:15:45 AM »
BMW K100RS4V
Production
Start of Production
1989
End of Production
1992
Number Sold
12.666
Price
19.950,- DM
Engine
Motor Type
Bore x Stroke
67 x 70 mm
Cubic Capacity
987 ccm
Max Power
100 hp (74 KW) at 8000 rpm
Max Torque
100 Nm at 6750 rpm
Compression Ratio
11.0 : 1
Valves per Cylinder
4
Valve Control
Carburation System
electronic injection, Bosch Motronic MA 2.1
Engine Lubrication
wet sump
Power transmission
Clutch
dry single plate
Number of Gears
5
Gear Selection
Gear Ratios
Rear Wheel Ratio
1 : 2.81
Bevel / Crownwheel
11 / 31 teeth
Electrical system
Ignition
electronic ignition, Bosch Motronic MA 2.1
Alternator
12 V 460 W
Starter
0.7 kW
Spark Plugs
Chassis
Type of Frame
Front Suspension
Rear Suspension
135 / 140 mm
5.32" / 5.51"
Rims front
3.50-17 MT H 2
Rims rear
4.50-18 MT H 2
Tyres front
120/70-ZR 17
Tyres rear
160/60-ZR 18
Brakes front
11.22"
Brakes rear
12.01"
2230 x 875 x 1260 mm
87.8"(7' 3.8") x 34.4"(2' 10.4") x 49.6"(4' 1.6")
Wheel Base
1565 mm
61.6"(5' 1.6")
Tank Capacity
22 l
259 kg
571 lb
480 kg
1,058 lb
Ground Clearance
140 mm
5.5"
Fuel Consumption
4,7 l/100 km (at constant 90 kph)
50.0 mpg (@ 60 mph)
Top Speed
232 kph
144 mph
Acceleration
0-100 kph 3,9 sec
0-60 mph
Power and torque:
New to K bikes?
Click here.
Click here.
frankenduck
Adrninistrator
BMW K1 Specifications
Reply #3 on:
May 14, 2011, 12:16:54 AM »
BMW K1
BMW K1
Production
Start of Production
1988
End of Production
1993
Number Sold
6.921
Price
20.200,- DM
Engine
Motor Type
Bore x Stroke
67 x 70 mm
Cubic Capacity
987 ccm
Max Power
Max Torque
100 Nm at 6750 rpm
Compression Ratio
11.0 : 1
Valves per Cylinder
4
Valve Control
Carburation System
Engine Lubrication
wet sump
Power transmission
Clutch
dry single plate
Number of Gears
5
Gear Selection
Gear Ratios
Rear Wheel Ratio
1 : 2.75
Bevel / Crownwheel
12 / 33 teeth
Electrical system
Ignition
Alternator
12 V 460 W
Starter
0.7 kW
Spark Plugs
Chassis
Type of Frame
Front Suspension
Rear Suspension
135 / 140 mm
5.32" / 5.51"
Rims front
3.50-17 MT H 2
Rims rear
4.50-18 MT H 2
Tyres front
120/70-ZR 17
Tyres rear
160/60-ZR 18
Brakes front
11.22"
Brakes rear
12.01"
2230 x 875 x 1210 mm
87.8"(7' 3.8") x 34.4"(2' 10.4") x 47.6"(3' 11.6")
Wheel Base
1565 mm
61.6"(5' 1.6")
Tank Capacity
22 l
234 kg
516 lb
480 kg
1,058 lb
Ground Clearance
140 mm
5.5"
Fuel Consumption
4,2 l/100 km (at constant 90 kph)
56.0 mpg (@ 60 mph)
Top Speed
240 kph
149 mph
Acceleration
0-100 kph 3,9 sec
0-60 mph
Power and torque:
New to K bikes?
Click here.
Click here.
frankenduck
Adrninistrator
BMW K75RT Specifications
Reply #4 on:
May 14, 2011, 12:21:46 AM »
BMW K75RT
BMW K75RT
Production
Start of Production
1989
End of Production
1996
Number Sold
21.264
Price
16.900,- DM
Engine
Motor Type
four-stroke, horizontal three-cylinder in-line engine, liquid-cooled
Bore x Stroke
67 x 70 mm
Cubic Capacity
740 ccm
Max Power
75 hp (55 KW) at 8500 rpm
Max Torque
68 Nm at 6750 rpm
Compression Ratio
11.0 : 1
Valves per Cylinder
2
Valve Control
Carburation System
electronic injection, Bosch LE-Jetronic
Engine Lubrication
wet sump
Power transmission
Clutch
dry single plate
Number of Gears
5
Gear Selection
Gear Ratios
4.50 / 2.96 / 2.30 / 1.88 / 1.67 :1
Rear Wheel Ratio
1 : 3.20
Bevel / Crownwheel
10 / 32 teeth
Electrical system
Ignition
electronic ignition, Bosch Le-Jetronic
Alternator
12 V 460 W
Starter
0.7 kW
Spark Plugs
Bosch X 5 DC, Beru 12-5 DU
Chassis
Type of Frame
Front Suspension
Rear Suspension
BMW Monolever swinging arm
185 / 114 mm
7.28" / 4.49"
Rims front
2.50-18 MT H 2
Rims rear
2.75-18 MT H 2
Tyres front
100/90-18 56 H
Tyres rear
120/90-18 56
Brakes front
dual-disc brake 285 mm dia
11.22"
Brakes rear
11.22"
2230 x 916 x 1460 mm
87.8"(7' 3.8") x 36.1"(3' 0.1") x 57.5"(4' 9.5")
Wheel Base
1516 mm
59.7"(4' 11.7")
Tank Capacity
21 l
5.55 Gal - 4.62 Imp Gal
258 kg
568 lb
450 kg
992 lb
Ground Clearance
175 mm
6.9"
Fuel Consumption
4,5 l/100 km (at constant 90 kph)
52.3 mpg (@ 60 mph)
Top Speed
185 kph
115 mph
Acceleration
0-100 kph 4,6 sec
0-60 mph
Power and torque:
New to K bikes?
Click here.
Click here.
frankenduck
Adrninistrator
BMW K75S Specifications
Reply #5 on:
May 14, 2011, 12:22:31 AM »
BMW K75S
BMW K75S
Production
Start of Production
1985
End of Production
1995
Number Sold
18.649
Price
13.990,- DM
Engine
Motor Type
Bore x Stroke
67 x 70 mm
Cubic Capacity
740 ccm
Max Power
Max Torque
68 Nm at 6750 rpm
Compression Ratio
11.0 : 1
Valves per Cylinder
2
Valve Control
Carburation System
Engine Lubrication
wet sump
Power transmission
Clutch
dry single plate
Number of Gears
5
Gear Selection
Gear Ratios
Rear Wheel Ratio
1 : 3.20 or 1 : 3.09
Bevel / Crownwheel
10 / 32 teeth or 11 / 34
Electrical system
Ignition
Alternator
12 V 460 W
Starter
0.7 kW
Spark Plugs
Chassis
Type of Frame
Front Suspension
Rear Suspension
185 / 114 mm
7.28" / 4.49"
Rims front
2.50-18 MT H 2
Rims rear
2.75-17 MT H 2
Tyres front
100/90-18 56 H
Tyres rear
130/90-17 56
Brakes front
11.22"
Brakes rear
7.78" / 11.22"
2220 x 900 x 1340 mm
87.4"(7' 3.4") x 35.4"(2' 11.4") x 52.7"(4' 4.7")
Wheel Base
1516 mm
59.7"(4' 11.7")
Tank Capacity
21 l
229 kg
504 lb
450 kg
992 lb
Ground Clearance
175 mm
6.9"
Fuel Consumption
58.8 mpg (@ 60 mph)
Top Speed
210 kph
130 mph
Acceleration
0-100 kph 4,7 sec
0-60 mph
Power and torque:
New to K bikes?
Click here.
Click here.
frankenduck
Adrninistrator
BMW K75C Specifications (includes the US only K75T model)
Reply #6 on:
May 14, 2011, 12:24:38 AM »
BMW K75C
BMW K75C
Production
Start of Production
1985
End of Production
1990
Number Sold
9.566
Price
12.890,- DM
Engine
Motor Type
Bore x Stroke
67 x 70 mm
Cubic Capacity
740 ccm
Max Power
Max Torque
68 Nm at 6750 rpm
Compression Ratio
11.0 : 1
Valves per Cylinder
2
Valve Control
Carburation System
Engine Lubrication
wet sump
Power transmission
Clutch
dry single plate
Number of Gears
5
Gear Selection
Gear Ratios
Rear Wheel Ratio
1 : 3.20 or 1 : 3.36
Bevel / Crownwheel
10 / 32 teeth or 11 / 37
Electrical system
Ignition
Alternator
12 V 460 W
Starter
0.7 kW
Spark Plugs
Chassis
Type of Frame
Front Suspension
Rear Suspension
185 / 114 mm
7.28" / 4.49"
Rims front
2.50-18 MT H 2
Rims rear
2.75-18 MT H 2
Tyres front
100/90-18 56 H
Tyres rear
120/90-18 56
Brakes front
11.22"
Brakes rear
simplex drum brake 200 mm dia or single disc brake 285 mm dia
7.78" / 11.22"
2220 x 900 x 1300 mm
87.4"(7' 3.4") x 35.4"(2' 11.4") x 51.2"(4' 3.2")
Wheel Base
1516 mm
59.7"(4' 11.7")
Tank Capacity
21 l
227 kg
500 lb
450 kg
992 lb
Ground Clearance
175 mm
6.9"
Fuel Consumption
58.8 mpg (@ 60 mph)
Top Speed
200 kph
127 mph
Acceleration
0-100 kph 4,6 sec
0-60 mph
Power and torque:
New to K bikes?
Click here.
Click here.
frankenduck
Adrninistrator
Re: BMW K75C Specifications (includes the US only K75T model)
Reply #7 on:
May 14, 2011, 12:27:33 AM »
Footnote: The K75T was a US only version of the K75C. It had a "naked" K100 fairing and a handlebar mounted large windscreen:
New to K bikes?
Click here.
Click here.
frankenduck
Adrninistrator
BMW K75 Specifications
Reply #8 on:
May 14, 2011, 12:29:43 AM »
BMW K75
BMW K75
Production
Start of Production
1986
End of Production
1996
Number Sold
18.485
Price
11.990,- DM
Engine
Motor Type
Bore x Stroke
67 x 70 mm
Cubic Capacity
740 ccm
Max Power
Max Torque
68 Nm at 6750 rpm
Compression Ratio
11.0 : 1
Valves per Cylinder
2
Valve Control
Carburation System
Engine Lubrication
wet sump
Power transmission
Clutch
dry single plate
Number of Gears
5
Gear Selection
Gear Ratios
Rear Wheel Ratio
Bevel / Crownwheel
Electrical system
Ignition
Alternator
12 V 460 W
Starter
0.7 kW
Spark Plugs
Bosch XR 5 DC, Beru 12-5 DU, Champion A 85 YC
Chassis
Type of Frame
Front Suspension
Rear Suspension
185 / 114 mm
7.28" / 4.49"
Rims front
2.50-18 MT H 2
Rims rear
2.75-18 MT H 2
Tyres front
100/90-18 56 H
Tyres rear
120/90-18 56
Brakes front
11.22"
Brakes rear
7.78" / 11.22"
Wheel Base
1516 mm
59.7"(4' 11.7")
Tank Capacity
21 l
227 kg
500 lb
450 kg
992 lb
Ground Clearance
175 mm
6.9"
Fuel Consumption
56.0 mpg (@ 60 mph)
Top Speed
200 kph
124 mph
Acceleration
0-100 kph 4,6 sec
0-60 mph
Power and torque:
New to K bikes?
Click here.
Click here.
frankenduck
Adrninistrator
BMW K100LT Specifications
Reply #9 on:
May 14, 2011, 12:31:28 AM »
BMW K100LT
BMW K100LT
Production
Start of Production
1986
End of Production
1991
Number Sold
14.899
Price
18.530,- DM
Engine
Motor Type
Bore x Stroke
67 x 70 mm
Cubic Capacity
987 ccm
Max Power
90 hp (66 KW) at 8000 rpm
Max Torque
86 Nm at 6000 rpm
Compression Ratio
10.2 : 1
Valves per Cylinder
2
Valve Control
Carburation System
Engine Lubrication
wet sump
Power transmission
Clutch
dry single plate
Number of Gears
5
Gear Selection
Gear Ratios
4.50 / 2.96 / 2.30 / 1.88 / 1.61:1
Rear Wheel Ratio
1 : 2.91
Bevel / Crownwheel
11 / 32 teeth]
Electrical system
Ignition
Alternator
12 V 460 W
Starter
0.7 kW
Spark Plugs
Chassis
Type of Frame
Front Suspension
Rear Suspension
185 / 110 mm
7.3" / 4.3"
Rims front
2.50-18 MT H 2
Rims rear
2.75-17 MT H 2
Tyres front
100/90-V 18 or 100/90-VR 18
Tyres rear
130/90-V 17 or 130/90-VR 17
Brakes front
11.2"
Brakes rear
11.2"
2220 x 920 x 1155 mm
87.4"(7' 3.4") x 36.2"(3' 9.2") x 45.5"(3' 9.5")
Wheel Base
1516 mm
59.7"(4' 11.7")
Tank Capacity
22l
283 kg
623 lb
480 kg
1,056 lb
Ground Clearance
175 mm
6.9"
Fuel Consumption
4,4 l/100 km (at constant 90 kph)
54.7 mpg
Top Speed
215 kph
134 mph
Acceleration
0-100 kph 4,1 sec
0-60 mph
Power and torque:
New to K bikes?
Click here.
Click here.
frankenduck
Adrninistrator
BMW K100RT Specifications
Reply #10 on:
May 14, 2011, 12:32:43 AM »
BMW K100RT
Production
Start of Production
1984
End of Production
1989
Number Sold
22.335
Price
15.600,- DM
Engine
Motor Type
Bore x Stroke
67 x 70 mm
Cubic Capacity
987 ccm
Max Power
Max Torque
86 Nm at 6000 rpm
Compression Ratio
10.2 : 1
Valves per Cylinder
2
Valve Control
Carburation System
Engine Lubrication
wet sump
Power transmission
Clutch
dry single plate
Number of Gears
5
Gear Selection
Gear Ratios
Rear Wheel Ratio
1 : 2.91
Bevel / Crownwheel
11 / 32 teeth]
Electrical system
Ignition
Alternator
12 V 460 W
Starter
0.7 kW
Spark Plugs
Chassis
Type of Frame
Front Suspension
Rear Suspension
185 / 110 mm
7.3" / 4.3"
Rims front
2.50-18 MT H 2
Rims rear
2.75-17 MT H 2
Tyres front
Tyres rear
Brakes front
11.2"
Brakes rear
11.2"
Wheel Base
1516 mm
59.7"(4' 11.7")
Tank Capacity
22l
253 kg
557 lb
480 kg
1,056 lb
Ground Clearance
175 mm
6.9"
Fuel Consumption
54.7 mpg
Top Speed
215 kph
134 mph
Acceleration
0-100 kph 4,1 sec
0-60 mph
Power and torque:
New to K bikes?
Click here.
Click here.
Like x 1
View List
frankenduck
Adrninistrator
BMW K100RS Specifications (2 Valve)
Reply #11 on:
May 14, 2011, 12:33:54 AM »
Production
Start of Production
1983
End of Production
1989
Number Sold
34.804
Price
15.190,- DM
Engine
Motor Type
Bore x Stroke
67 x 70 mm
Cubic Capacity
987 ccm
Max Power
Max Torque
86 Nm at 6000 rpm
Compression Ratio
10.2 : 1
Valves per Cylinder
2
Valve Control
Carburation System
Engine Lubrication
wet sump
Power transmission
Clutch
dry single plate
Number of Gears
5
Gear Selection
Gear Ratios
Rear Wheel Ratio
1 : 2.81
Bevel / Crownwheel
11 / 31 teeth]
Electrical system
Ignition
Alternator
12 V 460 W
Starter
0.7 kW
Spark Plugs
Chassis
Type of Frame
Front Suspension
Rear Suspension
185 / 110 mm
7.3" / 4.3"
Rims front
2.50-18 MT H 2
Rims rear
2.75-17 MT H 2
Tyres front
Tyres rear
Brakes front
11.2"
Brakes rear
11.2"
2220 x 800 x 1271 mm
87.4"(7' 3.4") x 31.5"(2' 7.5") x 50.0"(4' 2.0")
Wheel Base
1516 mm
59.7"(4' 11.7")
Tank Capacity
22l]
249 kg
548 lb
480 kg
1,056 lb
Ground Clearance
175 mm
6.9"
Fuel Consumption
54.7 mpg
Top Speed
220 kph
137 mph
Acceleration
0-100 kph 4,3 sec
0-60 mph
Power and torque:
New to K bikes?
Click here.
Click here.
frankenduck
Adrninistrator
BMW K100 Specifications (The great grandaddy of them all.)
Reply #12 on:
May 14, 2011, 12:36:27 AM »
BMW K100
BMW K100
Production
Start of Production
1983
End of Production
1990
Number Sold
12.871
Price
12.490,- DM
Engine
Motor Type
Bore x Stroke
67 x 70 mm
Cubic Capacity
987 ccm
Max Power
Max Torque
86 Nm at 6000 rpm
Compression Ratio
10.2 : 1
Valves per Cylinder
2
Valve Control
Carburation System
Engine Lubrication
wet sump
Power transmission
Clutch
dry single plate
Number of Gears
5
Gear Selection
Gear Ratios
Rear Wheel Ratio
1 : 2.91or 1 : 3.00 [K 100/2 from 1987 : 1 : 2.81
Bevel / Crownwheel
11 / 32 teeth or 11 / 33 [K 100 / 2 from 1987: 11 / 31 teeth]
Electrical system
Ignition
Alternator
12 V 460 W
Starter
0.7 kW
Spark Plugs
Chassis
Type of Frame
Front Suspension
Rear Suspension
185 / 110 mm
7.3" / 4.3"
Rims front
2.50-18 MT H 2
Rims rear
2.75-17 MT H 2
Tyres front
100/90-V 18
Tyres rear
130/90-V 17
Brakes front
11.2"
Brakes rear
11.2"
2220 x 960 x 1155 mm
87.4"(7' 3.4") x 37.8"(3' 1.8") x 45.5"(3' 9.5")
Wheel Base
1516 mm
59.7"(4' 11.7")
Tank Capacity
22 l [K 100/2 from 1987: 21l]
5.81 Gal - 4.84 Imp Gal[5.55 Gal - 4.62 Imp Gal]
239 kg [K 100/2 from 1987: 240 kg]
527 lb[529 lb]
450 kg [K 100/2 from 1987: 480 kg]
992 lb[1,058 lb]
Ground Clearance
175 mm
6.9"
Fuel Consumption
5,0 l/100 km (at constant 90 kph)
47.0 mpg
Top Speed
215 kph
134 mph
Acceleration
0-100 kph 4,3 sec
0-60 mph
Power and torque:
New to K bikes?
Click here.
Click here.
johnny
TrailBrakingThrottleWhacker
BMW K1100RS Specifications
Reply #13 on:
February 08, 2015, 10:37:40 AM »
BMW K1100RS
BMW K1100RS
Production
Start of Production
1992
End of Production
1996
Number Sold
12.179
Price
21.950,- DM
Engine
Motor Type
Bore x Stroke
70,5 x 70 mm
Cubic Capacity
1092 ccm
Max Power
Max Torque
107 Nm at 5500 rpm
Compression Ratio
11.0 : 1
Valves per Cylinder
4
Valve Control
Carburation System
Engine Lubrication
wet sump
Power transmission
Clutch
dry single plate
Number of Gears
5
Gear Selection
Gear Ratios
Rear Wheel Ratio
1 : 2.81
Bevel / Crownwheel
11 / 32 teeth
Electrical system
Ignition
Alternator
12 V 700 W
Starter
0.7 kW
Spark Plugs
03/97 on: XR7LDC
Chassis
Type of Frame
Front Suspension
Rear Suspension
135 / 120 mm
5.32" / 4.72"
Rims front
3.50-17 MT H 2
Rims rear
4.50-18 MT H 2
Tyres front
120/70-VR 17
Tyres rear
160/60-VR 18
Brakes front
11.22"
Brakes rear
12.01"
2230 x 802 x 1260 mm
87.8"(7' 3.8") x 31.6"(2' 7.6") x 49.6"(4' 1.6")
Wheel Base
1565 mm
61.6"(5' 1.6")
Tank Capacity
22 l
268 kg
591 lb
485 kg
1,069 lb
Ground Clearance
125 mm
4.9"
Fuel Consumption
48.0 mpg (@ 60 mph)
Top Speed
220 kph
137 mph
Acceleration
0-100 kph 3,8 sec
0-60 mph
Model Specs
