Author Topic: Front LED signals no worky  (Read 11100 times)
Offline sh00ter
« on: May 19, 2012, 06:20:07 PM »
 Hey any of you cats know why the LEDs I put in my front turn signals don't work?  Same ones work fine in the back.  I've tried other too.  Can't make LEDs work on the front turn, what gives?   :nono
'94 1100 RS
Re: Front LED signals no worky
« Reply #1 on: May 19, 2012, 06:22:59 PM »
shOOter, are these in addition to the OEM bulb or replacements?
Offline sh00ter
« Reply #2 on: May 19, 2012, 06:38:14 PM »
replacements
'94 1100 RS
« Reply #3 on: May 19, 2012, 07:05:47 PM »
Do they have built in resistors to fool the light monitor? Maybe a link to the bulb would help so we knew what you were trying to install.
« Reply #4 on: May 19, 2012, 07:37:09 PM »
greetings sh00ter...
are they 1156 replacements...
you gotts a name and a number on those bulbs...
are you using them for marker and turn lights or just turn lights...
Offline sh00ter
« Reply #5 on: May 19, 2012, 08:07:41 PM »
Oh I didnt think of that.  The bulb monitor only cares about the front ones?  I thought it only did tail and head bulbs   Ill bypass the bmu and give that a shot.
'94 1100 RS
Offline sh00ter
« Reply #6 on: May 19, 2012, 08:09:51 PM »
I got a signal minder in this pppy.  Just trying to do signals.  Works perfect in the back. But the fronts just won't blink.  I'll try the bmu and see if that's it.
'94 1100 RS
« Reply #7 on: May 19, 2012, 09:03:25 PM »
do the old bulbs still work...
Offline sh00ter
« Reply #8 on: May 19, 2012, 09:21:00 PM »
yessir-e-bob.  plugged 'em back in until i get to the bottom of it
these are the bulbs i used in the front and back... no prob in the back.
http://goo.gl/BtVwp
'94 1100 RS
« Reply #9 on: May 19, 2012, 09:25:30 PM »
Sometimes the polarity is reversed on the RS front turn signals.
Hard fix: Swap and resolder the wires.
Easy fix:  Shave off the square corners on the connector with an Exacto knife or other sharp instrument and flip the connector over.
Before doing either use a voltmeter to confirm polarity.
Offline sh00ter
« Reply #10 on: May 19, 2012, 09:29:40 PM »
shizzz i never thought of that - makes perfect sense given the diode-ed-ness of the LEDs .... will report back manana .. it's miller time now.
'94 1100 RS
Offline sh00ter
« Reply #11 on: May 20, 2012, 12:39:04 PM »
I chose option 2; two second utility knife fixed it right up - thank you Duck!  (Maybe update the LED lieberry sticky with this tidbit?)
'94 1100 RS
« Reply #12 on: May 20, 2012, 12:45:27 PM »
Nah, don't want to make things TOO easy. :laugh
Offline sh00ter
« Reply #13 on: May 20, 2012, 12:50:26 PM »
It's all in the journey ...   :giggles :giggles
'94 1100 RS
