Author Topic: The Blue Streak Gets New Clothes  (Read 95401 times)
Offline Shoganai
Re: The Blue Streak Gets New Clothes
« Reply #75 on: April 03, 2013, 08:54:50 AM »
Honey, I'm just an OCD hack with a bike addiction.  :embarass:
But thank you none the less.
There no words adequate to say how awesome all this is!
« Reply #76 on: April 03, 2013, 10:21:19 PM »
Really, thanks for posting all this Gwen.
Offline Shoganai
« Reply #77 on: April 14, 2013, 08:22:09 PM »
It's nearing the end of this project.
The wheels came back looking GREAT!
Because I believed I had burned up the first ambient temp gauge, I ordered another one. He is Stave checking it out to make sure it works with a 9v battery and the 12v to 5v step-down transformer.
It's all good.
Here you see where I mounted the transformer on the right and the temp gauge on the left.
Here Steve is mounting the Smart Tire pressure sensors before mounting the tires.
I used double stick polybutylene to mount the transformer and the clock switches.
Steve suggested the location and I loved it!
Brilliant!
Almost ready to ride.
I love the contrast between the black wheels and the new exhaust.
Here I'm mounting the temp gauge probe.
I love this old K1100RS.
And away we go!
The first ride was just around the block twice. The in full gear for about 00:30.
After getting back from a short ride with Steve following, we found a few missing or loose fittings.
It's a bike again! There are a few tweaks that need to be worked out but nothing that effects riding it.
I have since put another 100 miles on it without any issues.
Offline RetDet
« Reply #78 on: April 14, 2013, 09:29:41 PM »
Great job, beautiful bike.
Offline Shoganai
« Reply #79 on: April 14, 2013, 09:47:34 PM »
Thanks.
It's a very unique K1100RS, but still an honest looking old K11.
One of my goals throughout this project was remain true to the bikes form and function.
As I told Duck today...
I'm in a bit of a time crunch to work out some functional issues before H.M. on the first of May.
I made the mistake of wiring the clock bank into the PIAA relay, most likely on a wrong terminal causing them to turn off while I turn the PIAA's on.
Also I still need to retard the current on the running lights so that the blinkers can be seen.
I need to pull the clock panel off and water proof and seal in the clocks and temp gauge.
I'm not totally happy with the tank bag attachment at the saddle...need to rework it.
I still need to install the 2 gig chip in the 478.
I'm currently designing and hope to build a different 478 mount to lower it below the fairing.
I still need to order and install this...
http://www.jegs.com/i/JAZ-Products/5...08-06/10002/-1 because my current vent gushes fuel with the slightest lean of the bike.
I still need to dial in the J&M CB and trim the mic cover to fit better in my new helmet.
I need to hand paint the rear wheel bolt cover plate as well.
That's just the short, high profile list.
Offline Shoganai
« Reply #80 on: April 16, 2013, 09:43:16 PM »
Problem: this vent hemorrhages fuel when the fuel cell is full AND the bike is on the side stand.
Solution: Insert a value.
Note to self: MUST remember to OPEN the value as soon as the bike is vertical and BEFORE leaving the gas station!
I went to the local Speed shop and learned that the expensive roll over shut off fuel vents have to exceed 90 degrees of tip before the ball bearing shuts off fuel escaping.
Cost = $2.35
« Reply #81 on: April 17, 2013, 09:28:06 PM »
Thanks for sharing all your amazing work.
I'm curious to know how the aux fuel tank is plumbed into the fuel system.
« Reply #82 on: April 17, 2013, 09:44:37 PM »
That's looking really sharp, Shogs, very nice work!!!!
Offline Shoganai
« Reply #83 on: April 17, 2013, 11:04:08 PM »
Thanks guy.
I think brain surgery from the wrong end of python requires FAR LESS moving or removing of s*it to work on than digging my way to where the fan motor it mounted.
It quit working today.
Fuse is good.
Wiring directly to the battery (bypassing the relay) - no joy.
Offline Shoganai
« Reply #84 on: April 18, 2013, 01:02:53 AM »
It was seized. While I'm this deep I'm going to replace the thermostat also.
It's difficult to turn by hand which confirms full failure.
The up-side is it happened now and not on some long motorcycle ride across counry.
Offline BexarWolf
  • 1994 K1100RS - Rubik
« Reply #85 on: April 18, 2013, 09:56:39 AM »
Shogs, can you tell me more about the ambient temperature gauge?
Sit tall in the saddle, hold your head up high. Keep your eyes fixed where the trail meets the sky. Live like you ain't afraid to die. Don't be scared. Just enjoy the ride. ~ Chris LeDoux
« Reply #86 on: April 18, 2013, 07:10:00 PM »
Jeez Shogs, always takin' the easy way out...
Offline Shoganai
« Reply #87 on: April 23, 2013, 02:38:47 AM »
Offline Shoganai
« Reply #88 on: April 23, 2013, 02:41:58 AM »
 :neener:
It was like an Easter Egg hunt, I kept finding nuts, bolts, washers and one LED lamp that fell into the bowels of the bike while working on it since I bought the bike.
Oh, and who knew a radiator flush was included with EVERY fan removal.  :bang-head:
Done. If you have ever had to pull a fan out of a K11 you will understand why I made this wire a little longer.
Holy poop! :huh
How they ever managed to make that connection...it MUST have been assembled before any other wire was fished thru the frame.
Offline Shoganai
« Reply #89 on: April 23, 2013, 08:21:36 AM »
Update: on the K1100RS saddlebag catastrophic paint removal fiasco.
First - a brief review.
Today. Not too shabby with rattle cans.
Offline BexarWolf
« Reply #90 on: April 24, 2013, 12:40:45 AM »
This is what I used.
http://www.aliexpress.com/snapshot/223076857.html
You'll need this to step down the voltage from 12 to 5.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItemVersion&&item=221117981188&view=all&ssPageName=ADME%3AX%3AUPIOB%3AUS%3A1123&tid=1162758305012&guest=1
Thanks for the info! The step-down on Ebay has sold but I'm sure I can figure that part out.  :2thumbup:
Offline Shoganai
« Reply #91 on: April 24, 2013, 07:23:27 AM »
Offline Bassv
  • Ride it like you stole it
« Reply #92 on: April 24, 2013, 12:42:07 PM »
That bike looks awesome! Love the black wheels indeed  :2thumbup:
K75RT 1991
Offline Shoganai
« Reply #93 on: May 22, 2013, 05:45:08 AM »
I’ve been extremely busy with work, life, riding and wrenching and have not kept this thread up to date.
Note to self, a penny saved is NOT a penny earned if by installing an older, used fan motor ALSO fails.
Color me EXTREMELY not happy about going BACK in the damn bike THAT damn far AGAIN!
Yes, I tested it before installing it.
So I have 7 days off and this is the “To Do List”
1. Install BRAND new fan motor
2. Install electronic cruise control
3. Remove and remount fuel cell so that the top case bolts go all the way to the frame
4. Work on fuel gauge
5. Replace tragkorb lid support
6. Repair CPAP AC/DC converter
7. Re-set Smart Tire
8. Apply reflective tape to tragkorbs
9. Transfer the Shop Whore license tag to this bike
10. Make new license plate holder
« Reply #94 on: May 22, 2013, 07:03:29 AM »
Take a look at what this guy did for his top box..  You might find his solution using turnbuckles more flexible than long bolts.
« Reply #95 on: May 22, 2013, 08:42:35 AM »
Have you thought about a non OEM fan, Shogs?
« Reply #96 on: May 22, 2013, 08:50:45 AM »
IIRC she got a brand new motor assy able to fit the existing housing.....
Unless, of course, she changed her mind and went something totally different...........
Offline Quiltzig
  • K Guy
« Reply #97 on: November 17, 2014, 02:58:47 AM »
Hi Gwen,
Can you tell me where you got the ambient temperature gauge that you fitted to your K1100RS please?
  • Hamilton - New Zealand
  • K75S
1987 K75S - cafe racer project
2016 R9T (wifes ride)
2004 K1200RS
Offline Shoganai
« Reply #98 on: November 17, 2014, 03:08:03 PM »
China.
I don't have a working computer right now but should w/i 7 days.
When I do, I'll post a link here that I have saved in my favorites.
(replying via phone)
FWIW I buy all my small electronics, lights & switches from the East.
