Author Topic: Rear fender eliminator / short fender kit for K75?  (Read 9210 times)
Gubro30
« on: August 08, 2012, 08:15:46 PM »
Does some sort of kit exists? Thanks!
Motorandy123
Re: Rear fender eliminator / short fender kit for K75?
« Reply #1 on: August 09, 2012, 02:55:24 PM »
Um most people use this bike for touring so want a bigger rear fender!
You can remove the part hanging down or the plastic on top. Some have
put aftermarket cafe style plastic there. You can remove the inner fender
easily. But no no one makes a fender eliminator specifically for this bike
(as far as I know)...
Gubro30
« Reply #2 on: August 23, 2012, 12:35:09 PM »
« Reply #3 on: August 23, 2012, 01:36:51 PM »
Should be easy enough to make your own.
Remove the rear part of the fender.
Make your own simple bracket to hold the license plate so that it bolts to:
Gubro30
« Reply #4 on: August 23, 2012, 02:10:06 PM »
Quote
Now is there any way to make the orange turn signal lenses clear?
No. Why?
Gubro30
« Reply #5 on: August 23, 2012, 03:11:48 PM »
Looks!
« Reply #6 on: August 23, 2012, 05:27:01 PM »
Check out this post on ADVrider:
http://www.advrider.com/forums/showpost.php?p=16924624&postcount=1101
The second photo is of the fender eliminator.  In fact, it appears to be the actual fender cut down to look like a fender eliminator.  It is very convincing and cheap to implement.
« Reply #7 on: August 23, 2012, 05:37:09 PM »
cheap to implement.
Whoever did that had to modify (angle up) the rear of the frame that the "wedge" usually rests on.
