Author Topic: how do i fit a temp gauge to k100rs  (Read 11039 times)
k100
« on: August 11, 2012, 04:40:42 AM »
what type of sender unit do i use our can it be uesd on the standead one aney info would be good....  :k100rs
k100
Re: how do i fit a temp gauge to k100rs
« Reply #1 on: August 11, 2012, 07:24:27 AM »
is there aneything speshall about the gaeg our will aney do
« Reply #2 on: August 11, 2012, 02:51:41 PM »
Which temperature are you trying to measure -- oil or water?
If oil, the sender replaces the oil drain plug.  Any sensor with M15 thread and can place 80ºC at midscale. The gauge should have a range 40ºC - 100ºC.   If water, the sensor connection is part of the wiring harness.
k100
« Reply #3 on: August 12, 2012, 02:06:06 AM »
so i should be Abel to by a generic water temp gage and connect to eggsisting  wiring ?
k100
« Reply #5 on: August 13, 2012, 12:47:05 AM »
 :2thumbup: thank you
k100
« Reply #6 on: August 13, 2012, 09:35:21 AM »
so its ok to ues standed vdo typ gauges ? yes _no our do i have to find genuwe bmw typ
 :dunno :dunno
« Reply #7 on: August 13, 2012, 09:38:38 AM »
 :dunno :dunno
YES, I have one in my bike. Needs a different sending unit but I just got used to where it reads and left the OEM in.
k100
« Reply #8 on: August 16, 2012, 04:56:19 AM »
ok my bike is an 84 and has nun of the wiering thas showen < now what ?  :dunno2: :yikes:
k100
« Reply #9 on: August 16, 2012, 05:01:11 AM »
i serpous the fuel gage is out of the question now ?  and is there a vdo water temp sender that will fit ?
 :confused:
